Everything posted by Numbchux
Front CV axle length in 2000-2004 wagons
Numbchux replied to portsample's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Should" go in. Experiment with the axle shaft into the inner joint. Occasionally those get pulled apart, and won't line back up correctly.
Fuel still getting in oil...ej swapped brat
There's a "read mode" wire at the ECU. Ground that, and it will flash trouble codes on the check engine light (can be done with a test light at the ECU, as well).
rear diff leak on my 02 Forester :(
Numbchux replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPinion seal is kind of annoying to change, as the nut has a lot of torque on it, so holding it solid while removing requires a fixture of some sort. And, has to be retorqued precisely. I replaced one once with none of the right tools (I think I torqued it with it in the car and the back wheels on ramps), and the diff was noisy forever more after that. That should be either a 4.111 or 4.444 gear ratio. These are stupid common, and pinion oil leaks are rare. You can likely get a used diff for cheap. I've had 4 out in the last year, without too many dramas ('98 Forester, '01 Forester, '97 Impreza that had had the strut tower fail due to rust, and '00 Outback that I was worried about subframe failure, these were all MN cars). The '97 Impreza, I had to pound 1mm undersized sockets onto a couple of the factory bolts to get them to come out, but wasn't too bad a job. Or....you'd be surprised how little oil can leak and leave quite a smear on the outside of the diff. Check the fluid level periodically, and keep driving it. Assuming, of course, you mount your fuel tank somehow, I have not had to deal with failed tank straps, yet.
Physical engine dimensions.
You might contact these guys. Probably the shop that did the most with the EE20s in the US. They were importing and selling them for a few years, but I don't think they do anymore due to the reliability problems. But, they shipped them, and installed them in a couple VW chassis. I bet they have an idea on size. https://www.boxeer.com/pages/contact External dimensions on EJs will all be pretty similar. The displacement doesn't matter, but the head style does. The EJ18 was only a phase 1 SOHC (the smallest, fits nicely in both the EA81 and EA82 engine bay), where an EJ20 could be had in all styles (phase 1 and phase 2, SOHC, DOHC and even with AVCS).
Talk to me about the 2013 oil consumption problem.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is an oil pressure light, just like Subaru has used for 30 years. That is triggered at about 6psi. That's fine at idle, but if you have 6psi while driving down the highway, yea, you're about to have a rod come out. All the FB cars except the first couple years of the Forester have an oil level light, as well. This comes on about at the low mark on the dip stick (pretty early, IMHO). The first time my mom called me and said that her oil light came on on the highway in her 12 Impreza, I freaked. But it's the level light, and she adds about 1/2 qt, and moves on.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep. Most models have a low oil level light, but the early Foresters do not, so it's not uncommon for people to drive them until they don't go anymore.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the ever-present chase for fuel mileage, the rings were left too loose, and they burn oil. The replacement engines will get worse fuel mileage. We had many complaints at the dealership where I worked, as the advisors didn't make this clear enough up front. The lawsuit brought the warranty up to 100k miles, I don't know if there was a time limit on that. Early warranty repair was to replace rings, but then they changed to using brand-new shortblocks, either to reduce labor cost, or problems, or both. Even still, it's no small job, and we saw more than a few comebacks due to oil leaking from the timing cover or cam carriers. Running 5w30 (synthetic, of course) helps. You can use a used engine from newer model with a few small changes. A friend of mine bought a 2011 Forester with a blown engine, not knowing it was an FB. And he ended up getting an engine from a 2015 or so and swapped it in. Sorry, I don't remember all the details, but it wasn't anything major. There must be some documentation on it.
I got into rally when my friend's STi got hail damaged. The insurance check paid for the cage....
Limited slip front?
Yes, have to be AWD to use 4.111 or 4.444 gears.
NEED ADVISE about Class 3 Hitch - 98 Legacy Outback
Numbchux replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, no frame. Unibody means the entire sheet metal body of the car provides the structure. Which is exactly my concern, the commercially-available hitches only attach in a couple spots, and I bet those bolts would just tear through the sheet metal with that kind of weight on it. Which is why I said I would build my own hitch with more pickup points. Some brackets that tie into the bumper mounts, maybe something forward to catch some rear suspension points. Etc.
