roostema4328
About roostema4328
  • Birthday 07/20/1982
  • Location
    Belgrade, MT
  • Occupation
    mechanic
  • Vehicles
    86 GL wagon/89 RX
roostema4328's Achievements
Advanced Member
Advanced Member (3/11)
11
  1. I need help with a weber carb swap. I live in big sky, mt! Hit me up 406-551-3319
  2. that still makes no sense. It cant be part time if it is not selectable. It would be full time 4wd. It would act like a part time that was locked in 4wd mode if thats what you are trying to say. but that still wouldnt be part time because you wouldnt be able to unlock it.
  3. yes welding the center diff would not make it PT "part time" ? lol It would be 4wd all the time ha ha which could be good in a off road rig.
  4. I ran into problems like this with mine. I just ended up putting in a MT ecu and all was well.
  5. I believe you can change the stubs without cracking the case. I would need to varify this. But back 12 yrs ago when I didnt know much about cars I remember trying to do a cv shaft on a subaru. I didnt realize that there was pins on the axles. I beat both shafts out of the trans without removing the pins the stubs came out with the axles. then I transferred the stubs to the new axles. and put them back in. I remember it ended up working in the end. I would try it again but I havent had a need to change out any stubs. lol I suppose this would be assuming there wasnt a carrier change involved in the stub swap also?
  6. yes. right stuff is the stuff. ha ha. it does alot of ************. ha ha the only major problem with it is the fact that getting the stuff back apart after it has been right stuffed. can be a major chore. ha ha
  7. why not just make a new intake that way you actually could flow the air of a bigger carb. you probably could make a steel intake out of exhaust tubing with a pipe bender and some flanges real easy. I thought about doing that once. and then mounting a holley 650 to it.ha ha. but I realized like everyone else. there is no point because the heads wont flow enough anyway. but you probably could get at least more flow than the stock one.
  8. just ej swap the tracker. lol way easier and better as the trackers have a full frame and a real t-case. you could just use the toyota bellhousing adapter. in this thread. http://www.ultimatesubaru.org/forum/showthread.php?t=111709&highlight=series+trans get a toyota trans and t-case out of the yard. Problem solved.
  9. this is true. and what I thought in the past but a ************ty clutch disc will bake in quick order. lol I have found that on very hard launches with my car the rear end was the weak link. I broke 3 of them. ha ha
  10. the 3 speeds are junk. do not use one they go out frequently with the stock engine. I would use a 6 puck carbon ceramic clutch disc. mine seems to grab very well.
  11. no. and the xt6 pressure plate probably wont hold that kind of power. maybe for a short time I guess. ha ha
  12. just get one of these. thats what I use in my car with 33s ha ha. http://www.walmart.com/ip/Garmin-nuvi-1300LM-4.3-Portable-GPS-with-Lifetime-Map-Updates/15266006
  13. crack open the case and weld up the front diff. ha ha you could do that if you had hubs that could disengage. because obviously you couldnt turn other wise ha ha.
  14. right stuff FTW. make sure to get every spec of oil off the mating surfaces with brake cleaner before you seal it. RTV will not adhere to the aluminum with oil on it. ha ha
  15. probably the only trans he will be able to use with this that may hold up is the EA bellhousinged 4EAT lol.
