Caboobaroo
Everything posted by Caboobaroo
  1. yeah cause it would still be sitting dead in your driveway!
  2. Mike, could you pull the passenger side rear quarter window for me bud? I still need one....
  3. when you put the clutch together, did you make sure to put the flywheel side in toward the flywheel? Maybe you got the clutch disc in backwards.... or try taking the clutch cable off of the tranny and start the car. Might need to be adjusted more possibly.
  4. well its either make 250 bucks or spend 50 to drive down there in a car that hasn't been out of my own neighborhood except for the one time I took it to work. You'll see it eventually, maybe after I get it painted, hehe:banana:
  5. yeah Tom, I'm not going to be able to go since I can't afford to take time off of work, plus my RX is still 3 different colors and not show worthy in my opinion.
  6. Mac tool number for Subaru Axle pin Removal tool... LT-730
  7. will that fit onto an EA82T? I think I can get one up here, hehe:banana:
  8. and a 36mm socket with a 1/2" breaker bar to get the axle nut off.
  9. I'm out. Gotta work this weekend to finish up a Mustang resto at work. Gotta have it done by the end of the month and at 12 bucks an hour, I ain't passing it up! So maybe us old schoolers will have to get together one of these weekends and have a bar-b-que or something. I'll bring hotdogs and a few other things if someone is willing to put it on.... Labor day weeked maybe?
  10. Shoot LUVMYBRAT a PM. I know he's after a few things like the rear roll down quarter windows with good seals to mate up to the door glass....
  11. Yeah but this is Will. He can't seem to make up his mind between an EJxx engine or a built EA82 engine. He changes his mind more then I change the oil in my car... and I change it a lot!
  12. I think I paid roughly 15 bucks after tax for mine from Mac. They were having a special on it I think but I'll check on Friday with our Mac guy and see if they're still availible at that price.
  13. and the plan with these components is......? Are you going to try and adapt them to a EA82T or EJ FTW?
  14. all right guys..... go to a local dealership that has the MAc tool guy come around once a week, and pick up the Subaru axle pin removal tool for less then 20 bucks. Yes, its the tool that is used by mechanics and for less then 20 bucks, it'll get the job done and you won't have to worry about it breaking off or any stupid deal like that. I bought it and it works awesome! I can get a number for it tomorrow since I have the paperwork in my toolbox at work.
  15. Is there a difference in the pumps for different engine sizes on the Fords? I need one now since I also have a AFPR....
  16. yes, I'd like to know too. Is there a difference for the engine sizes on the Fords or are all of them going to have the same pump?
  17. which is what I'm gonna use it for, hehe:brow:
  18. if you didn't put the torque converter back in right, you would have had a lot more problems before running the car. For example, you would have had to fight the engine to get it anywhere near close to the bellhousing on the tranny, then if you did, and said TQ wasn't lined up right, you would have heard some very bad noises when you pulled the engine into the tranny. Like a loud bang, some metal grinding, etc. Then, when you were to start it up, there would have been ATF under the car pouring out and it wouldn't have moved anywhere, along with various grinding noises. I've seen it done before, not a pretty sight:eek:
  19. you should ask him what are the mods. He's got more then one;)
  20. yeah mine ticked real loud right as the oilpump went out. Heard it get really loud but it was too late for it. Oh and I also have a shovel, wanna go dig up some more old posts?
  21. hehe, a bit.... and I got one up here just an hour from Colorado and its a bit modified too... doesn't need an engine either:-p
  22. Mine went VROOOOOMMMM..... clunk clunk clunk....... knock knock knock after 20 miles...
  23. Mine will be put back together this weekend, YAY! I'll be running the 260 cams from Delta with a high compression SPFI block, TD04, IC and a lot of other goodies as well. Too bad I won't be able to make it to the show this year. Kinda a far drive for me and couldn't get the time off approved. Next year though, I'll be there.
  24. well here's the deal. I'm going to be putting a new alternator into it, or rebuild this one. However, the battery is dead and I can only get it to run for a few seconds sicne the fuel pump is wired to the alternator. Also, car is an auto so I can push it if need be but rather not with my messed up back and all. If I can get it outside, then I'm going to throw a cover over it and call it good for right now. My RX needs the engine put back into it and running this weekend.