The diagram makes sense, and actually, I just finished setting up something similar on my Tacoma, which I intend only to use around the yard. As such, I wanted to use a small plastic marine fuel tank, which does not have a return fitting. When the system is disconnected for some reason (or the tank is run low enough to suck air), it gets air into it, which can only escape through the injectors/engine. So it runs very poorly for several minutes, and requires many restarts before it clears up. Your symptoms sound a bit like that. It's not correct, but it should work. It's fantastic news that your return line reads no pressure. But the supply should get a bit more than 30 psi (you did say "about" 30, so maybe it's getting to 36ish), and it should hold pressure for quite awhile once the pump is off. This is held by the pressure regulator and a check valve in the fuel pump. It doesn't explain your fuel in the oil issue, but it might explain the running issue if you're having trouble with the fuel pump. I also installed a low pressure fuel filter between the tank and pump to protect the pump from debris. I skimmed through here and didn't see it. Was it ever determined if there are any trouble codes? It's possible it's been trying to tell you what's wrong the whole time.
Limited slip front?
The major dimensions of the diff (i.e. ring gear size, side bearing size, and the relative location of them) is the same as the EJ 5speed diffs. So anything listed for, say, a WRX will fit in the box. BUT. most are designed for 25 spline axle stubs. This part is relatively easy, "just" have to purchase EA82t axles. The bigger challenge comes with clearance with the low range gears. The low range gears protrude down into the front diff area, so a diff engineered to fit in a WRX case would not have to worry about this. You can kind of see in this picture, on the left, an OEM 5MT front diff, on the right a Carbonetic LSD. Arrow pointing at the shoulder that sticks out just a bit further than the stock casting. + @el_freddo was able to remove some material in that area to get the OBX unit to work. I took some measurements, and believe that in order to clear the 1.59 low range gearset, I would have had to remove too much material from this diff, and would have compromised it. I think it might have been doable with the 1.19 gearset, but never tried it. If you start looking at various different brands and styles of front LSD, you'll see some have more of a curve there, and some are more squared off. So I suspect some would be possible, but I wasn't willing to start buying them just to see.... In the end, this stumble put enough of a delay on my 4.444/1.59/front LSD transmission build that I finished my 4Runner, and realized what real gearing was. And so, the Subaru project sits. Likely never to be finished.
Numbchux replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIIRC, there aren't very good mounts back there for the hitch. I think I would fabricate one with more pick up points for carrying that weight.
Numbchux replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope. AFAIK, Class 2s weren't available until at least 2005 (I know you could get 2" receivers for those, but I'm not sure if they were actually rated any higher). I agree, though. Class 2 is good for 3500 lbs. Shouldn't be towing any more than that.
@Scott in Bellingham with SJR had started a similar project, I think to use a Nissan case behind the 4EAT. He's always got many irons in the fire, so I'm sure he'll come back to it at some point.
2.5 -> 2.0, Now P0170
Numbchux replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll check live data again to see what I can read of that sensor. I don't remember if it's an AF or O2 sensor. Either way it is a new Bosch one. The 2.0 injectors appear to be physically interchangeable (although I haven't disassembled them). This engine was clearly much newer, and had many differences above the block. So no guarantee that the injectors will be 20% smaller.... But, when I get some time, I think I will try to swap them. This car had no engine when I got it. The engine that was in it was pulled to use in a nicer car, so all my components are cobbled from my collection or new. That said, I was very careful to check part numbers on things, and used all new gaskets, plugs, wires, timing components, and more. I have no running issues, and no other codes. If the battery has been disconnected, it usually stalls on the first startup attempt. But once it learns itself for a trip or 2, it starts perfectly.
Should I buy an 04 Subaru Legacy?
