vasy
About vasy
- Birthday 04/02/1952
Gender
Not Telling
Location
Richmond, VA
Vehicles
96 OBW 2.5
vasy's Achievements
Advanced Member (3/11)
14
I have a 2016 Outback with exactly the same issue. Just had the radio (head unit) replaced today under 3-year basic warranty. I've heard other folks with the same issue and their dealers replaced the units under warranty also. Edit: it's not normal. The new head unit does not have these zig-zag lines, neither did my factory unit when new.
I have a 96 Outback with auto purchased new in 96. I replaced the factory rear pads around 40,000 miles. Replaced the rear pads again twice, about 40,000 miles apart using Adv Auto parts. Replaced the original factory front pads at 120,000 miles (not a typo) with OEM pads. We don't drive hard so that's easy on brakes. Had to replace 3 calipers after 120,000 miles due to dragging pistons. Used Adv Auto for the 2 rears and reman Subaru for the left front. Still have the factory caliper on the right front. Now at 151,000 miles no issues at all with brakes or anything else (did the HG around 130,000 miles).
I've used it in an unconventional way with good result. My AT pan had a minor leak at the rear corner. I first dropped the pan, cleaned off all old gasket, put on Ultra Grey on a brand new pan and installed the new pan. The leak came back 1 year later. I then used Right Stuff to fix the leak. But I did not remove the pan this time. I thoroughly cleaned the leaking area on the outside of the pan. First with dry paper towel followed by alcohol on paper towel. Cleaned it REALLY well. Then applied Right Stuff on the outside of the flange where the leak was. I applied several layers with finger, waited till it's dry before the next layer. Did so over the course of 2 days without driving the car. At the end, there is a thick layer of Right Stuff on the outside flange of the AT pan. Guess what, the leak has not come back in 2 years. I did the same to a persistent leaking valve cover gasket due to a casting defect on the cylinder head flange (there is a hairline crack on the bottom flange from the factory). Worked well for about 1.5 years now. The leak has totally stopped. The trick is to thoroughly clean the area before you put on Right Stuff, and put on several layers, one layer at a time. The issue I have with this product is with its storage. I used the type that you dispense with a caulk gun. I followed the instruction by leaving an 1-inch of the stuff hanging out of the spout.as a plug. But after about a year of storage, the remaining stuff in the tube became partially hardened and it was difficult to push it out. If you can use it up in less than 6 months, it's not an issue. Don't have experience with the aerosol type.
Here is a picture of the factory oil filter on the FB engine showing part of the hole. As I turned the filter very slowly and removed it, most of the oil in the filter drained down into the crankcase. There was very little oil left in the filter resulting in no spilled oil at all. The only oil left in the round aluminum tray at the base of the filter was on the mounting flange. Cleaning up was extremely easy, the easiest oil change I've ever done. I also installed a Fumoto valve shown in the 2nd pic.
Exactly. I have a 2016 Outback so I know something about this. It's been discussed at Subaruoutback.org. This "hole" is simply an oval dimple about 2-3 mm deep. Mostly likely the result of the casting/machining process said above. I filled mine with JB Weld to get rid of the depression so that dirt and spilled oil don't get in there. Of course that's really not necessary. Any dirt there won't get into the engine with the filter in place. I changed the oil on this car a few days ago and the top-mounted filter is really easy to handle.
Coolant Level
vasy replied to jchrusc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have a 2016 Outback. Many 2015/16 Subarus come from the factory with low level of coolant in the overflow reservoir. Many say that's because they didn't fully burp the cooling system at the factory so the level gradually drops as you drive the car (it burps as you drive to let out trapped air in the system). Mine was in the middle of the hi/low marks with cold engine when I took delivery. It gradually dropped about 2 inches in the first 2 months and then stayed there. I read about many such reports on another forum. I think your service advisor was wrong. Whatever is stated in the manual is correct. But in any case, as long as you have at least some coolant in the overflow, the radiator is full or near full and that'll do its job. I keep it at full mark with a cold engine for both my 1996 and 2016. For both cars, it does not spill out of the overflow no matter how long I drive the cars. -
EGR code
vasy replied to sub96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is a small metal tube leading to the EGR valve. When I had P0400 6 months ago (~142,000 miles), I removed the EGR and used a stiff wire to poke into this tube to clean out the inside. I reused the original metal gasket and the code never came back. -
I just wanted to point out that in some cases, the splines of the axle on the wheel end get so tightly fused with the hub, you can't separate the axle from the hub no matter what you do with any tool. I've heard people breaking the hub into 2 pieces while using a hydraulic press to separate the axle from the hub. That happened to me on the right front (I didn't break anything, just couldn't separate with a gear puller from Advance Auto after soaking with PB Blaster for a few days). I just replaced the boots and grease. On the left side, the axle and hub came apart with a slight pull. And I don't get lot of snow where I live.
I was wrong earlier saying there was only 1 bulb. There are several on the back side of the panel. The light on the top area in front of the panel I was referring to is for illuminating the gauge needles. These 4 needles on the 96 are not self-illuminating. But my intermittent problem is that when this problem does not show up, all bulbs work. When the problem shows up, none works. The entire panel is pitch black. It's all or none. So it's not a bulb issue. It's probably a bad connection somewhere or a switch on/off issue. This problem did not happen last night.
