Everything posted by Love_em_when_there_old
Deleting engine driven radiator fan
Love_em_when_there_old replied to rpiereck's topic in Old Gen.: 80's GL/DL/XT/Loyales...
New Thermostat and EJ22 RAD! -
Thank YOu alot! My brother will take it back for me Friday and i will fix it Saturday morning, For right now im getting him to push start it with his friends pick me up in it then im going to go wire up a fan for the RAd so i can work on the timing. What kind of a wiring problem would just cause the Starter to click? I know the wiring has been very meesy by the battery since i got the car but has never been a problem, i checked all the fusable links and they all looked very good, there is many unconnected connectors but im assuming that was for "optional A/C" Is there a home test method for checking the Starter, i know someone just mentioned it but i dont want to Electricute myself. Could a Frayed power wire to the starter Cause this? Becaus ei know mine is in horrible shape, im getting new terminals and iwres today anyways.
Ive only Seen one other Vintage Subaru in the all the miles i drive, i drive back and forth to Calgary Regularily and ive only seen the 4 door version of my car. Where are all you pre 1990 subaru Guys! Im so lonely (1985 Subaru GL) At pick n pull there is one subaru chaser and thats it, thats all ive seen, the rest are post 1990 Subarus.......The Guy at Centaur Subaru said hes worked there for 7 years and has never seen one being serviced. I bought my GL a block away from there!
I do all sorts of Crazy things in my GL. My best friend lives abouts 60kms away from me and i make that trip regualarily, the GL climbs hills, down hills and its an Awesome Hockey Car! I got to pick n pull often and its a great parts carrier! Ive hauled around engines, transmissions and various car parts in it, without it i lose my life and im missing every second wihtout.
Ive got warranty and everything for the starter, do you think my best/first option is to exchange it for another one? Or is there another, deeper problem. This is what happened from the beginning. Lonaed Car to Friend, He backs up into a light pole and wreck the taillight. He chops the Exhuast. He complains about starting problems. I get the car back. Starts fine for a while and then Grinds like a mofo when trying to start, like the starter is grinding the flywheel. This was just a cheap DD, so if i just stopped and retryed it would start. Then occasionly, the Car would crank by the KEY! even with the bypass switch button thingy. Sometimes it wouldnt start and id leave it for a sec and then it would start. Then one day the Starter just makes a wierd noise and then i just hear the Starter spinning freely. The teeth on the starter were chewed but not bad, the starter spun freely either direction and you could pull it in and out. Replace the Starter, Replace the leaky Rad. Car fires up first TRY! It then dies because it was cold and hadt run for a few days, try to start it again and nothing! The flywheel could not be possibly damaged could it? I cant be push starting my car around in the winter with a NEW starter, mi thought id let you guys know from thre beginning but ill go exchange this starter and see whats up, appreciate all the info up to hear its really helping me alot!
I wired my Fan up to stay on all day long, done and done. So thats why it takes a while to heat up? hmmmmmmmmm -
Im not usful with wiring, but thats a great diagram thanks! So i put the charged battery in, replaced the solenoid and try to start! and CLICK, click clickdy click! SO we try to push start it and VROOOMMM it starts up! Is it possible the brand NEW starter i got is ************? This is really weird...COuld a way to far adavanced distbutor cause this?
Ive had a 1998 Subaru 2.5 Rs 5 speed Transmission laying in my garage for a while now, So if i later planned an EJ22 Swap, What would be need to done to fit that transmission in my car? 1985 Subaru Gl 2 Door Hatchback, EA81, 4 speed, 4wd. Im assuming instead of having 4wd/4lo, it would be full time 4wd/AWD?
I got lucky on E-Bay !!!
Love_em_when_there_old replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oooooooohhhh Fancy! Nice Buy! -
I know the fusible links beside the battery are good, Ill check the drivers side ones. So Basically pushstarting does the same thing as jumping the starter then...I installed an EJ22 Rad and for fitment i had to move the harness but i made shure not to wreck anything, is it possible i broke a ground? Its weird though, it fired right up the first time then just clicked every other time after that, i thought ill diagnose it after we push start it but that wouldnt even work everything electrically works. Ill look into those tihngs and get back to you guys, thanks for the help!
Drive Axle
Love_em_when_there_old replied to Love_em_when_there_old's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just got around to doing this, 6 hours laterrrrrrrrr its done, nothing would come off. So we took of the strut and pulled the assembly away from the Drive axle, god that was a royal PITA!