Numbchux replied to firehawk89's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPrices are crazy this year. Shop around, that's a premium price, but might not be completely out of line. Inspect it, thoroughly. Low miles on an old car means it's been sitting a lot. If it was in a garage and only driven on nice days, it's probably in fantastic shape, if it was in a field in the summer and driven hard in the winter, it'll be nothing but problems. I have an '01 Forester with 97k on it that I'm rehabilitating, and the rear suspension was rusty like a 200k mile car. I had to replace all the brake lines in the rear, etc. As mentioned, make sure the timing belt has been done, and done correctly. Take a look at the tag on the LH strut tower in the engine bay, it will have the complete engine code. California emissions cars in 2004 had a unique version of the 2.5 that is a bit more trouble to find parts for (especially if you need a complete engine). The California code will start with EJ259, where the others will be EJ251.
01 Forester. Originally a 2.5, replaced with a JDM SOHC 2.0. Install went smoothly (reused many of the 2.5 parts, as per usual), engine runs great, car drives very nicely. Throws a P0170 (fuel mixture rich). Live data reads LTFT -20% or so, which makes sense as I've reduced engine capacity by 20%. I've seen dozens of posts about doing this swap. The dealership I worked at did it many times. I don't recall hearing about a code like this. However, quick google search does turn up a few mentions. I see some using smaller injectors, I might try the ones from the 2.0. Any experiences/insight/recommendations?
Recomendations for an OBD scan tool
Numbchux replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, I don't think you can access any dealer settings with anything that cheap. Any ELM bluetooth dongle (I've bought a couple for ~$15) and an android app can do a lot of diagnostics. ActiveOBD is a subaru-specific app that can read transmission temperature, AWD %, and more on the newer models (was invaluable when diagnosing a torque converter solenoid on my mom's 2012 CVT Impreza).
Would like confidence in using Jack stands under my 2000-04 Legacy
Numbchux replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. I can't agree with these 2 sentences enough.
Numbchux replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour profile says you live in Wisconsin, but then you mention lifting by the rocker panel. I'm guessing your cars are less than....8 years old? Even on our '04, which I removed the rocker molding at 130k miles, the rockers are not safe to support the weight of the car. My 350k mile 2000 doesn't have rockers at all.... Yea, those are nice on a solid car, but if you live in the rust belt, be very careful!
Quick EJ25D crank timing sprocket question
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAFAIK it varies depending on model and emissions equipment (California cars got it first). It was about 2002, or so. Looks like some models switched over as early as 1999, but I know my 01 Forester has the older 6-tooth sprocket. https://parts.subaru.com/p/Subaru_2008_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/Engine-Timing-Crankshaft-Sprocket-U1/49224693/13021AA141.html vs the 6 tooth: https://parts.subaru.com/p/Subaru_2001_Forester-25L-AT-L/Engine-Timing-Crankshaft-Sprocket-1X--C0-U0-UT-EGM-G-EGM-P-U0-C0/49224691/13021AA091.html FYI, EJ25D was '96-'99 and all had the 6 tooth. That LGT has an EJ255, SOHC 2.5s were EJ251s and 253s (and, occasionally, 259s).
Numbchux replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf there's any metal there. The rear jacking points are the first place to get soft, especially if the car has rocker mouldings.
2012 Impreza P2764
Numbchux replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo surprise. But it doesn't need a complete valve body at $800. It just needs one solenoid. I know, I'm a cheapass..... The A and B shift, and torque converter solenoids are all identical should all read between 10-13 ohms. The OEM one that failed read 3 ohms. This aftermarket one..... 0.2 Ohms.... From my research. The torque converter solenoid is by far the most common to fail, despite the fact that the 2 main shift solenoids are identical. So I got a used valve body with less than 100k miles on it that had a failed AWD solenoid. I grabbed one of the shift solenoids, and swapped it for the converter solenoid in my mom's car last night. Code cleared, test drove great. The car has about 190k on it, now. If it lasts another 50k, I'll be happy. If not, I have 2 more used OEM solenoids on that valve body that test good....
2012 Impreza P2764
Numbchux replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI picked up a used valve body just in case the cheap solenoid failed. Well....it threw a P2764 again yesterday. Barely more than 2 months. I wasn't expecting to get another 185k miles like the stock one....but, that was disappointing. I plan to swap in a used solenoid from the other valve body tonight.
