5
Everything posted by Caboobaroo
Convert it to a 5-lug from an XT6. Larger swaybars, upgradable brakes, struts, and better wheel/tire selection. Check out the thread I have in the USRM about the swap. http://www.ultimatesubaru.org/forum/showthread.php?t=50400
I have a 1979 brat 4x4 and need help...
Caboobaroo replied to Subaru_Mechanic's topic in Subaru Retrofitting
Sorry but you can't upgrade it. Only thing to do is to replace it with a used one, or go get a new one... The dash is made to fit in a certain style and size of heater core. I got mine sitting on my shop floor when I put my Brat back together. -
RX is up and running again
Caboobaroo replied to harpua's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dude, where are you at in Wyoming? I still got loads of EA82T parts and such. You in Laramie still or moved on to a better place in this state... if there is such a place.. Hit me up man! -
Do you like the thought of replacing your engine numerous times? Do you like the thought of blowing it to little pieces? If so, go for it! On an EA71, not a smart move. Maybe if it was fuel injected, it would be a bit better because you could tune it easier.
Riddle me this...... wiring troubles
Caboobaroo replied to GoldDiggerRoo's topic in Historic Subaru Forum: 50's thru 70's
the wiring harness is pretty basic since it has no ECM or fuel injection. Start looking under the dash or pull the dash out, which isn't hard either, and see what's going on. It might be behind the headlight switch since the main power wire to the switch has issues sometimes. -
New York!?!?!?! Some of those would be nice to have but alas, too far to pick up and shipping it all would be such a hassle, plus a ton of money.
thats what I'm thinking! Mines going to be painted as well as the engine... Maybe even the driveshaft!
Well you need to realize that there's going to be a lot of work that you'll have to incorperate into this car. A turbo and intercooler arn't going to bolt right in. You'll also need exhaust (header and turbo back) coolant and oil lines for the turbo, piping for the intake and outlet sides of the turbo, piping for the intercooler, some sort of fuel management, and much more. If you do decide to go with it, you're reliability is going to go way down, along with fuel mileage. Best bet, find a wrecked Legacy SS with the EJ22T in it and swap it all over. Much more easier and will be more reliable. What your friend speaks of, is a manual boost controller, to adjust the output of the turbo. You can also get an electronic one and adjust it from inside the cab. So, you might as well buy the car and drive it as it is. I have a ton of money into an older turbo Subaru and it still isn't running right and isn't very reliable.
Yes its a fairly simple swap actually... Check out this thread for a bit of info and I'll also expand on it as well... http://www.ultimatesubaru.org/forum/showthread.php?t=64249 The 1800 you refer to as, is an EA81 engine code. This engine will drop directly into the car without any modifcations. However, the tranny is another story. You'll need to figure out shift linakge since the linkages are mounted differently between an EA81 d/r and a EA71 (1600cc) single range. You COULD get an EA81 with a dual range in an '81 GL Brat which is still a gen 1 bodystyle. Also, I have heard that the front driver side axle will either rub or be very close to the steering column, right where it enters the front crossmember. The ideal swap for that, to get clearance, is a steering rack out of a '81 GL Brat with the EA81 in it. If the tranny might be a bit more then you want to handle, you can always swap the bellhousing on the EA71 engine, onto the EA81 engine and it willl bolt up directly to the tranny. I have swpaped an EA81 into a gen 1 Brat before but I haven't gotten my tranny in yet. I'm going to be using a single range 4wd 4-speed EA81 tranny. However, I'm not going to be using the fornt axles so I won't have to worry about the clearance issue. You can use your stock driveshaft and axles if you do swap the EA81 tranny into your car. Tranny mount should work but I can't say for sure.
You're going to want to get the intake harness from the XT if you haven't already. I have gotten one to work on my RX but since I have other issues with the car, she's not doing so hot. Basically on mine, I used a NA spyder intake which doesn't have the EGR valve like the turbo spyders, but it has the AAV on it as well. For some reason, I though when I pulled it, it had a knock sensor but when I went to install it, it wasn't there. I think I might have been imagining. Worst case senario, you'll have to do some repinning on the engine harness to get it to work, but its not too hard if you compare it with your stock harness. I had to wire in my knock sensor but I looked at the old harness to see which slots they went into. AS far as the XT6 TB, I haven't a clue...
