poomwah
Everything posted by poomwah
doesn't seem to be any excessive lash in the rockers not sure if this matters, but I just drained the oil and strained it. Couldn't find my strainer or any screen, so I used a t-shirt, boy that was fun, LOL. Anyway, there was a SLIGHT, very slight hint of sparkle in the oil, small enough that it went through the shirt, if you look at the oil at just the right angle, you can sort of see really fine sparkle. It doesn't show up in pictures. A rod bearing would have left more than that in the oil right?
odd thing, not sure if this means anything or not. I got a better stethoscope today. And I noticed that the sound is just as loud on the right head as it is on the block. And with the scope on the front edge of the head right up by the valve cover mating surface, I can hear a metallic kind of timber to the sound, a brighter, almost ringing tone amidst the knocking sound. Is this just bottom end echoing through the head, or is a sign that the problem is inside the head? And I don't know if its just because of acoustics, but, the loudest place for the noise is on the intake manifold. Is that just the bottom end noise echoing through the hollow intake manifold, or is that a sign of something else?
I put about a quart into the recovery bottle. not sure why it was low. It didn't store a code. I'm not sure why, I figured since the light had been on, that even though the light was off, that there should have been a stored code. If it's not stupid cold I'll drain the oil tomorrow and strain it and report back. The belt tensioner isn't bounching. Can the oil pan be pulled while the engine is in the car?
I recently picked up a 99 OBS 2.2 AT 126K timing belt and water pump done at 104K It ran a little rough sometimes, but most of the time it was ok. The check engine light was on when I got it, but went out shortly afterwards. There are no codes stored on the computer. I was driving about 50mph and it started losing power, I was on a busy road with nowhere to pull over, the shoulder was filled with a mountain of plowed snow, so I tried to keep it going until I could get off the road, by the time I got to where I could pull over, I had it floored just to keep it moving. The engine was still quiet at this point. As soon as I let up on the gas, it died. I tried restarting it and it cranked but sputtered and stumbled and would not restart. The temp gauge never went over half (don't know if it's accurate or not), and the heater blew hot air the whole time. The engine compartment smelled really hot. The oil level was good. I added about a quart of coolant. After I let the car sit for about 45 minutes, I tried to start it again. It fires right up, but it sounds like someone is taking a hammer to the engine. I tried moving the car to a better place, a parking lot instead of the side of the road, and it had very little power. After having it hauled home on a flatbed, I pulled the accessory belts, still the same noise. I pulled the timing cover and the noise didn't get any louder. The timing marks are still lined up, and I put a stethoscope on every non moving part under the timing cover, including the bolts on the idlers, Noise isn't coming from there. I pulled spark plug wires one at a time, it changed the idle of course, but that's all. No one plug wire made a difference in the sound other than slowing it down a little. What do you guys think? main bearing?
