Numbchux
    112
Everything posted by Numbchux
  1. huh...I never got one. although, I'm usually more careful about letting it fill up. lol @ clown picture
  2. :-p just deleted a bunch. I got an email telling me that you tried to pm me though.....I think that's new. Cool!
  3. everything you speak of has been discussed, done, and documented. you're not new here....have a look around. the answers you seek are here.
  4. excuse me. I miss-quoted that. 88 XT says 25 spline shaft. 02 impreza says 24. 04 impreza says 24. 99 legacy says 24. this confuses me, as I was fairly sure that Ej clutch discs would work on an EA. guess I'll have to take an extra EA 4WD disc over to my buddy's place tomorrow and see if it will work on the 04 WRX trans he's got.
  5. only the disc. although that really isn't news. note: I checked an '02 impreza FSM. and the N/A discs are all the same dimensions, EXCEPT they use a 25 spline shaft. Spec has about 6 different available clutch kits for EA82s. I just wish they had max torque listings for them.....
  6. absolutely badass!! I love that rig!
  7. just noticed this post....and pulled out my XT FSM. XT6 = 500kg then compared to a '93-'96 impreza list. and the disc dimensions are 100% identical between a 4WD XT and an AWD EJ (OD x ID x Thickness: 225 x 150 x 3.5. spline OD 25.2, 24 splines.)
  8. glad to hear it!!! have you seen any of the recent pics of your old brat? http://www.ultimatesubaru.org/forum/showthread.php?t=87032&page=2 almost got the lift done.
  9. RockAuto.com they've got an awesome parts listing, and are extremely accurate with parts (haven't found any incorrect listings yet...). I'm running a Beck/Arnley clutch that I got from RockAuto in my car. it's new, not remanufactured, comes with bearings, and alignment tool as well. I've put about 20k hard miles on mine with the EJ22, and it's held up quite well.
  10. hehe, just a little bit. truth be told. You've done some positively awesome work! but yea, a little greedy. I definitely think you'd gain a little power and a lot of reliability if you swapped to a standalone. anyway. not much to report on this. the XT6, and upcoming frozen rotors group buy have soaked up much of my funds lately, and the wagon has been accumulating snow. BUT, Skidd over on RS25 has made progress on his, and given me a massive idea. I was always a bit nervous about running the belt around the radiator hose like reddevil does. but couldn't think of a good way to mount an idler low enough to route the belt under the hose. But he's done it: bolts to the power steering bracket: belt routing. that's some very nice wrap on all the pulleys, and no removing a rad hose to swap blower belts! so I think I'm going to keep my blower mounted flat like reddevil (since I don't have to worry about an ABS pump). but route the belt under the hose like Skidd did. next step in the project, however, is to get some legacy power steering lines. my manhandled EA82 ones will be very much in the way.
  11. yep, I've done the old baseball-bat fender rolling trick. pretty easy, just have to be careful (also better to do in warmer weather to help prevent paint cracking. but careful use of a heat gun can do this too). running the AGXs that stiff on stock springs is definitely working them harder than just regular street driving on stock struts. I've known many people to have great luck with AGXs, but all are running a well-balanced setup with stiffer springs. you're next project is to figure out where it's rubbing. try backing that corner up onto a ramp, or jacking it up from the suspension to compress just the one corner. and see where it touches first. as for the EJ22 swap. short answer, yes, it's quite easy. But there is a ton of other info here about it. no need to hijack this thread to get into it.
  12. that would be true with 02-05 wrx rears. but 06-07 use a 290mm (compared to 266 for wrx and tleg) rear vented rotor and 2pot caliper. definitely an upgrade in every way, and definitely not re-using the old rotors, as they're 24mm smaller! what kind of springs are you running? only on the one side? other signs of blown strut (poor handling, bumpy, etc.....heck, go out and bounce that corner of the car by hand, and see how much it continues to bounce).
  13. oh, good call! I do remember that. Loyale2.7turbo posted it, I believe.....off to search for it. although, I think it was a tercel axle or something, which I don't really think would hold up to oversized tires any better than an r160. as for wheeling worry-free. I've borrowed buddies jeeps, toyotas, nissans, etc. and wheeled them harder than I ever did my soob, without worrying about needing to borrow a trailer to get the rig home. never had that with any of the subarus, and wheeling just isn't fun when you're thinking about who you can call to come rescue a car that doesn't roll/run/turn. I love subarus to death, and had a ton of fun wheeling them, but got tired of being scared about how I was going to get home. I think I made one trip without breaking something mechanical, and that was when my water pump was going out and I could drive it most of the day......
