thecryoflove
Everything posted by thecryoflove
'90 Loyale AWD Turbo Wagon
thecryoflove replied to thecryoflove's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the tips guys... sounds like replacing the axle is the way to go. Also have another question... this thing is idling super low (about as close to zero as you can get) and usually dies coming out of reverse because of it. On cold mornings it idles higher (about 2000-2500) and settles low so everything is working properly there, but what should I set it to idle to (I'm assuming my Chilton's will have the run down on adjusting it)? Also, last time I worked on my 86 wagon (when I used these forums more) I saw a thread about people's preferred timings. Should I stick with what the book says for my timing or does anybody got some better ideas? Sorry if these are stupid questions, but I've been out of the soob game for a while now =( Also... what should I ask for when I go in for the CV front axle parts? CV front axle? Is that what it's called? =) Sorry guys, I'm no mechanic... just a DIY guy =) -
Ok. So the last Subaru I had was an '86 gl wagon with an EA82 wagon. I recently bought the said vehicle in the title and was stoked about the extra power with the Turbo (still an ea82) engine, but when I talked to my other soob nut friend he cautioned me against the turbo, cuz when it goes out it creates tons of issues. So my question... what should I do to check up on and maintain this engine so I don't have to deal with it when it goes out? Also, I read some threads on replacing CV joints (they sound like they are starting to go out) but a couple said "if it's a turbo, disregard everything I said"... great! My Chilton's for some doesn't have the CV joint info (just the CV boot checkup and replacement). So any advice on where to get some info on the CV joint replacement of this car?
My Overheating, Air Bubbling, '86 GL
Ok... I;ve toasted it. Ever since I've owned it it has had a tick that goes in and out intermittently, but a couple days ago it started rumbling (the engine) like it never has before. Then I parked it for 1 minute while I ran into Hollywood Video and returned to her not starting. She's turning over but it's a high pitched noise and she refuses to start. Does this sound like head gaskets? And if it is my head gaskets, is there any way I can check the heads themselves for warping or cracks, or di I got to take it in for that? -
First off, sorry for the delay, it's been crazy... For me head gaskets aren't an afternoon job =) I did burp it and it belched a lot, they came back (and pretty much instantly...only drove 10 miles before it was gurgling like a SOB)... now also...after letting it sit for a while longer (it's in timeout) it is spiking and jumping on the tacho when i get to about 3000 RPM's... I'm really hating this digi dash... oh, and still overheating is there a standalone thermometer i can install to check temp? -
Hey all. A brief history of the issues of my '86, manual transmission, 1.8 L, ea82, Subaru GL wagon. So I came back to Ellensburg, WA early December (central washington) where my baby was parked for about 3 months. She ran wonderfully for a while. Then came gurgling behind the dash... few weeks later she overheats. Top her off with antifreeze and she still overheats. Change the thermostat... works better, but only for a few hours then overheats again. At this point the overheating is like this... temp climbs steadily and fairly slowly until gets to the red, then maybe back down below (but still high), then back up again, and then evens out at running temp instantly. I (unfortuantely) have a digital dash in this thing so I'm also wondering if maybe it's lying to me. Anyways, I must also mention that at this point she only overheats when the heat is ON!!! 2 seconds after I switch it from hot to cold she evens out instantly temperature wise. So I parked her on an incline and ran her with the radiator cap off and she expelled lots o bubbles!!! FInally after about 45 minutes of burping her I installed a new radiator cap and let her be. Seemingly it fixed the problem (idled for about 45 minutes without budging from running temp). Took her in to town.... overheating and now the hot/cold does not affect anything...she just overheats no matter what. Woke up this morning (burped her yesterday) and some new gurgling behind the dash... I am positive she had all bubbles out of her yesterday. So now... please tell me my head gaskets aren't screwed. Tell me there's an easy fix.... please! I should also mention that when I was burping her the upper radiator hose was, of course, warm. Then when I took her in to town after that (when she overheated) i checked the upper radiator hose and she was cold!!!!
