5
Everything posted by Caboobaroo
ARGH!!!!! bad oilpump + running EA82T = .....
Caboobaroo replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wasn't a junkyard engine. It came to me from a felow board member for free, had about 120k miles on it, and ran fine when pulled, just had a blown intake gasket. -
well I edited my WANTED post so here's kidna the plan now... MPFI NA EA82, gen 2 turbo heads which are on deceased engine, Delta 260 cams which are in my shop in cam towers and new seals, plus all of the extra bolt on stuff I have. 8.7:1 compression ratio plus those cams will make one pretty awesome engine... Yes, she did start ticking really loud right before it died. Bah... what a day. -
MEET: CO: May 21th at Red Rocks Park
Caboobaroo replied to The Korean's topic in Meet n' Greet. Your USMB Welcome Center
Welp... I'll be coming in a Bronco... RX decided it was going to give its oil pump away and head south on me:( -
Not a good thing... was getting some more of the vacuum lines and such finished up on it and decided to take it out for a spin. Was runnin great, then power started lagging so I turned around and headed for home. 6 blocks from my house, a terrible terrible sounds came from my engine.... it went SQUEAK, SQUEAK, SQUEAK, KNOCK, KNOCK, KNOCK and then stopped running... not it won't turn over for anything... bah, now I need a new engine....
To pop the CV axle apart, all you need is a couple donor axles if you don't feel like bashing yours up if they're any good, and a big ole hammer. Just hold the DOJ side of the axle (tranny side) in your left hand and hit the CV joint with the hammer. It'll eventually pop it apart and then take the guts outta it. You'll need a 36mm socket for the axle nut, 14mm socket and ratchet for the balljoint on the knuckle, and a drift or also known as a punch that will fit into the hole where the roll pin is on the tranny side DOJ.
WCSS8 Mug Ordering Time
Caboobaroo replied to Subarutex's topic in Meet n' Greet. Your USMB Welcome Center
So if for some reason, I cannot make it, can I still et one? I am planning on coming up but if the RX has some issues before then to make it so I cannot drive, then can I get it shipped to me for extra? -
WCSS8 Registration Page
Caboobaroo replied to Dr. RX's topic in Meet n' Greet. Your USMB Welcome Center
I'm gonna pay at the gate since I dunno if I can make it yet or not... -
Yeah mines black, white and silver.... maybe I'll throw some black primer on it to make it somewhat match:D Gotta show them WRX owners what its all about! Old Skool FTW! -
Here's the scoop, my '89 RX which has a WRX TD04 on it, also has a 3" bellmouth Megan Racing downpipe on it. Since I'm in need of a catback for the time being, I was wondering if the catback from a '96 Impreza 2.2 liter would work? I eally only need the midpipe, not the axleback since i have a muffler I can temporarily throw on it until I get my aftermarket catback. Would this work?
ha, my bad. I totally didn't see that. His board name here is quikRXturbo or something along those lines...
Lookin good Rob! Gonna bring that RX of yours to WCSS8? It would be awesome to have another one there since I'll be in mine hopefully:D
Looks like one form an EA81 car. LUVMYBRAT has one on the front of his '84 Brat http://community.webshots.com/photo/332702224/2045041840067339125iLsTqM Lookin good Keith! I might see about gettin that door trim for you. Are you comin to the Red Rocks meet in a couple weeks? You should bring the RX and pask it next to mine MWAHAHAHA!
I should be there in my RX woohoo! Even though its still 3 different colors:-\ -
A big, long, scary 2000 mile trip.
Caboobaroo replied to SakoTGrimes's topic in Meet n' Greet. Your USMB Welcome Center
you should drive out to Denver and meet all the people out this way:D Or I'll just come back to Oregon for WCSS8:headbang: GO RX GO! -
The TD04 and the VF11 share the same upipe flange.
the car you refer to as the "white sedan" is actually a '87 RX 3-door coupe. His board name is WJM for a reference to search on. Yes, he had dyno numbers and from a consenses that a few other board member's agreed on was from the numbers he was showing for his wheel hp, gave him roughly 230 crank hp. He was running a STi intercooler, stock engine, stock turbo, TWE header and downpipe, 2.5" exhaust, and that was at 15psi with no sort of fuel upgrades from what I can remember.
my '78 Brat is RWD. I dropped a high compression FE EA71 into it and it would smoke the rear tires all day long. Also had the stock s/r 4-speed in there and it never gave me any troubles.
I had a chopped shifter in my Brat. It was cool! I cut off the threads of the shifter where the shift knob screws onto, chopped the rod off where it does the step up to hold the boot in place, then welded the threads back onto the shifter and voila! 5'' gone and worked real smooth:D
2 gen 1 Brats that I'm possibly getting!
Caboobaroo replied to Caboobaroo's topic in Historic Subaru Forum: 50's thru 70's
yeah, the '81 GL which will be getting everything swapped from it to the '80 DL, is getting parted out and it has a black interior in it. Why, whatcha need Mary? -
My 'new' 79 wagon (thanks RavenTBK!)
Caboobaroo replied to DerFahrer's topic in Historic Subaru Forum: 50's thru 70's
its gonna have 68 hp y0! Lookin good! -
you might want to check the 02 sensor located at the mouth of the downpipe, right behind the turbo. Sometimes, if the cats get plugged, it'll end up fouling the 02 sensor
Thanks! It took me a bit to get the plumbing all situated but thanks to a GM car for the reducer between the IC and the TB, it all seemed to work pretty well.
I did get a couple about 2 months ago.... http://community.webshots.com/photo/302403464/2171799040067339125uICvyJ http://community.webshots.com/photo/302403464/2381973490067339125eJPOCR These are the most recent pics I have of it. I also put the one window I have back into it but I need to clean it real bad....:-\ I have also put on some 15" steels instead of the 14's in that pics as well.
