5
Everything posted by Caboobaroo
Fix the issue with the check engine light first. The first generation EZ30D have known issues with the throttle position sensor and the harness for it as well. Under easy acceleration, it can feel like a stumble real quick before it gets out of the trouble area. My car used to hesitate right about 2600 RPM in any gear. I installed new front and rear oxygen sensors, new intake air temp sensor, new spark plugs, and a few other things. Once I could graph the TPS voltage line, it showed me the issue. Since I replaced both the TPS and harness, I've had no issues since.
You say you're getting a code? Let me guess, p0519. If that's the case, is the car a manual? If so, I'm willing to bet you have a neutral safety switch going back.
- 10 replies
5spd 4wd dual range swap with auto. starter issue help
Caboobaroo replied to RunsWithMoose's topic in Subaru Retrofitting
The connector that went to the original 3AT shifter needs a jumper wire. It should be a 6 pin connector with two larger wires (black and black/yellow?) that need to be jumped together. I put a jumper wire in with a couple spade terminals and wrapped it up with electrical tape. -
They must go back into the original locations as they're line bored to match the heads. They should have a stamping on the top of them, something like I3, E6, I4, E2 with an arrow pointing toward the front of the engine. The number is what cylinder they go to and the I means intake, E means exhaust for what cam they are matched to.
When you remove the VVT blocks (4 - 10mm bolts), you will see the screen on the inside. It's made of plastic with a mesh screen so be careful. I use a pair of needle nose pliers and grab it by one of the tabs that stick up. Clean it out with brake cleaner, some compressed air and you're ready to go.
I usually take them apart and clean them real well. My local machine shop also does a really nice clean up job on them but that's when the heads are in getting a resurface. If it has variable valve timing (2006 and newer), the blocks that house the solenoids need to be removed from the heads. There are tiny screens inside of them which hold a lot of metal.
Stay away from a fix in a bottle. It can actually lead to plugged radiators, plugged heater cores and more. If it has a bad head gasket, the easiest and best thing to do is replace it. No magic in a bottle solution will help but in fact make it harder on yourself. I've done hundreds of Subaru head gaskets with OEM or SIX Star. I've never been a fan of Fel Pro head gaskets as I've seen too many failures with them.
Need help identifying EA82 blocks/pistons
Caboobaroo replied to subdubscoot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The extra cavity on the back of the turbo block is a crank case breather. My ER27 has the same one. Having run a nonturbo block in an EA82T setup, not ideal to run without. It can cause blow by and other ring/land issues. The piston appears to be a SPFI piston or possibly an EA81 piston. The MPFI pistons had a slight valve relief in them, the carbed had a bit more relief and the turbo has a dish. It's been awhile since I've played with an EA82T as I've moved on to bigger engines. -
This is a common problem on 2000-2004 Legacy and Outback wagons. The center garnish ends up filling with water running down the hatch. You can either put a bead of silicone between the rubber gasket of the window and the top of the garnish. YOU can also pull out the garnish and lay silicone all the way around where the front and back plastic sections of the garnish meet. Check the sockets for melting or corrosion and replace if nessessary. If they are badly melted inside, it can cause some decent electrical gremlins.
Is it leaking from the hose or from the fitting into the radiator? I've had aftermarket Koyo radiators leak from the fitting straight out of the box. I now make sure they're tight before installing. If it's coming from the hose, you might want to replace it with either an aftermarket hose or one from the dealer. Also, I highly am against anything except a factory hose clamp.
Difference Between XT6 And GL DR Clutch
Caboobaroo replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
And according to my local dealer, there's no more XT6 pressure plates left. Luckily I have a few spare XT6 fywheels, discs and pressure plates in my stash :-)
