timstiles
Location
San Jose
Vehicles
I Love My Subaru
timstiles's Achievements
Advanced Member (3/11)
10
Thanks for the replies and pics. I can go at it now without worrying about breaking something. Even though I walked into the dealer with the correct part number below it turns out the guy gave me an oring with close to the same part number but ends in '6020'. I wondering if it will even fit. Same parts counter guy that gave me the wrong bulbs for the hvac unit during the same visit.
Went to the dealer today and he sold me all long bulbs. Doh! I wished I would have printed out the part numbers in the url above first. The long ones were the only part numbers on the dealers blowup of the hvac controls. But I put the long bulb in and the fan switch lights up now. I still need to get 1 short bulb. Question on that though, is it possible to rotate the bulb base into a position where it is not making contact on the circuit board? Tim '96 Legacy Wagon with Saabaru 92X Wheels and '97 Legacy GT interior
yup you were right on the money. I went to the picknpull yard today and found 1 lonely 93 Impreza. Sure aren't many Subarus in junkyards around here! Fortunately the car had the same internal fuel pump harness as my 96 legacy. I got that and the harness from the top side. The subaru dealer wanted $62 for the part (6 inches of wire with 2 ring terminals) , the counter guy at picknpull didn't charge me! Got home, put it back together and it fired right up. The Airtex brand fuel pump I got from Carquest is louder than the engine at idle which is already driving me crazy , I think I'm in for a battle getting the store to take it back. 2 quick questions to save new repetitive threads. 1) for the 96 legacy what is the cheapest, easiest and most reliable path to turbodom (i've read 4 forums til my eyes hurt but am probably more confused than when i started) 2) same car has oil leaks, if it's not coming from the front of the engine, valve covers, rear main, oil filter, or separator plate, where else can it leak from ? its burning off the exhaust at the "Y"
The saga continues! It wouldn't start today so I bought a new fuel pump. Installing anything other than the subaru pump is a pain by the way. Got the new pump in, jumped in the drivers seat to fire it up and it has the same d!@@ problem. I found out why but don't know what could have caused it. The pump/sender housing side wiring connector is permanently affixed to the housing. On the bottom side 2 2 wire harnesses plug into it. One goes to the sender , the other to the pump. I noticed the insulation was missing a bit on the black wire going to the fuel pump, not on the pump side but up within the small 2 wire white connector that plugs into the larger white one that passes through the pump/sender housing. I popped that connector out and a good bit of insulation is indeed gone from the black wire. The fuel pump connector is black, melted, and burned looking, it looks the same where it plugs in also. I'll post some pics later when my camera is back from a birthday party. I'm a bit concerned to have found this on the internal tank connectors. Has anyone seen this ?
Ya it is a bit odd. I had my ear right on top of the pump while someone turned the key and cranked it and heard nothing. When I connected it directly to the battery the pump worked. I will probably replace it so I don't have to worry about it. partsamerica.com shows the correct part number as: Carter In Tank Fuel Pump: Part Number: P72193 Fits the following vehicles SUBARU 1993 - 1995 IMPREZA 1992 - 1996 SVX 1991 - 1998 LEGACY INFINITI 1991 - 1994 G20 ISUZU 1991 - 1995 RODEO 1992 - 1993 TROOPER NISSAN 1989 - 1998 240SX 1993 - 1994 MAXIMA 1990 AXXESS
Tested the connector going to the fuel pump and it has +12v for a few seconds with key first on, and +12v when cranking. so the fuel pump wasn't working . I removed the fuel pump and connected it to a battery and it ran, reinstalled in the car and it works fine now. Last year the electric fuel pump for my RV generator stopped working. My father in law whacked it with a hammer and it started working. What is with these tempermental fuel pumps? Best deal in town for a new subaru fuel pump is $99 bucks. If you know where I can get one cheaper let me know! Tim
