5
Everything posted by Caboobaroo
Might wanna rethink that bucko... Hitachi it is since its a 2 barrel round mouth carb. If it was a single barrel round mouth, it would be a Carter-Weber which, unless you know how they work, can be more hassle then a Hitachi. Now there are people running the Weber (either a 28/32 or a 32/36 on here) or its look alike Holley 5200 which was made by Weber but has smaller barrels (GD and I discovered this after I bought one and compared) but it works better then a 32/36 when put onto an EA71.
Strut rods (was Strut bars)
Caboobaroo replied to Hodaka Rider's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those can be made from stock bars as well, just need to throw it into a lathe, turn it down some more, thenadd some extra thread to the end of it, add a nut and a washer and done! -
so I see what you did on the modifying of the backing plate but I'm curious on how you worked the axle to work with the EJ end that has the lugs on it....
ok who owns the shop on......
Caboobaroo replied to mellow65's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yup and I heard from GLCraigGT that someone in a Mustang one night not too long ago, plowed into the portion of his lot that happens to have his older Subarus like his lifted hatch. Probably totaled 2 or 3 of them unfortunatly... Stupid drivers:mad: -
Well to be honest, I've been into Subarus since the summer of '03 so 4 years of having tons of Subarus, mostly parts cars but most of them ran and such.... Plus I also have/had a bunch of other cars from 2 '88 Camaros to a '76 Triumph:rolleyes:
Bush, chill man. I bought a '89 RX, a black RX, from a junkyard and in the 2 years I owned it, I drove it 100 miles because I blew the engine in it 3 times.... I bought the car for $150 and after 2 years, and 3 engines (plus a 4EAT -> manual swap, complete 5-lug swap, mass amounts of parts like TD04 turbo, Delta cams, and so on), I stripped it of what it was worth and it went back the the scrap yard...... Yes, it is a love/hate relationship but I've owned a good 20 Subarus or so and I'm still going. Don't know why/how though:lol:
Is the little wire that goes from the ignition to the starter connected? I sometimes forget to reconnect it until I try to start it:rolleyes:
how hard is it to change the clutch in.....
Caboobaroo replied to Dustp115's topic in Historic Subaru Forum: 50's thru 70's
its easy! The easiest way to do it is to remove the engine (which sounds like a lot but its not). First off, unbolt the y-pipe from the bottom of the engine. Then remove the radiator and hoses from the front of the engine bay. Then disconnect the 2 heater hoses, throttle cable, disty wires, alternator wires, main engine harness (2 small plugs), clutch cable and pitch stopper. Then unbolt the tranny and engine from one another, unbolt the engine from the crossmember and pull it out. Replace clutch and stuff it back in just the opposite of removal:banana: Fairly simple really, I can have that engine out of there in 20 minutes:headbang: -
87 GL-10 thudding and stuff
Caboobaroo replied to Prospeeder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah GL-10s could come with various drivetrain setups but mostly came with a EA82T under the hood. I have seen a SPFI 2wd 5-speed GL-10 wagon before. Oh and if you need those parts, lemme know... just collecting dust -
EA82 GL Coupe makeover
Caboobaroo replied to deerhunter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What kind of problems are you having? I swapped my '87 GL coupe from a FWD 3AT automatic to a RX manual gearbox. Granted, my backup lights don't work and I had to wire up my diff lock to work as well, plus rewire the RX guage cluster to work properly.... -
Some people just don't know when not to speak. First off Hitachis are a real PITA but Carter-Webers are even more of a pain. A regular Weber like a 32/36 are easy and a great upgrade for our little Subies. On the EA71 however, it needs to be rejetted to something a bit smaller because the EA71 doesn't have quite the fuel consumption as the EA81 which would flood it out. I had this problem on my old EA71 because I had it adjusted up too rich. The same adapter plate used for the EA81 can be used for the EA71 as well. I ran a Holley 5200 (made by Weber) which I rejetted to a 28/32 but it ran a bit richer because I was also running a JDM high compression EA71 which was much quicker then my stock EA71 but it only like to run with Plus in it:rolleyes:
Joining old gen but which way should I go?
Caboobaroo replied to stumpy's topic in Historic Subaru Forum: 50's thru 70's
The headlights (dual or quad) were an option. Duals were standard but you could upgrade to the quad sealed beams. Looks good stumpy! Makes me miss my Brat though:-\ -
I love pics of cars gutted for more awesomeness! I'll add a pic of my car during the 5-lug conversion... Can't wait to see how this thing looks when its done.
Hello from a new Rocky Mountain member
Caboobaroo replied to Matt Monson's topic in Meet n' Greet. Your USMB Welcome Center
Did someone say drunk? IBtheUSMBdrunk:banana: Which is why I'm probably drunk right now, woohoo! -
Adios until spring 08'
Caboobaroo replied to sparkster58's topic in Meet n' Greet. Your USMB Welcome Center
Spark, we'll have to get together sometime soon if I can find some spare time... I got your number! -
I do have a complete passenger side suspension and axle here at my place. Fairly new axle (23 spline) and newer strut (Gabriel IIRC). Come get them out of my garage and you can have them! -
Yup, EA82T FTL.... Especially when I saw Suberdave's EJ20G:slobber: And this post is brought to you by the USMB drunk!
87 Turbowagon being cantankerous
Caboobaroo replied to Hondasucks's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wasn't that boot cracked like 2 years ago dufus? I remember you told me about it a long time ago (right after you moved back to Oregon I think) and how it was cracked. -
STi intercoolers are much bigger then stock WRX ones. This is why they go for so much (roughly $300 or so) because they're an upgrade. As far as benefitting, probably not at this stage in the game.
What I was meaning was the back of the tranny, where the driveshaft for a 4wd rig would come out. I know he know's where it is cause he had a 4wd RX;) -
Get under it and grab the tailshaft housing (or where the driveshaft for a 4wd would come out) and see how much the tranny moves when you wrench it around. It sounds like the tranny mount is shot causing the tranny to hit the tunnel. -
looks like a hunk of metal and rust..... Where the finished results? Kidding... Lookin good man. Mine looked about the same but it was mostly assembled when I put it into my coupe. I also swapped my engine crossmember too so I had the turbo corssmember already for the turbo EJ swap eventually.
Is this an old a subaru??????????
Caboobaroo replied to zyewdall's topic in Historic Subaru Forum: 50's thru 70's
There was an '39 Peugeot on ebay a few days ago. It went for a ton of $$$! Very sweet looking car though:slobber:
