Everything posted by Numbchux
Strange, I just got digging into the catalog. Yea, one of the rear subframe bolts is different. It's drawn in the LR position. But the bushings are all the same. 🤷♂️
can the engine and transmission come out the top?
Numbchux replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. 4th gens were available with the 2UZ 4.7l. Mine is a 1st gen, though. I have a 4.0 1UZ in it. Install is far from complete, but it runs and drives (no cooling system, so very briefly).
Stock 1988 RX rallycross NWRA
Rallycross is a good time, and depending on the surface and track layout can be a real strain on the cooling system. The last time I raced one was in a fully rally-prepped STi, and I had to drive it down the road 1/4 mile and back to let it cool off after every run.
Numbchux replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know you've already done it. But when I scrap cars, I cut out the radiator support. Then the engine and transmission come out easy. I even made the upper radiator support bolt-in on my 4Runner during the engine swap. I had the V8, 4-speed auto and transfer case in and out of it several times, but left it all as an assembly.
mmmmm......billet
2006 3.0R engine opinions wanted
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood engine. 5EAT is lovely when it works. I think higher failure rate than 4 speeds. Prepare for electrical issues. Rear tailgate harness breakage. Passenger airbag light fails and disables the entire airbag system. Any trouble code disables the cruise.
00 Outback legacy..Anyone know what this part is and if it is replaceable?
Numbchux replied to DarkenLX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's the buffer and a buffer cover Covers are discontinued, but there are still a few buffers in the Subaru of America warehouses, Any Subaru dealer in the US can order them. $15-20 ea
Quickest possible question regarding 2001 3.0 H6
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX😬
Possible EA82 front strut options.
Those Hyundais have an upper control arm. The shock is not designed to support lateral loads.
What's REALLY the best tool for separating a tie rod end from the steering knuckle?
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never needed more than a good hammer on a Subaru. My 8lb mini-maul usually pops it off in one hit. loosen, but do not remove, the bolt. And smack the end of the knuckle where the tie rod goes through it (not the tie rod itself). I rented a tool similar to the one linked for my Suburban, but the hammer-smack still did the brunt of the work.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not hard. 2 bolts for the washer reservoir, one hose clamp for the airbox, loosen the 2 bolts for the pitch stopper, one nut on the motor mount. Floor jack and a piece of wood and the spark plugs are super easy to get to.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for your contribution?
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAirbox and washer reservoir out, pitchstopper loose, remove motor mount nut on one side, lift the engine and it will tilt up. Easy access to spark plugs/compression test.
2024 OB parts list
Numbchux replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use partsouq.com a lot for various manufacturers, occasionally Subaru (I work at a Subaru dealership, so the VAST majority of my Subaru cataloging is licensed software right from Subaru of America), but similarly they don't usually have stuff right up to current years. parts.subaru.com has abridged diagrams for all current US models.
Looking for EA82 head bolts for head gasket job
800211050 and 800211060 are the part numbers in the Subaru Catalog, and is the only part number I see for EA82 cars. (I work in parts at a Subaru dealership). I never did take the heads off an EA82 car, in fact I scrapped many running ones in favor of an EJ22. So I don't claim to know the dimensions. But those are the correct part numbers. They are discontinued. But my parts locator shows Nelson Subaru in Martinsville, VA having 5 of the 060 bolts in stock. If that's accurate, they'd probably be tickled pink to sell them.
"One for each direction" I remember him saying he doesn't want to have to separately fill the aux tank. He'd like to flip a switch while filling the main tank to transfer it up to the aux tank. And then activate the second pump to transfer it in the other direction when needed.
