The Dude
About The Dude
- Birthday 04/21/1972
Contact Methods
Website URL
http://
Location
South Carolina
Occupation
Job
Vehicles
Forester, Impreza
The Dude's Achievements
Certified Subaru Nut (8/11)
13
I just got off the phone with my local Subaru dealer. I was told valve adjustment is NOT required on my 2006 Forester as it is not listed in the 105,000 service that includes changing the timing belt. My indie shop said "we have never done a valve adjustment on a Subaru." So, is valve adjustment required? Is there Subaru service literature stating that a valve adjustment is required? I want to avoid a burnt valve(s).
My two cents. What does "replaced the timing belt" actually mean? Because if just the timing belt was replaced you could have a problem. Is it reasonable to expect the pulleys and tentioner to go 210,000 miles? I don't think so.
Do you do a lot of "stop and go" driving? I would expect the clutch last over 100,000 miles, but commuting in "stop and go" traffic could account for the worn out clutch, brakes, and suspension. If you want a car to run for as long, and as cheaply, as possible do not buy a turbo. A turbo is just one more thing that can break on a car. Also, you need more expensive hi-test gas to run a turbo. I hope that you were aware that turbo has to be "simmered" after using it.
When I start the Forester for the first time of the day, the power steering cuts off and then back on. This happens about a dozen times right after starting the car. After a couple of minutes of driving, the power steering stays on for the rest of the day. The drive belt seems nice and tight. I don't hear any belt squealing. The fluid level is good. Any thoughts on what might be happening? Thanks.
