anspaugh777
Location
Lakewood
Vehicles
I Love My Subaru
anspaugh777's Achievements
Member (2/11)
10
Okay....so as of right now it runs BEAUTIFULLY!!! I'm not sure if it will slowly downgrade and get back to what it was (excessive shift shock), or it will stay this way. But here's what I did: 1. Located the TCM and the ECM. 2. Disconnected the circuits to the TCM and the ECM. 3. Under the hood I disconnected the air flow pipes. 4. Disconnected one circuit and one ground wire. 5. Blew on circuits, and tightened ground wire. 6. Reconnected the air flow pipes and tightened them down. 7. Reconnected the TCM and ECM circuits. 8. Put everything back together. 9. Prayed to Jesus. 10. Did the self-diagnostic test to see if the A/T temp light would flash a code. 11. The A/T temp light just flashed normally after self-diagnostic. 12. Drove over 5 miles, fast and slow. And the car shifts perfectly!!! We'll see what happens. Thanks for all of your help everybody! I'll let you know how it goes.
Well, I found a TCU code on my car using the "unique" method. The code was 45. So I looked up in my subscription to AllDATA and it says to check the engine ground terminals to see if they are tight. If not, then it says to tighten them. I just don't know what they mean by engine ground terminals and can't find a diagram as to where they would be.
Okay....so here's what I've done so far. I've taken off the cover underneath the steering column. I can see the TCM and its connectors, which are 2 big ones. I unplugged them and kind of blew off some dirt. But I noticed to green connectors, NOT wires, but end connectors that look like they fit perfectly together. They weren't connected. Should I connect them? Could that be the problem?