The reason for 14g was the distance more than the amperage. I used 12 ft, it's erring on the side of caution, but probably a good idea. If 5A is peak, not continuous, 16g is probably fine. But you'll start seeing voltage drop, which can be hard on motor contacts/brushes. The cleanest and shortest path from the alternator would help that. I looked up the stuff I used on my 4Runner. I'm using these in different Amperage ratings, but they're available in many variations. Maxi Relay + connector and terminals, here's an 80a version of the relay https://www.waytekwire.com/catalog/relays/mechanical-relays-and-connectors/cit-relay-and-switch-a3k1ccq12vdc1-6-maxi-relay-spdt-80a-12vdc-max-145vdc- Surface mount manual reset breaker https://www.waytekwire.com/catalog/circuit-breakers/high-amp-circuit-breakers/eaton-s-bussmann-series-184080f-01-1-surface-mount I buy a lot from Waytek, or Mouser.
Personally, I don't think I would trust ABS wires. Small gauge, and twisted pairs. Maybe use all 4 rear ABS sensor wires as positives, and then ground to the body Using this calculator, default voltage drop and temperature, 14v, 5a, 12ft run, they recommend 14g. Alternatively, 22 g wire has about a 20% voltage drop.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have not seen anything officially saying one way or the other. But I would also bet interference. Even the 2.2 went interference in '97ish. That said, I see the FSM has a specific note to use caution installing the timing belt on a 2.5, as incorrect timing could cause piston to valve contact, and there is no such note in the 3.0 timing chain section.... I don't think I've seen or known of one break a chain. I've heard timing chain noise several times before due to damaged/worn guides and/or tensioners. Not that it isn't possible, but I'd be highly skeptical that it just broke without making a bunch of noise. What Cam sensor code? P0340 is for cam sensor circuit, indicating a wiring issue or failed sensor, P0341 indicates good signal but out of time. I've had engines attempting to start with bad sensor data sound strange while cranking. If it broke on the highway, the valves are already bent. It'll turn over nicely now. Before you touch those cover bolts, definitely do a compression test. If it fails that, I would drop the exhaust and look up the ports at the valves you can see (IIRC the front valves are hard to see through the single exhaust ports), and then crank it again to see if you can hear the compression blowing out the exhaust. If you have cylinders with no compression, but the offending valve cover and check to see if the buckets move freely and smoothly. While a stuck valve won't prevent a bucket from moving all the way out, there won't be any spring pressure on it. I believe you can see the bank 2 chain through the oil filler cap. Drop the oil into a clean pan and look for debris. Cut open the filter for the same. I would expect to see considerable metal in the oil if the chain has been failing. Maybe even drop the lower pan and look for bigger pieces of debris. I have an 01 H6 with no compression on cylinder 3. It all blows out the exhaust. I removed the valve cover and can move the valve buckets/springs freely with a prybar, resistance and movement feels identical on all 6 exhaust valves on that side (I believe if the valve wasn't closing all the way, the spring/bucket would not return all the way). It will still run, just super rough. I believe it to be a burned valve. And I will almost certainly swap in a used engine before I bother pulling everything apart enough to replace a valve. I have a couple known good high mileage engines. Or maybe try to get a JDM, although those are a lot less common/cheap than they used to be.
EJ swap in GL10, rough running
And it still makes 200psi? Wow. I'm impressed. I'm pretty stumped by this. All 4 cylinders? I was thinking stuck injector, but it would be strange to be all 4. I know you know this, but I'm brainstorming. The injectors are pretty simple. One wire is constant power from the ignition relay. I can't think of a likely failure mode on either side of that that would cause more fueling. But also would require some seriously bunk input information for the ECU to actually command that much fuel. And even then, I would think it would throw a DTC and override to open loop "limp mode". I guess you could unplug the MAF, then you would know it's open loop, and see what that does. But it seems far more likely that it's something mechanical. A leaky or stuck injector, a hose connected incorrectly.
What year engine/wiring/ECU? What transmission does the ECU think it has (I assume it's a manual now)? Correct MAF sensor, IAC, TPS etc.? DTCs? I'm having the thought that hoses might have been switched and excess fuel is ending up in a vacuum line. But if it's getting pressure and running at all, I can't think how. Maybe return line right off the rail to a vacuum source? I'm just thinking out loud at this point. Or maybe temp sensor reading super cold? I know on our 04 EZ30 Outback, when the wires to that got chewed, it defaulted to 40*F. But it was about 10 below that day, so it would not fire. But maybe a short might make it read crazy cold?
