5
Everything posted by Caboobaroo
Gary I have a C-clamp style spring compressor I got from Matco tools but I have seen the same one from other makers. I will get a pic of it and post it up this week.
Sounds like you partially hydrolocked the engine because the headgaskets failed into the combustion chambers from massive overheating. Those codes are specific cylinder misfire codes and with the hydrolocking, could have done internal damage to the engine. You should pull the plugs, check the condition of them and do a compression and leakdown tests. If it was me, since it has to come out to get the head gaskets replaced, you can check out the internals while its torn down.
Help diagnosing oil leaks ? please :)
Caboobaroo replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its an old Subaru. If it ain't leaking, it ain't running..... I would do a full engine reseal. Yard the engine out and get a gasket set and do the whole thing. Also get a new clutch if it needs of. Also find the source of the coolant leak that is present on the front of the engine, drover side. Probably a waterpump and the 90 degree hose that goes from it to the upper bypass line. Also he a good time to do timing belts and components. -
I usually only replace the rear moons of they're leaking, which is very unlikely. I usually put a dab of gray silicone on the corners of the rubber to prevent them from leaking. As far as axles go, I would only go OEM on these cars as I've seen many new aftermarket axles cause heavy vibrations under accellerating, decellerating, and highway speeds. If your current axle isn't making noise you can still possibly reboot it instead of replace it. Empi axle boots are OEM as well which is what I use. Their boot kits come with grease and bands where others can come with just the boot.
Car had basically a gray RX interior. Looked identical to the RXs I've owned. Car was bright red, no bodykit. Nothing real distinguishing about it but it did have a OEM gl-10 sticker on the hatch. Only thing I can think of if it wasn't an actual gl-10 is maybe it got rear ended and the wrong badge got placed back on it.
OK guys, let me help out a bit. Starting in 2004, Subaru changed the design of the internals of the transmission along with reconfiguring the duty C solenoid. Unfortunately they didn't really get the torque bind issue resolved but instead relocated the solenoid into the valvebody. Start with a flush and see if that helps. I would also try using a better fluid as well.
They did offer a GL-10 3 door coupe but they are fairly rare. Basically a RX had almost all the options the GL-10 had so most people got that. I have seen an '88 GL-10 coupe that was MPFI NA, 4EAT with a LSD.
Ummm why not replace it with a good unit. Even if you get it out and a new slide for it, there's still enough rust in the housing that it will bind back up, sooner then later. Calipers are still a safety item and I would hate to see one lock up or completely fail on someone, especially when you can get a set of loaded calipers for $150 if that.
I think that might actually work on those.
Also check your coolant temp sensor. Not the sending unit for the gauge, the sensor for the computer. They're known to corrode the connector and cause a runnability issue when cold.
Hello from Corvallis OR
Caboobaroo replied to MrGlegacy's topic in Meet n' Greet. Your USMB Welcome Center
I'm originally from Corvallis