MAJOR problem- Wiring Harness 1981 Brat
Caboobaroo replied to RdNkBrt's topic in Historic Subaru Forum: 50's thru 70's
If you can give me a couple pics of it laid out and how much of the harness you have, I can compare it to either one of my harnesses and my FSM and see what I can come up with! -
Im pimpin out my 79 brat and need some info...
Caboobaroo replied to Subaru_Mechanic's topic in Subaru Transplants
Like Jobs said, garner, who doesn't frequent this board very often, if at all, swapped an EA82T and pushbutton 4wd 5-speed into his gen 1 Brat. A lot of fab work and fitting that you have to do. The frame rails up front would have to b cut out a bit to make enough room for the valve covers. Here's a link to his pics... http://usmb.net/gallery/garners-sub-a-rama I would go with an EA81 myself. The only problem with EA81Ts is the fact that its harder to find them and harder to find parts for them as well. I'm putting an EA81 and single range 4-speed into my gen 1 Brat since it is also a street Brat (lowered, shaved everything, the works). It'll be a direct bolt in procedure but the tranny mount I think is going to give me some issues. I got a welder though! I did have a high compression JDM EA71 in my Brat when I still had it on the road. Sold it though, which is a bummer... Here's my pics... http://rides.webshots.com/album/302432023YUcDSD -
Hondasuck's first Subaru, which was an '87 STD hatchback, also had stars painted on the hood by him and another friend...
WOw, be glad it didn;t happen on your road trip out here or back. That could have been real nasty.... Then I think I'd be getting a PM about needing some help with it;) Shop's always open though:D
Well even wthe rubber line, if pinched off, will cause some major braking problems. It'll cause it to pull very hard the other direction, thus creating a larger hazard then a sticking caliper. Just pull the caliper off, grease the slides up a it and spray some WD-40 around the piston. Should help free it up a bit...
Ooops I Did It Again (head gasket)!!! UPDATE
Caboobaroo replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bah, the grapevine... what a wonderful place, especially in the middle of summer in a truck with nonfunctioning AC... Anyways, are you sure you blew a headgasket and not just overheated it to the point of fuel vapor lock? I think the reason why my RX was getting harder to start and didn't run as long was because it was getting to the point of vapor lock, and I'd shut it down before it would blow a headgasket. If she's not smoking, I'd start checking the coolant system for any signs of it blowing one. If not, you might be all right... Next time.. PULL OVER! -
Ok sounds good. If you need some help with measurements, I have 2 gen 1 Brats I can get them from! Neither have any striping on them though...
Todd, can you have the GL stripe kit made as well for the Brat? Its the stripe, that besides the targa stripe, runs from the front fenders all the way around the back. Its the same kind of striping on Laura's Brat seen here... Let me know Todd as I am looking for a set for my Brat as well. Don't know what color I want to go with but I'm thinking silver...
Yup. Sounds like a plan. Since swapping an automatic into a 4wd gen 1 is a lot of work then learning how to drive a stick. Just make sure you have a couple new clutches and you get good at pulling the engine;)
Rebuilding front end
Caboobaroo replied to Subieguy's topic in Historic Subaru Forum: 50's thru 70's
Don't really need a press to do any of the fornt end work on it. However, the tie rod ends and the balljoints are going to be a bit tight so have a tie rod fork ready for action! The wheel bearings are more of a press in fit, BUT if you have a larger hammer and a chisel, pound them out on a work bench with the bearing not having anything touching it. Only do that though, if you're planning on replacing the bearings. Don't forget the wheel bearing seals! Oh and one other thought. Make sure that the caliper slide bolts are well greased up with brake caliper lube. You can used regular lithium grease but with them being closer to the pads and rotors, not a wise idea. -
hate it bust your bubble but unless you want a 2wd Brat, you won't find an automatic 4wd tranny that'll bolt right in. You could put in an EA81 4wd automatic, but then you have the change the bellhousing on the engine and do some modifications to the body, as far as shifter linkage and whatnot. Also, why do you want an automatic Brat? They're gutless as it is and adding an automatic behind it will make it barely want to get out of its own way, let along, bu bye towing/hauling capabilities...
