5
Everything posted by Caboobaroo
yes, even with lots of air, the most you'd do is blow out a sidewall, or a bead, or blow the valvestem out. Too much pressure plus a tire thats not supposed to take that much plus the addition of the weight which is going to be over the load capacity of the tire equals lots of BOOOOOM!!!!
hey man, clean out your PM box, Its DA FULL!!! It's regarding the y-pipe and DHL;)
Where the heck have you been?!?!?!?!?!?!?!?!?!
Subaru ff-1 In Oregon
Caboobaroo replied to Mirroromega's topic in Historic Subaru Forum: 50's thru 70's
I do believe thats the one! I'll have to ask Andrew since it was before I was into Subarus yet but it sure looks like it! -
well if it is a turbowagon, it should have 3.70 diffs both front and rear BUT you could get a XT6 with a FT tranny which had the 3.90 diffs. So someone might have swapped the tranny and diff from a XT6 OR possibly a non turbo GL-10 maybe?
I smell a new EA82T being built in my garage very shortly;)
mmm pics of it to iroc_z2814@msn.com please. I might know this car from when I still lived in Oregon since there was only one FF-1 that I knew of when I lived there. -
Flooded when hot? '84 Brat
Caboobaroo replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well when I go out and start her up, she runs like a dream. Even my '78 Brat didn't run this good. I was thinkin it was a vapor lock problem but I can smell the gas even before I start cranking it over. I know its not the fuel pump since I can hear it click on and off with the ignition. -
umm, it can't be an '81 wagon with a 1400 unless someone decided they wanted to take a 1400 from a gen 1 stage 1 car and put it into an '81 wagon. The wagon is going to be a gen 2 bodystyle... Oh and I bet you're not as drunk as me!!! I'm the USMB drunken appretice!!! :drunk: :drunk:
After I go for a spin and the Brat gets up to operating temperature, if I park it and leave it for about an hour, maybe less, its realy hard to start. I can tell its flooded and it takes me a couple minutes for her to clear up and get started. I know its getting flooded by the smell of unburned fuel coming into the cabin. Choke is not sticking closed since I have already checked this. What else would cause this to happen?
Lucky Le Coupe post of happiness
Caboobaroo replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Soundin good Paul. I wish I can have kids that will be like that. At least I found me a girl who loves gen 1 Subarus;) -
you think looking at the pics is bad? Try seeing it in action at WCSS6... Now THAT was HOT!!!
you are correct my friend. As far as blocks go, the only differences between and turbo and a nonturbo block is one or two things depending on what nonturbo block you have. The turbo blocks have a PCV coming from the back of the block right next to the bellhousing sticking straight up into the air and also has a hole for the knock sensor. IIRC, the carbed and SPFI engines have no knock sensor but the threaded bung for them should be there I believe. The nonturbo MPFI block has a knock sensor but no PCV and the turbo has the knock sensor AND PCV.
Wagon and Brat Part Interchangeablity
Caboobaroo replied to waimaks's topic in Historic Subaru Forum: 50's thru 70's
basically everything from the firewall forward is the same. Fenders, hoods, front valence, grilles, headlights, wiring, the dash and dash components. The doors, glass except for the windshield, and everything else will not swap. Drivetrain will swap, suspension (front and rear) will though. I've had both sitting side by side ('78 Brat and '79 4wd wagon). -
I think this car might have lived in Albany possibly. I know there was an FF-1 wagon in Albany that disappeared. I'm from Corvallis, lived in Albany and had a couple friends in Scio man. Great score and I'm sooooooo jealous!!! -
What color should wagon wheels be?
Caboobaroo replied to blownbimer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
or go with a carbon fiber color. My friend had an '89 GL sedan with wagon wheels and he painted them this carbon fiber color. It looked sweet. He also did the hood that color since it came off of another vehicle. His sedan was about the same color as your wagon. -
Oil supply line to turbo
Caboobaroo replied to Sister7's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just go down to the nearest autopart store and replace them and save the hassle of them possibly leaking again. I do it whenever I disconnect the brake calipers on the car to same me the worry of getting air bubbles in there. So I would recommend replacing them since they tend to get grooved from the bolt heads -
Cometic discussion, thickness
Caboobaroo replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
:eek: Wow.... just wow...... I'd be all over a set but at that kind of price, I think I feel my wallet burning -
Attn:EA81T people in colorado....
Caboobaroo replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Better let LUVMYBRAT know since he's looking for an engine.... -
I know a few of you guys have been looking for a cherry gen 1 dash for some time now *cough Paul *cough*. I came across this on ebay and it might have been posted awhile ago but I couldn't remember. Anyways check out the link http://cgi.ebay.com/ebaymotors/77-81-Subaru-Brat-Stage-II-Stand-NEW-Dash-Pad-Coverlay_W0QQitemZ8032091020QQcategoryZ40017QQrdZ1QQcmdZViewItem
you just need to swap the heads and depending on what block you have (carbed, SPFI, MPFI) it'll raise the compression ratio which will make the car a bit quicker. Also, swap the intake as well since they differ between the turbo and non turbo MPFI cars.
Will, There's a few of us who are very appreciative of the hard work/ time your taking to figure out all of this. I myself is one of them and since I have a car to drive at the moment, the RX is getting the complete engine buildup done to it. I'm doing it right, taking my time because like its been said before, ANY engine can make a lot of horsepower, it just depends on how much money you're willing to spend. Then after the buildup, comes the time it takes to tune it right. Another reason why these engines go BOOOOOOM is the disrespect of proper tuning. Trust me, I've been reading all about the different parts that can be made to work in these cars and about 95% of them you have discovered.
would be better then the butt end of it bouncing all over the road like its a mexican jumping bean! You have to remember I know what a stiff ride is like in a Brat... I had the one with no suspension at all!
reproduction shift boot for 80-84 2wd 5 speed
Caboobaroo replied to mcbrat's topic in Products for your Subaru
let me ask Bill if he needs a new one for the Brat. I might be sending you some money for it plus the metal ring.
