Lanky
Everything posted by Lanky
If you're asking who the manufacturer was, I don't know. Looking at the invoice though, it appears it's a remanufactured one anyhow. So, that's probably not the best thing. My cousin helped me replace the driver's side cv axle about a year and a half ago. By "help", I mean I watched him do it, and attempted to assist him when I could. Nothing higgy happened after he was done, but he worked at a Subaru dealership as a mechanic for a few years so I reckon he knew what he was doing. I attempted this repair myself, but I don't have air tools, and I managed to half round the head of the bolt that holds the steering knuckle on, hence why I brought it to the shop instead.
The severity of the shaking doesn't really change much if I'm accelerating or decelerating or whatever. I just don't like getting one problem fixed, only to create 2 new problems that weren't there before. I'll call them on Monday and *************** about it...I'll assume they had one of their "non-experts" do the repair. He/She must have glanced over the section in the FSM that tells them to index the position of all vital parts before removal...We'll see. Thanks for the reply.
Had my passenger side front CV axle replaced today. Now the steering wheel shakes at all speeds, and I have to push the brake pedal almost to the floor to stop the vehicle. Did the mechanic throw off the alignment when he replaced the CV axle assembly??? I'm bringing it back Wednesday to get the passenger side wheel bearings replaced...hopefully they don't try to charge me for a front-end alignment, as it wasn't a problem before I brought it in.... Oh, it's an AWD 97' Subaru Brighton wagon. What do you folks think?
That seems to be the scenario. Unfortunately I'm up in NY right now with all the fun snow and a tiny garage packed full of crap, so looks like I'll just have to suffer through it for a while. I know it's not the valve covers, head gaskets nor the cam seals. All I know for a fact is that it's leaking somewhere that I can't see without removing ************. Which lead me to believe it's the rear main seal or some other seal in that vicinity. I'll try replacing the PCV valve to see if it reduces the flow at all. Thanks to everyone that replied.
I've had a minor oil leak for some time now, but it hasn't been severe enough to worry about. WELL, on a recent drive down to Florida from NY it started leaking pretty substantially to the point where it's dripping down onto the Y pipe and back towards the resonator, etc... Needless to say, it stinks really bad, while leaking steadily enough to require me to replenish the oil level every 2 weeks or so. I've replaced the passenger side rear cam seal, which was leaking slightly, but it didn't really help at all. I'm hoping it's not the rear main seal, but I honestly don't know enough to make an educated guess as to where the major leak is. Any insight is greatly appreciated. 96' Legacy Brighton wagon MTX 1.2L
Removing Wood From Cylinder
Lanky replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's how I got a bunch of metal shavings out of a cylinder...:-\ -
Is there a secret to removing these?
Lanky replied to mykingcrab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I buddy of mine uses that sticker and label remover in an aerosol can. He said it's quite effective. -
No aftermarket AC condensers???
Lanky replied to Lanky's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I guess I answered my own question.... -
Been trying to locate a condenser for my 87' wagon. I think it's probably one of the only things preventing me from having AC. No parts stores carry them. Even checked an AC parthouse. No dice. Dealer item only???
No, it's a male and female connector. They're separated by default. Just plug them together...
On my 87' wagon it's by the drivers side firewall near the windshield washer pump. It's actually a green plug. Pretty easy to find.
I drive my 5 speed 87' wagon to work everyday 60 miles there and back on the highway. I average 80mph on the highway. Mixed with the grocery getting during the week I average 29 mpg. If I did straight highway I'm guessing I'd get 35-38. No special goodies in the engine either.
Can't get starter back together
Got it sorted. Apparently I was temporarily blind and didn't see the 2 phillips head screws on the back of the housing. I almost stripped the head of one of the screws getting it out though. Also, found a good way of getting the armature back in. Take a 3/4 socket and place it over the bearing at the end. The back of the socket is tapered so you can get the brushes around it pretty easily. Then just ease it in slowly and it'll slide past the socket and onto the commutator. Yay! Thanks for the quick replies guys. -
There's one hole in the housing and it's quite small. I don't think there's anyway to get all 4 brushes out of the way to get the armature back in. I've looked around the internet and found some tutorials for rebuilding starter motors, but it seems like they're able to access the brush assembly without cutting ************ apart. -
That sounds good in theory. The problem is that the brush assembly housing is connected to the field magnet housing by 2 thick wires. There's prety much no room for movement short of cutting those 2 wires. I'm thinking I'd just be better off picking up a new/refurbished starter than deal with the hassle of that... Thanks for the suggestion though. -
I took the starter out of my 87' wagon to see if anything was awry in it. I've never disassembled a starter before so I was unaware that the brushes were spring loaded. Is there a special tool I need to keep them out of the way so I can reinstall the armature???
The lights on my 87' wagon are ridiculously bright. The high beams illuminate stuff that's like 1/2 a mile down the road.
That was it! Thank you very much. I don't have stay for 2 hours after work now to get a ride. It doesn't make any sense to me how a fuse that has nothing to do with engine operation would affect the car that way, but whatever...
Initially I had a problem with the starter clicking repeatedly before engaging. At one point it took almost half an hour, combined with me hitting the starter itself with a blunt object, before it would actually start. I stripped back both wires going to the battery and replaced the ends. The negative cable was really nasty and corroded for about 2 inches back from the original connector. So, after replacing the battery connectors, I drove it for 3 or 4 days with no problems starting it. Next, I decided to work on putting a new stereo in it seeing how the stock one only played the latino station as well as producing sound from only one speaker. I stripped every wire and used trial an error to try and find the switched +12v wire with no success. In the process a green wire which must supply constant voltage sparked on some metal in the area of the radio. When I tried to start the car after farting around with the radio wires, the engine would only start, rev up to about 2k rpms, then die out. I tried it a few more times with the same results. Depressing the gas slightly made no difference. I noticed during this time that the fuel pump was constantly cycling on and off. I went on the forums here and figured out the green end diagnostic wire was hooked up, and thusly unplugged it. At this point the engine changed from revving up and dying out to constantly turning over with it trying like heck to start but not quite succeeding. I tried plugging the diagnostic wire back in to the same effect. I've replaced all the spark plugs and wires, replaced the acc. belts and all the other normal maintenance you'd expect to be necessary. I also replaced the radiator due to the original leaking ridiculously. Is it possible messing with the radio wires possibly blew some important sensor involving the fuel pump??? Any suggestions are appreciated. I apologize for the longevity of the post. I just wanted to cover as much as possibly initially. TIA.
