Subaru X
About Subaru X
- Birthday 04/15/1982
Contact Methods
Website URL
http://
Yahoo
infinatezero415
Location
Northglenn
Occupation
Automotive industry
Subaru X's Achievements
Advanced Member (3/11)
10
It all depends really. Depends on what gaskets you put in, and how bad of shape the cylinder heads are in. If you buy the gaskets from the dealer they are upgraded gaskets and stronger then the originals. If the heads are warped. I would recomend new cylinder heads. I've heard of others milling the heads and re-using them just to have them be too thin and once again over heat. Some people just replace them once. Others have done it 4 times.
sounds like it might not have been overheated too much. I ran mine for approximately the same as you did. if you are driving it to the dealership then make sure you empty out some of the excessive fluid in the over flow resivour and re-fill the radiator. Should be able to drive about 20-50 miles before anything happens. As for how long it takes before it is really trashed. I'm affraid I have no idea. Maybe someone else can come in on this one.
Well not sure if it is the alarm or not. But I had an issue like that once with a car where it had the alarm but I didn't have the remotes. Try removing the fuse to the alarm system. If it is an aftermarket alarm there should be a fuse inline with the alarm. If it is oem there should be one in the fuse box. Remove the fuse and see if it starts. If it does then it is an alarm issue.
120k before the headgaskets went is awesome. Mine went out at 90k. I'm at 117K now and no signs of issues. I do seriously recomend getting at least the head gasket from the dealership as the felpro gaskets are still of the old design. Subaru upgraded the headgaskets to be stronger. As for the price. Well that depends on who you know. I knew a few mechanics really well at a subaru dealership I had done New timing belt water pump thermostat rocker gaskets head gaskets recored radiator flushed system and a few other things done for 1,500.00 on the nose As for reliability. I complain a lot under my breathe about the cost of sensors and how they go out. But the damn car just keeps going. It's very rare when I see smoke blowing out the exhaust of a subaru. As long as you didn't over heat the car much when the gaskets went, and you can afford every now and then a sensor. I say go for it.
Wow very informative description which helps a lot. Since you did replace your MAF and you were getting codes for your MAF I wouldn't quite rule that one out yet. As for the fuel filter the replacement is very easy. The nice thing about subarus is that the are easy to learn on. There should be a manual for your car by chiltons or haynes. May have to order it online. But it would tell you step by step how to replace your fuel filter. It's actually a really easy task on the subarus...easier then the spark plaugs you replaced. I was having a problem simular to yours on my 2.5. Ended up being a crack on the intake tube. Ended up replacing it all with an aftermarket and that took care of the problem. I would just check out the whole intake. Might have a crack somewhere on the underside, or on one of the vacuum hoses just mucking everything up. I don't think this would be the problem on your car...but could also be an o2 sensor problem. Thats something I am about to replace on my car very soon. It's not triggering the check engine light so it doesn't get a code. But it's telling the ECU that there are holes in the exhaust causing hesitation. I highly doubt this is what you are experiencing though.
Brake problem
Subaru X replied to Eikari's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
lol whenever my brakes squel like that I take a trip to the car wash. Even when I use the silicone on the back of the pads I still squek. So I just pressure wash the car and make sure to get in between the spokes of the wheels to get the brakes clean. Keeps it from squelling for about a week. Which is about how often I wash my car. -
PREACH ON! I got one of my cars painted there before I learned how to paint. 1 week afterwards. CHIPS FLAKING OFF! No primer what so ever which I paid for also. On top of that you have to sign a waiver saying you will not hold them responsible for mechanical damages. I got a flat tire, a blown out throw bearing, and the arm rest on the interior door torn off. I ***************ed at them for so long. I had a 6 month warranty. When I took it back a couple of days later with paint peeling they didn't want to repaint the car. WASTE of money. Few years later...working in a tint shop with a co-worker who was a former maaco employee. Eye opener. They mistreat every car apparently. And if you're an rump roast to them, even more so. They claim to hand sand and primer...apparently you are lucky if you even get the car ran over with a scotch brite pad. To remove dents on the front end they hook up the cars to the chain links in the floor...(like most shops) but unlike most shops they then turn the car on, pop it in reverse, and just floor the sucker with smoking the tires. I will never use maaco again, and I would never recomend it to anyone. I would suggest spray painting your car before you go maaco...sometimes it looks better too.
It's alive! Pics of 80 DL hatch. 56k warning!
Subaru X replied to tscinmd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oh man I would leave that paint job. That paint is so frickin expensive. Would look sweet with some tinted windows and bigger tires. -
I know your pain. I sold my acura and got a legacy. Within 6 months I did even more repairs and more costly ones. (not even going to get into which ones) I often tried to sell the car. And thought about trading it in. But I am too much in over my head to do such a thing. The best thing to do is to take a deep breath..maybe sometimes spit on the car (makes you feel better). But there is some hope after I finally fixed everything the car is just awesome. Plan to get many years of service out of my car. And I imagine you will too especially since it is a forestor. Just be thankful a boyracer didn't own the car before you. I think a girlracer owned my car and thats why I've been having so many issues.