  14. outer splines, as in the ones that slide into the hub. so an EJ axle could not be used with an EA hub. I've never noticed any difference in axle length. swapped all kinds of combinations (FWD N/A 3AT, FWD 3AT turbo, 4WD D/R, 4WD 3AT). granted, I've never measured any of them....so I suppose it's possible.... also, XT6 hub splines are different than EAs. so those don't help.
  15. I'd be willing to bet that it is. since the internals are the same as EJ 5MTs. and I know an EJ 5MT cable pigtail will thread in place of a 6MT VSS.....I would assume that there's something that would fit in an EJ 5MT. I plan on replacing all my gauges will aftermarket ones within the next couple years, and an aftermarket speedo will require a digital VSS....so I've been looking into this a bit. keep us updated on what you find!
  16. you will need to use the inner DOJ cups that match the diff. there's a chance that things will be the right size and you could just mix and match parts and make hybrid axles that will work. or, you might have to get some conversion races from rockford or similar. I'm planning to put an SVX rear LSD into my XT6 this spring...so we'll see how that goes.
  17. in the USRM, on the new servers: http://www.ultimatesubaru.org/forum/showthread.php?t=84798
  18. all EJ series shafts have the same splines on the outer ends (as other EJ shafts), which is quite different to the EA. so yes, newer WRX sedans have longer shafts due to a wider track, but the axles will not work with an EA 4-lug hub. all Ea82 shafts are the same length. I'm with the king here. strut tops are virtually identical (interchangeable anyway) between EA82 and EJ. so you can get camber plates for a liberty/impreza and put them in your RX, although you may have to drill 3 new holes to get them oriented correctly.
  19. I've never heard of anyone doing a solid axle without a tcase (not saying it can't be done, but your comment that you know it's been done is not entirely true). also, I think you'll be hard-pressed to stuff a solid axle under there with enough room for suspension workings and such with only a 4" lift. maybe relocate the fuel tank? and yea, once I dropped the diff enough, I didn't break any rear axles on the trail (had more problems with fronts, and even then, 95% of my broken axles were on the road, mostly from torn boots/dirt in the joint). not saying it's a bad idea, or it won't work, just that it might not solve the problem (which might not exist in the first place).
  20. yep, the VW guys do it all the time. helped a local guy take 1.5" off the bottom of an EJ22 pan to put in a vanagon.
  21. I'm N/A...but I've been running sans pitch stopper for 40k+ miles. stock mounts (280k+ on them) are still in one piece. although, when I upgrade things this spring, Group Ns are on the list.
  22. the diff in a subaru trans cannot be flipped. even with a custom ring/pinion. just no room for it. I also don't think the engine could be made to run backwards without a ton of work. cams reground, oil/water pumps redesigned. ECU reprogrammed. I think your best bet for 4WD, is a VW-subaru adapter plate, with a Synchro vanagon 4WD drivetrain in there. would be rear engined...but close. I think running a driveshaft under the suspension components would be a nightmare. really wouldn't be much room.
  23. the clutch plate might not be aligned. might try loosening the pressure plate bolts and re-aligning the clutch (with a real-live alignment tool) before re-torquing. the input shaft only slides about 1/2" into the pilot bearing. so my immediate reaction (having done many of these) is that that's not lined up. it can be an enormous ***************, as they have to be perfectly aligned (not just in the right place, but if the engine or tranny is angled a bit, it can hang up). sometimes it helps to put a bit of grease on the input shaft. then, put a jack under the front of the tranny to get it high enough so things will line up without the engine mounts hitting the crossmember. get the engine lined up, and you'll probably have to shake and wriggle things a bit. and yea, turn the crank a bit to help the splines line up. you may have to use the bolts to help a bit (don't use them to pull things in, you could strip the threads. but put them in finger tight, then rock the engine back and forth to get it to seat better, tighten a bit more by hand, etc.). it's an extremely snug fit, so it'll take some coaxing.
