Everything posted by renob123
Just a thought
I'd caution against using it for what you have in mind. The coilpack may be fine underwater, but the ignitor that hooks to it can fail if it gets wet. Mine did on my EJ-swapped Brat, so I put it inside by the ECU. I'm not trying to discourage you, but from what I saw, EJ stuff is not totally waterproof. It could have been a fluke, though. Jacob
EA81 Master Cylinder/Booster Upgrade?
I can't seem to slow my EJ-powered Brat as much as I'd like. I've asked around, and the consensus is that I should do the 5-lug swap, which I know I should do, but I can't finish it before the next rallyx. I've ordered the most aggressive pads I can find, and I'm looking into SS braided lines. The rotors are good, and the system has been recently bled. I've searched pretty extensively, and I can't find anything about master cylinder/booster upgrades for EA81s. It looks like Legacy (and even WRX) parts will fit EA82s, but there's no indication of whether these will fit my Brat. Has anyone had any luck with upgrading this part of the system? Thanks. Jacob
So really... how much?
Oh' date=' head [b']gaskets[/b]. I thought you had something wrong with the actual heads. From looking at your price list, I guess you didn't bother trying to cool the engine:) Also, you don't have any apparatus to affix the engine to the crossmember. I'd add a used Protege fan and STI motor mounts to your list. I could also waste another hour of time at work coming up with more things that nobody thinks of. Jacob
- So really... how much?
Well, like I said, you can substitute time for money, and I wanted it done for the first rallyx of the season, which didn't give me a lot of time. $3,000 is more than necessary. I spent less than that to get it running, but it only lasted 12 hours, threw codes like crazy, and had no exhaust. I could have gone without the 5-speed upgrade too, but I don't know where I would have been stuck when it failed. I could have cut corners all over the place, but I wasn't ok with the alternatives. It also depends on what car you're putting it in. An EA82 with SPFI would cost way less. On my way to work today, I saw a couple Legacies. I didn't see a single Brat. That's why. Jacob- So really... how much?
No hard feelings:) This is kind of a loaded question, since you can substitute time for money and vice versa in most cases. If you're willing to wait a year or two to acquire the parts and put them together, you can do it for cheap. I was not. Also, I find that when a lot of people here estimate a price of something like this, they leave out the cost of the parts they have in their Subaru piles that they used. GD or Qman, for example, could probably do a swap for close to free in that regard. I'm in over $3,000 easily by now, and the total keeps growing. However, I think I spent incredibly little time on it, considering how amateur of a mechanic I am. Jacob- Next ORG RallyX--May 30th
When I was picking the course up, I found an oil filler cap that looked oddly familiar. I stopped that guy, and sure enough, it was his. He must have been hauling rump roast to make that thing fall off:grin: Jacob- "E-code" headlights
Nevermind. When I saw "Loyale", I instantly thought "Brat". Sorry. Jacob- Any ideas on moddin an 87 gl sedan into a rally car?
Almost everything you do to the car will be useless if you can't use it. Plus this is much cheaper than an EJ22 swap: http://www.writerguy.com/primitive/nwrallyschool.htm Jacob- High range 4wd on an 89 Brat
Yeah, I had the same problem. You can't trust the light on the dash that says you're in 4-hi, and it always seemed like there were two "grooves" where the lever could sit. One would make the light come on, and the other would actually engage 4-hi. OP: You've picked the groove that makes the light come on. Try moving the lever up or down a little into a smaller groove. You can barely feel it, but it's there. Jacob- Hillsboro
renob123 replied to Old Pearl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, who would have thought that moving that wire would cause it to die, but you and Andy can throw dirt clods at it and it actually improves the paint? It is a monster, and I think part of the reason it feels like that is because the suspension and brakes aren't nearly where they should be. With some fine tuning, I bet I can make the exhaust hit the brown note at idle. That'll be fun. And to the OP: Yes, I'll be there. Jacob- 88 GL D/R Wagon - Another EJ Swap
I wouldn't buy them because I see the NASCAR logo in the reflection on one of the spokes. Jacob- EJ swap stalls...ideas?
