5
Everything posted by Caboobaroo
I would do that to my RX but I look at almost $7k sitting there and think.......
Well on my search for some new injectors, I came across a company on ebay selling a set of 6 injectors for the 280ZX turbo. I sent them a message and they are willing to do sets of four for us Subaru people. So, if you're interested, later today (5/20), they are going to be putting up a "Buy It Now' on a set for a '89 Subaru. Check it out!
WCSS8 Mug Ordering Time
Caboobaroo replied to Subarutex's topic in Meet n' Greet. Your USMB Welcome Center
and I'm now old enough to join you Eric! -
like I said online the other night, that thing is SWEET! Gonna have it or the RX at WCSS8 this year?
spfi on a ea71? possible?
Caboobaroo replied to 75subie's topic in Historic Subaru Forum: 50's thru 70's
now does it fit a standard EA71 like what is found in gen 1 cars, or does it fit the fatcase EA71 which is the same as a EA81? -
Adding a cat to a car that never had one.
Caboobaroo replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I got a shovel guys, wanna dig up anymore dead posts? -
EA82-T Performance Cams
Caboobaroo replied to Steveman09's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmmm then maybe I should go with the 272 cams....... -
Maybe I'll have to come over and show you. It's pretty straight forward and the one you need is a very common bolt on Subaru. The last one I bought was 40 bucks or so, and it came with 10 helicoil inserts.
a drill and a helicoil my friend. Gonna be the only way to fix it.
GL-10s never came with an airbag. You can cut out the inner hub of a stock wheel, drill a few holes and tap them, and bolt on an aftermarket steering wheel if you like to.
Well I am planning on tearing it down to the shortblock, replacing all of the seals/gaskets, putting my gen 2 turbo heads with my cams on it, and a new oil pump as well so I don't have it die on me... again. I also have planned to get the block and heads O-ringed as well, but I dunno if I can use stock headgaskets with the O-rings. Anyone know?
yes you can do that, or modify the base where the TB will mount to so it'll bolt to a EA71 intake. -
So I have sourced a few options from my personal junkyard. I can get all these for free mind you so here we go. EA82 SPFI x2 EA82 carbed EA82T All engines are unknown condition. The turbo engine was sitting in the car with no intake, valve covers and now has been out of the car enduring the weather for quite a few months. One of the SPFI engines has been torn down for some unknown reason but is still in the car. Carbed and the other SPFI engine are still complete and are sitting in the cars out of the weather. So, what would make a good high compression EA82T from these options? What compression ratio is going to be lower then the other (SPFI vs. carbed)? I don't want to go extreme high compression cause then I will have some issues running on pump gas when I move back to the PNW and higher boost. I'm planning on running about 10psi of boost in this car with the larger 280ZX turbo injectors and AFPR. I do plan on taking it to the drag strip a few times but I'll get some 110 octane for that;) So what do you guys think, and what opinions do you have? Also, my Delta cams (260 duration) are planned to go in as well. Plus a few other mods like exhaust and such.
ARGH!!!!! bad oilpump + running EA82T = .....
Caboobaroo replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh I know I can carry out a Subaru engine;) I do think I have sourced an engine up here though for free:D -
^^^^ SAWEET!!!! Now to go find an engine! -
yes, yes they do. Too bad I don't need it:D -
yes I know this, BUT the MPFI I believe has the higher compression ratio, plus it has the bumg on top of the engine thats threaded for the knock sensor. I'm gonna be looking into some of the differences of these engines still.... -
MEET: CO: May 21th at Red Rocks Park
Caboobaroo replied to The Korean's topic in Meet n' Greet. Your USMB Welcome Center
yup, whole engine is toast. Won't even turn over. Check out my WANTED post in the Marketplace.... I need a MPFI NA engine now, gonna build it up;) -
Why's that? Did Tex have issues with them? These are the first set of Delta 260 cams that were made. I got them from WJM and he was running then with no issues I believe. -
Why's that? Did Tex have issues with them? These are the frist set of Delta 260 cams that were made. I got them from WJM and he was running then with no issues I believe.