Center diff lock swap?
We must not be thinking of the same thing. The dual range main case halves have considerably more machine work than the single range ones. You cannot just lay a dual range input shaft assembly and idler gearset into single range case halves. When I talk about the machining, I'm not talking about the transfer or extension housing. You can put FT4WD/AWD dual range input shaft and idler gear into a PT4WD DR case. But that's not what he has. The OPs question involves using what he has. I'm fairly certain importing a transmission from overseas is not what he's looking for.
Anyone own a Baja and at least one 2000-04 Legacy?
Numbchux replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, several of both. I'm not a fan of the Baja, it's an Outback with less usable space, less weight capacity, and a novelty price premium. But my wife has always loved them, so we have 2. Non turbo Bajas use the single bulb headlight like the Legacy L. Turbos have the Outback/GT 2 bulb set. The exhaust is probably the same to the flange at the rear axle, but muffler is different (rear overhang is longer. Might be able to lengthen Outback muffler assembly to use on a Baja. I haven't looked that closely). Fuel tank is not specific to the Baja, but there are a few different part numbers depending on year and emissions. But a Federal 04 Outback and Federal 04 Baja will have the same tank. There are many things that are interchangeable but different. Dash trim is silver instead of wood grain, but interchangeable. Fenders, doors and front bumper will fit, but is different (I've heard that you can drill mounting holes in the Outback sheet metal and put the Baja cladding on it, but I haven't verified). Rear door glass is specific to body style (Sedan, Wagon, Baja). Outback seats will physically bolt in, but as with swapping between Outbacks, some have side airbags, power adjustment, etc. I think the rear seat will swap, as I remember someone wanting to have 3 seats there instead of 2, and I think they were successful. Most specific things to the Baja are unobtanium. Although I have been seeing more and more 3d printed parts for them. Some of the clips and trim for the bed area.
I'm ASSuming the GL-10 is a manual. If it's an auto, no. Just no, but I don't think there was one marketed as a locking center so I'm assuming manual. The input shaft is different depending on single or dual range. The latter being 2 piece for the extra gearset, and the former being one continuous shaft from the clutch disc through all 6 gears (don't forget reverse). The DR transmission case has a bunch of extra machining for the low range. It looks to me like the casting is the same and theoretically this could be duplicated, but would require some serious machine work. The Output shaft is different depending on FT4WD/AWD or PT4WD/FWD. The former being hollow so the pinion shaft can spin independent of the output shaft, the latter being one piece, pinion and output shaft. So in theory, you have an example of each. BUT (and it's a big one), these 2 transmissions have different ratios, so both would have to be disassembled and parts swapped for it to work. The 1st, Reverse and 2nd drive gear are part of the input shaft. So you would need to be able to put the associated driven gears from the PT4WD output shaft onto the FT4WD, the other 3 gearsets could be used from either, as long as it's a matched set, but 5th is very short in the turbo cars, so I would assume you'd want the non turbo set. I have not seen anyone try to swap them. I do know that all the bearings that those gears ride on are different part numbers between them. I got 98% done assembling an RX box with non turbo low range and 5th gears, EJ 4.444 ring and pinion and AWD center diff. I also wanted to use a Carbonetic clutch type front LSD, but it crashed hard into the low range gears, then the rest of the car didn't pan out.... But the EJ pinion gear does fit the EA82 FT4WD output shaft perfectly and then the EJ center housing bolts to the back of the EA82 front case.
2000 Legacy/Outback driveshaft for AT - unavailable except for more than $600!?
Numbchux replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX90-04 Legacy/Outback with an auto is all interchangeable. Ujoints are staked in, but can be replaced. I've done many. I did a writeup on it years ago: https://www.subaruoutback.org/threads/driveshaft-u-joint-replacement.465866/ And yea, almost every car or crossover on the market with AWD has staked in joints, driveline shops are everywhere and generally very familiar with them.
