5
Everything posted by Caboobaroo
Man, I know how you feel. But hey, I'm gonna be ordering my subscription this week so hopefully I can get this magazine;)
EJ20g into GL10 Wagon almost done ~EDIT DONE~
Caboobaroo replied to suberdave's topic in Subaru Retrofitting
Dave, where is the VSS on your wagon at? I know you had another post going about that but it was getting kinda sidetracked. I gotta hook up my EBC and my TT here in my RX before I get it on the road and I start rompin on it too hard;) Congrats and I hope to be seeing you at the show. Won't be able to miss me in my black RX;) -
New toy, '89 RX(pics)
Caboobaroo replied to Free Range's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not too shabby. At least it runs compared to when I first got my '89 and mine was also a 4EAT automatic. '89 was the only year you could get an automatic in an RX but it was the 4EAT, not the 3AT. -
Well I've just about finished the deal with moosens with my '79 4wd wagon. Many of you know, this car is the one that got me hardcore into modifying Subarus. I was one of the first, if not THE first to completely put a EA81 front suspension/brakes into it. I made custom control arms that a few have seen in pics if not in person. This was my second Subaru I had, which I got when I traded my first one straight across for it. Rust free but had an engine issue which first thought was a bent pushrod but later turned out to be a thrust bearing knock. Got a bunch of parts from General Disorder waaaaay back in the day of ezboard so it has one minor dent in the driver front door now. Mudrat79 will be picking it up shortly from my parent's house in Oregon. Sad to see her go.... so much time and work into her but its time to downsize the fleet a bit more. Glad to see her going to a good home though. I know Paul will give her the lovin I've been denying since I got my Brat. Goodbye my love but its time for us to part....
NA Spider intake,..
Caboobaroo replied to [HTi]Johnson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I paid $25 bucks for a complete one from a junkyard in Denver. Then I modified it to work with my turbo. -
MUST SEE RARE JUSTY CLUTCH lol
Caboobaroo replied to JustyPimp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so they make a high performance clutch for a Justy, what about an EA82 turbo? I got a stage 2 in my RX which is still brand new since I've never driven it with it in there..... -
but with money and time, it can be made into a high performance car! But right now, I'm sitting at $5,000 into my '89 RX turbo with mods out the wazoo and its still not on the road. Just ran outta time right now. If you put a Weber on it like GD said, it will also increase your throttle response too. You can get cams reground from Delta Cams IIRC but I don't know fi they do NA cams. Those will run about $120 plus your cores but like I said, I know they do turbo cams but I'm unsure about carbed cams.
Gl, Broken turbo should I buy?
Caboobaroo replied to Suzrub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my turbo was pretty shot in my '89 RX so I upgraded to a WRX TD04 turbo. Slight modifying is needed to fit it in but I would also recommend putting in a top mount intercooler from a WRX as well. As for a dual range, you can get a turbo tranny thats a dual range in either a Full Time 4wd (basically AWD) or a part time 4wd so you have 4 hi and 4 lo but also have 2 hi as well. I actually have both. The part time came in the '85 '86 RXs and some of the GL-10 sedans. My part time came from an '85 GL-10 turbosedan. I also have the full time in my RX as well. Only the RXs and some of the 3-door turbo coupes came with the dual range full time tranny. The other option is to swap in a naturally aspirated dual range 5 speed but you'd also have to swap the rear diff as well since it has a different ratio. The turbo's came with 3.70 diffs whereas the NA trannys and rear ends are 3.90 diffs. The main difference between the turbo tranny and the NA tranny is the fact that they have the different diff ratios but also the turbo tranny has a 25 spline DOJ where the NA tranny has a 23 spline. I've heard that a turbo car with the NA tranny and rear end make it really spunky.... -
Nissan 280ZX Turbo Injector Swap *DONE PROOF*
Caboobaroo replied to Steveman09's topic in Subaru Retrofitting
IIRC, the EA81T injectors are the same as EA82T injectors. -
Must-have accessory for my BRAT...
Caboobaroo replied to snoutmeat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I 've been wanting to put a set of those on my RX since I plan on using it for shows.... -
what kind of a FPR are you using and where did you get it from? Maybe I can do a nice injector upgrade in my RX with an AFPR as well. Crank up the boost a bit and see what she can do! -
85 GL voltage issues Please help!!
Caboobaroo replied to suby85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds like an alternator problem. If I were you, I'd pull it out and take it to an autoparts store that will test it for you. They have a tendincy to fail and cause weird symptoms. -
Well first off, that engine thats in there is STOCK. All EA82 cars that were turbo had an MPFI turbo'd engine in them. If you fix it, you might be able to get $500 outta it but that's depending on who's in the market for one. Also, you'll have a lot of headaches if you end up swapping that engine into your '88.
yes, with the turbo engines, they creat much more heat then NA engines do. I would get that fan fixed ASAP cause if it overheats too much, then you'll crack a head or blow a headgasket. Much more expensive and time consuming to fix. There a quite a few board members in your area. Hopefully they can pipe in and possibly help you out a bit.
where is the VSS on an EA82 car anyways? Not to hijack a thread but I need to know so I can hook up my turbo timer.
1988 GL won't turn over...
Caboobaroo replied to 1981k20's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There a small wire connected to the starter toward the back of it which comes from the ignition to engage the starter. You might want to see if you knocked that off. Thats what it sounds like anyways. -
rod knock in the Brat.... ugh!
Caboobaroo replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ok I'll get it home today and pull the plugs and see what it does. I hope its just hydrolocked and not a bad engine cause I don't feel like swapping this engine again. I did it at the beginning of January. -
well if you haven't seen my previous post about it eating coolant in the past couple days, its there. Drove the bugger to work today but was a little sluggish because its been eating coolant and burning it out the exhaust. Parked it and went into work. Came out for lunch to see if I could possibly figure out where it might be getting coolant from like the baseplate gasket on the carb or an intake gasket, went to turn it over and it goes "knock knock knock CLUNK!". So I tried it again a couple hors later and still it has this horrific knocking sound. Kinda sounds like it might be a starter which I hope it is but how could it get a rod knock from sitting in a parking lot? I know its a little low on oil cause it has a bit of an oilpan gasket leak but it made no noise on my 3 miles drive to work this morning. Also, its been around 10* the past few days if that helps any. I made sure to chekc the coolant level before I left for work this morning since it was pretty low. If anything, I got another engine I can swap into it.... I got a spare starter I can try tomorrow if anything.
Plans for the 78 BRAT
Caboobaroo replied to 75subie's topic in Historic Subaru Forum: 50's thru 70's
if you drop that motor in there, you won't even remember the one you pulled out. This is a great upgrade to gen 1 Brats to give them more power. I know that if I ever decide to get another 1600 for my gen 1, it'll have to be the higher compression engine, hands down since I got so used to the power. -
EA81 headgaskets.... yay...
well I went to pick up one of my roomates a couple hours after I got off work and it was smoking even worse then my trip home from work. I was thinking that its probably more likely an intake gasket since I used some cheap ones from Advance when I swapped intakes onto this current engine. Plus, from the amount its smoking, it would have blown a headgasket pretty good and since it doesn't seem to be gurgling into the radiator, leads me to believe that its probably an intake gasket as well. That and I smelled the inside of the radiator and it actually smells more like unburnt fuel. -
you could possibly have a short inside the coils in the starter causing it not to have enough power to turn the car over. I would check the connections on the starter, try it, and if that doesn't work, I'd go get that $5 starter for it and throw that in there.
