2
Everything posted by mkoch
I would like to know what these relays are. Here are a couple of pictures and a video. Thanks for any help on this! https://goo.gl/photos/WMvog46RqkaT4u8e9 https://goo.gl/photos/J11d48W25VJw8JFa9
nearly ready ! EA81, twins, propane Brumby
mkoch replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That, sir, is an awesome setup! -
I need to take my door apart on my '84 GL. I cannot remove the crank, how should I do it?
Thanks for the pics 1982gl4! You are helping move this project along more than you know. And, the job you did in the build-thread, just wow.
Heya, 1982gl4, Thanks for the build thread. I the rocker panels arrived. Here is a video where I describe the problem, Could I just replace the lower part of the rocker panel? mkoch
Yep, they rust from the inside out. This looked pristine half an hour ago, then I started using a wire brush. Much of the car is not rusty, and I feel I can get a few more years out of it. I found rocker panels at this placehttps://www.millsupply.com/auto-body-rust-repair-panels/subaru/ After I order the part, what's the next step? The rest of the car really is in great condition
My 1984 GL 4wd is approaching 200,000 miles, and I plan to replace the front axles, struts, bearings, and calipers. Did I miss anything? While that area is dis-assembled, I would like to do the easy fixes now, so they don't have to be done later.
Looking for flasher unit, video, is this it?
mkoch replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here is a pic of the flasher unit. It is very difficult to reach! Other threads mention removing the frame which holds the fuse box. I was able to reach up with a screwdriver and unscrew the flasher unit. It is a very tight fit! I removed the driver's seat in order to have room to work. I will put the replacement flasher in a more accessable location. mkoch -
I have an exhaust problem with my 1984 GL wagon. http://smg.photobucket.com/user/weimadog/media/IMG_1068_zpsf20d217a.mp4.html The video explains the problem. I found it by connecting a shop vac to the exhaust pipe, and listening for the hiss. That's a lot more pleasant than getting under a car and dealing with a hot exhaust. One bold is rusted in place, the other one is still springy. What's the solution for this one?
1984 GL 4wd wagon, All four of the boots are ripped on the front axles. The CV joints are not causing any problems. I would like to replace the boots without removing the whole axle from the car. That is, remove the DOJ, and slide a boot over to the CV joint. What boots, and source, are recommended for this task?
So I found a curb in a snowbank...
mkoch replied to Ogrekhan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
About a year ago, I found a curb in a snowbank also! It caused a bent rear rim, bent suspension arm, and no other damage. I hope your repair will be as simple as mine was. -
Thanks for sharing this! No charge for the remote fuel filler door release!
I am also looking for one. I found this, which could be useful when you do the swap: http://www.carpartsdiscount.com/auto/parts/84/subaru/gl/windshield_seals/windshield_seal.html?3593=8398
I have noticed the same thing. I am wondering why there are not as many corresponding wagons for sale. It looks like the number of available GL wagons for sale has gone down for a couple of years.
I just installed a Weber Carburetor (electric choke) on my EA81 1984 GL Wagon. I just tried to start the engine, and the idle was very rough. The engine would not go above about 500 rpm, if that much. The exhaust does not smell strongly of gasoline. I smells more like coolant, with maybe a bit of gasoline. There is coolant on the outside of the intake manifold, as shown in the photo. Could something I did during the installation of the Weber cause a coolant leak? This one has me baffled, because of the location. The view in the photo is looking at the front of the engine. The distributor is on the left. What could cause this, and what can I do to fix it?