My new old car - '86 GL Wagon - Questions
Hey. It's been a while, but still need your help... OK, so about a week ago I started getting some groaning in the front passenger wheel. I took off the hubcap and the nut in the center (with the codder pin in it...excuse me for lack of part name) was extremely loose, to the point of being able to just flick it to and fro. I hand tightened it down and the groans stopped. Next day groans again... nut loose again. This time I really reef on it (mechanic friend says to give it all, that it isn't in conjunction with the bearings and that he impact wrenches 95% of his) and the groans stop again. Two days later (today), it's groaning like it never groaned before and the nut is not as loose... but noticeably looser than when I tightened it (the groaning is more of a clunking actually, seems to go with the wheel revolutions and gets louder with the clutch in and breaking... also, when passing close by concrete buildings I can hear the echo and it sounds like a compressor giving off short bursts of air pst..pst...pst...pst--- this is when there is no clunking). Also, I can hear some tire rubbing where there has never been tiring rubbing before. Really stumped with this one. So I have two questions: 1) Was it wrong to tighten it with no mercy? Or is it supppose to be super tight? 2) What can cause the nut to keep coming loose? The codder pin has been put back in both times, tho it has been a little loose, didnt think it mattered (figured it worked like a trailer hitch sort of, just to keep it from sliding off in extreme cases) EDIT: Also... I replaced the fuel filter and it was backwards... just curious how much affect this has on fuel system... Thanks!!!!! -
can anyone else see the pictures? i uploaded them on a different computer and now i'm at home and can see them Also GeneralDisorder... how can you be sure I have a feedback carb? There is no computer underneath the the kick panel... what other tell-tale signs are there if I have a feedback carburator? -
Here are some shots of the engine and such... just to preface, I know I have a lot missing out of this car since I compared it to my friends 86 GLSW ea82 he just bought. If you're standing at the front of the car looking at the engine, this is at the upper right corner. If you're standing at the front of the car looking at the engine, this is at the upper left corner... the tube I'm holding is cut just out of the picture, don't know where it's suppose to lead to The dash... don't know why I have the automatic dash and a manual transmission... the tone of the dash is not the same as the rest of the interior either... so I'm thinking it was replaced, rather than the transmission being replaced. Nothing is connected here.... Shot of the engine... I have a lot of missing parts =) -
That was my first reaction... where is a run-through of making the feedback system a non-feedback system? EDIT: Oh yea... I also have adjusted the timing up to 12 from 8. The manual says 8, but there was a lag (accelerated and would hear about about .5 sec worth of whirring before it actually revved) and there is no lag at 12.... would this be a bad idea? -
What do you mean when you say "retrofit the later throttle body injection"? -
I'm sure it's not a fuel injected... it's a carb. As for the catalytic converter... the mechanic told me I had one out, and from the sounds of it I think I do also. Sounds just like the Suzuki I had when the cat was bad on that... really rattley when I get up to about 3000 RPM. -
Carb i believe -
What do you mean the front cat is a different story? As in,don't touch it... or you won't have to remove as much to get at it... Also... does the O2 sensor affect this engine much? Mine is connected, but all the wires are cut! I'm assuming it's a bad sensor... but is it worth replacing? -
Replacing the thermostat will improve overall running condition? Also, I took it in to get the muffler replaced and I've been told I have one bad catalytic converter. Can I just remove it and hollow it out till I can afford a new one? -
Hey all. New to the forums. Was given a '94 Suzuki Sidekick that was not running. Got it running and sold it for $2250, to buy a $380 1986 Subaru GL Wagon. EA82 engine, 5 speed manual. Anyways... it needs some work on it. I got about 16 MPH on the first check (only 104 miles but I was too anxious) and was pretty disappointed. The brakes are really soft, bled them once and no difference though I read you need to do it RR, LF, LR, RF, so I'm gonna do it again (how much of a difference does it really make?). There's a leak in the exhaust...anyways I'm stoked for the cheapness of it. Will be asking more questions and posting pictures tomorrow. Question: As far as a general tune up goes, upon getting a Subaru, what are the first things I need to check/replace?