Did you figure this out yet? With the new exhaust on my Brat, I saw that a big cloud of exhaust gas puffs out when it's doing the bobble thing. I noticed it for the first time on my way to work today. It did the bobble. I stopped at a light. Taking off from the light, there was a big cloud of smoke. I assume the ECU is dumping fuel/pulling timing because it thinks something's wrong. The CEL cleared itself, of course. Jacob- Looking for suggestions on 85 BRAT
Perhaps, but you usually do it with a bitter dose of reality:) 2manetoys: I was in a similar situation for a while. One of the upgrades I was most satisfied with was replacing the engine and transmission mounts. Hold off on the transmission mounts in case you do the 5-speed swap, but both pairs can be replaced in less than a day, and they greatly improved my driving experience. At 182k, I'm betting you'll have a similar experience. Jacob- hard to push clutch
Why is that? Does it pinch or get dry or something? Jacob- hard to push clutch
Right. I assumed it was a normal EA82 flywheel, but it can still be ground to XT6 specs. I'd try to get a better idea of what he ground the step to. Jacob- hard to push clutch
Did you have the flywheel turned to XT6 specs or "normal" EA82 specs? Also, did you use an XT6 pressure plate or normal EA82 pressure plate? I had an XT6-spec flywheel and a normal EA82 pressure plate, and I had similar symptoms. It's drivable, but they really should match. Try to find out what step the flywheel was ground to by the "guy". Jacob- Brat Jump Seats
My '85 Brat has threaded holes in the middle of those raised squares. I always assumed that's where the belts bolted. You should make sure there's enough metal behind those squares, though. I'd imagine they're reinforced on mine, but they may not be on yours. Jacob- What model Exhaust is this?
The newest iteration of NA 2.5L engines has an equal-length header. That doesn't look like it, though. If it is equal length, then people at NASIOC say you can put in a resonator to get back the boxer rumble, but they also say there may be fitment issues around the oil pan. You'll have to read up on it. Jacob- how to adjust my speedometer
You're lucky he didn't get you for your badass exhaust too:) Jacob P.S. I'm coming through your area again in about an hour. I'll be in a black '06 STI this time, though, in case you get a wave. No Brat:(- Ignition barrel removal 85 brat.
I don't remember pulling out the spring-tensioned ball thingies when I did mine. To get the actual lock cylinder out, you need to drill out some pot metal. Search under threads started by me. GD gives a decent explanation of it. Jacob- EJ swap, hard start after sitting
Yeah, I read a bunch of stuff in the New Gen forum here about it, and since it's the cheapest fix, I'll take a shot at it. I try to search legacycentral sometimes, but its search system and I don't get along. I'm pretty good at searching for stuff, but that thing seems to return threads that don't have my keywords in it:confused: Jacob- EJ swap, hard start after sitting
I had to replace the throw out bearing, so the Brat's been on jackstands for a week. I'll be driving it at least 600 miles this weekend, so I'll have a better idea then. Maybe I can actually get out the voltmeter when it's not starting and see what the CTS is doing. Jacob- EJ swap stalls...ideas?
I didn't say it happened every time when coasting to a stop. All it takes is to do some engine braking at all to trip the CEL. About 1 to 30 minutes later, if I floor it, it bobbles. If the CEL goes away, I can floor it and everything's great. I'm not arguing, I'm just being clear so that knowledge and information is shared. Jacob- Throw out bearing issues. Recommendations?
Yes, it would DEFINITELY be a weird angle, and if you have big hands, you may need to get some child labor/girlfriend involved. I'm not even sure if it's possible, though. Good luck. I pulled the transmission this week and found that one of the clips had broken. Jacob - So really... how much?
