The Dude
Everything posted by The Dude
I just got off the phone with my local Subaru dealer. I was told valve adjustment is NOT required on my 2006 Forester as it is not listed in the 105,000 service that includes changing the timing belt. My indie shop said "we have never done a valve adjustment on a Subaru." So, is valve adjustment required? Is there Subaru service literature stating that a valve adjustment is required? I want to avoid a burnt valve(s).
My two cents. What does "replaced the timing belt" actually mean? Because if just the timing belt was replaced you could have a problem. Is it reasonable to expect the pulleys and tentioner to go 210,000 miles? I don't think so.
Do you do a lot of "stop and go" driving? I would expect the clutch last over 100,000 miles, but commuting in "stop and go" traffic could account for the worn out clutch, brakes, and suspension. If you want a car to run for as long, and as cheaply, as possible do not buy a turbo. A turbo is just one more thing that can break on a car. Also, you need more expensive hi-test gas to run a turbo. I hope that you were aware that turbo has to be "simmered" after using it.
When I start the Forester for the first time of the day, the power steering cuts off and then back on. This happens about a dozen times right after starting the car. After a couple of minutes of driving, the power steering stays on for the rest of the day. The drive belt seems nice and tight. I don't hear any belt squealing. The fluid level is good. Any thoughts on what might be happening? Thanks.
My Wife's 2009 Impreza burns oil. Expensive all synthetic 10-20 oil. Subaru's response? Define "normal" as burning one quart of oil every 1,500 miles. I had have good luck with my 1999 and 2006 Foresters. I will say this though, it appears that Subaru has no problem leaving customers twisting in the wind. First the head gasket fubar with the DOHC 2.5 and now this. Five added quarts per 7,500 mile oil change interval is not "normal" in my book. I will wait and see how the CVT holds up before I buy another Subaru.
Time well eventually tell. Does 0-20 oil shorten engine life? Is 0-20 oil just a marginal MPG booster that will reduce your engine's life? Same thing about the CVT. Sure, the CVT "saves" about 0.5 MPG, but what is the life expectancy of the CVT? They are very expensive to replace. I buy Subarus because I want a car that can go 200,000 miles without a lot of expensive repair drama. In fact I would hope to get 300,000 miles from a Subaru with a little luck.
Purchasing a rebuilt engine was one of the worst experiences of my life. The "rebuilt" engine used a quart of oil every 200 miles and soon had a blown head gasket. I had to take the shop to small claims court to get my money back. I bought the engine from the installer. Therefore, I only had to sue the installer and not the rebuilder. The installer was in my state, so it was easy to drag him into small claims court. If you buy a rebuilt engine and it's good, there's no problem. But if you get a bad engine you can probably look forward to a trip to hell. A reputable rebuilder will replace a bad engine, but you're on the hook for all installation and de-installation labor. You are also responsible for all freight charges. And guess what, the replacement engine may be a bad engine as well. Usually you can't get money back if you get a bad engine. Your only remedy is a replacement engine.
When working on the timing components a torque wrench is highly recommended, if not mandatory. The bolt hole that you stripped is speced at only 35 ft lbs. Aluminum threads strip very easily. On the other hand, the crankshaft bolt is speced at 133 ft lbs. Under tightening the crankshaft bolt is fairly common. That creates additional problems. Also, if you are working on a Forester you might want to remove the radiator to gain enough working space. Good luck.
A strange problem with our 2014 MT Impreza with 30,000 miles on the clock. This car burns excessive amounts of motor oil when it is driven for long periods of times at highway speeds (65-70 MPH). Our Impreza used more than 1 quart of oil during a recent 650 mile drive to Miami, FL. When the car is driven around town at 35-45 mph, it uses considerably less oil. Any thoughts on this? Thanks.
