5
Everything posted by Caboobaroo
Well poop. Looks like Webshots went down and I lost all of my older pictures:mad: Guess I will need to get more but here is one to keep you entertained:clap: More mods are to come, including a fully rebuilt ER27, MegaSquirt 2, ISC coil overs and more. suspension will probably go through round two before the MS2 goes in. Once the MS2 is running good, then I will build the extra engine I have.
I voted for you:popcorn:
In 2004 there was a design change with the valve body and Duty C. Depending on the year the transmission was built (my '04 has a transmission that was originally assembled in '03) the Duty C solenoid went from being serviceable like they all have, to integrated into the valve body. If its the newer style, then the only way to fix it is replace the valve body. I know there was a TSB on this and the sticker on the bellhousing right above the starter will give you the code to determine when it was assembled.
Congrats Qman!
has anyone swapped a ej25 turbo into their ea82 car
Caboobaroo replied to tandm1999's topic in Subaru Retrofitting
Do I get to go for a free drive?:-p I will let you ride along:grin: -
Rear Toe is in on 92 Loyale 2wd wagon?
Caboobaroo replied to 92LoyaleH4's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They were right, it is a major pain in the butt to adjust the back end. Most shops won't to be totally honest and most mechanics don't even know how to adjust the back. I don't align very many EAs but I have also been able to align the back end successfully. Camber sounds normal but it does have a bit of a toe in issue, especially since the front is toe out some. Unless it is a huge difference in ride height, the shocks in the rear aren't going to really effect the alignment. -
I used to have it on my webshots account but somehow it's gone? I have a FSM you could borrow
XT6 manual transmission noise.... Upgrades?
Caboobaroo replied to Caboobaroo's topic in Subaru Retrofitting
Well the engine swap will happen but this will probably be a few years from now (moving this summer, getting married, other projects) and I just went through the engine in it currently. Only complaint is the amount of power but it's currently fairly reliable and I have a spare ER27 in the garage. My other option is to build a beefy NA ER27:clap: -
need opinions on power steering.
Caboobaroo replied to maozebong's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Glad to hear you made it out this way! I have some EA82 power steering parts that will probably make their way into the trash but I have a good pump and possibly some lines and maybe even a rack:headbang: -
ECU still thinks its an automatic (5MT swap)
Caboobaroo replied to Ibreakstuff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nw ant to do it the easy way? I believe the 6 pin connector that plugged into the original automatic shifter needs to have a jumper wire installed. Out of the 6 wires, find the two largest and put a wire to connect them. I then wrapped the jumper wire and the connector with electrical tape to keep the jumper secured. This was on my '87 but I don't see it being that much different. Wires should be Black/Yellow stripe and Black/Red stripe. -
Well from what I've read, putting any other final drive behind a EZ30 besides a 3.70 will make it scream on the freeway. I miss having the RX dual range box in my coupe as it was great behind the EA82 SPFI engine that was in it. I'm also curious as to different gear sets from EJ transmissions and how they bolt into the XT6 case. Also, I'm curious about swapping 5th gear with something a bit taller, again to help with freeway rpms. Oh and I forgot you had that adapter plate:headbang: -
Long story short, my '89 XT6 is starting to whine at high speed once the fluid is warm so it will eventually need a rebuild. It is possible this transmission could stay with either an EG or EZ swap and I'm trying to figure out what would be reasonable. I have a few newer generation Outback, Legacy and Impreza transmissions but only one XT6 box. So, opinions matter, what would you do if you were in my situation and faced with these decisions? One of my biggest peeves is the highway engine rpm as its too high for a 6 cylinder at cruise:dead: it can kill gas mileage...
Portland Oregon - Old Gen meet up
Caboobaroo replied to 92_rugby_subie's topic in Meet n' Greet. Your USMB Welcome Center
Wish I could make it to this as well... -
Swapping 5th gearsets EA FT4wd ~ '05 FOR XT
Caboobaroo replied to Gloyale's topic in Subaru Retrofitting
I might have a phase 2 box from a '99 Outback open and partially apart at work. Not a fozzy gear set but would be a phase 2 box nonetheless... -
When the alternator goes bad it will start and run until the bowl in the carb goes empty. While cranking, the fuel pump is run directly and fills the bowl but once running, it gets power from the alternator.
