100
Everything posted by Numbchux
XT6 Rear backplate/caliper mount dimensions please .
Numbchux replied to discopotato03's topic in Subaru Retrofitting
look what I found! pics of the backing plates right after I sand blasted them! the other side of the XT6 plate: the trailing arms, XT6 plates, EA82t plates with and without dust sheilds: -
glad it was helpful. don't mind GeneralDisorder......he's a little surly. and tends to get right to the point.... anyway, I'm sure it could be done. but I think the amount of custom fabrication and research that would be required would wasted since it would be a huge step down in power and mileage. as far as making it look original. here's my engine bay. '92 legacy EJ22 in a '92 Loyale:
oops....sorry, all the recent 5-lug talk has gotten me confused
yea, the concept is a good idea.....but the execution would be a nightmare. you couldn't just slap the EA82 disty on the EJ22. as they're very different. and the crank angle sensor for the EA82 is in the disty, so you'll have to replicate that signal for the EA82 computer. not to mention the displacement increase......could the EA82 computer/injector compensate for the extra .4l of air being pulled in? if you're worried about the wiring part of the swap (which, I can understand why......not everyone gets wiring diagrams. some of my most respected subaru friends won't wire their own swaps), there are a number of people who can do it for you.
Which is the Better Offroader
Numbchux replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
^ EA82s are already extremely rare here in MN. and I haven't seen an EA81 (except the ones whose owners I know) in years. in fact, first gen legacies are already all rotting away. good news there is that EJ-swap donors are a dime a dozen! if only there were any EA cars worth swapping (my buddy has been looking to copy my wagon for almost 6 months, and we haven't found anything) -
New Subaru Commercial With Brat
Numbchux replied to Durania's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a good friend of mine from the Twin Cities is working with the company who is in charge of the Subaru advertising campaign. I haven't see anything yet, but he contacted me a few weeks ago looking for a subaru with over 300k miles on it to feature in a new ad. And he was really hoping to find an EA-series car. unfortunately both things were hard to find here in MN. So I'm not sure what they ended up with. -
L Cable Calipers on Legacy Knuckles/Rotors/Brackets ?
Fair enough. it really wasn't as bad as I was anticipating. Still seems easier than trying to mount L front calipers to EJ knuckles. the RS brakes aren't much heavier than standard legacy/liberty hardware. I wish I'd weighed it all while I had it apart, but I did compare them, and didn't notice a difference. And I'm pretty sure the calipers with the ebrake mechanism are heavier. one of these days I'm going to disassemble all the different setups in my shed and compare things. I definitely agree that the light car doesn't need much, and the 294mm WRX hardware is definitely overkill. but the 276mm RS stuff is very nice. Also, the SX calipers I'm using actually came off an S12......so that might make things more difficult your end. BUT, as far as I can tell, B14 200SXs (aka sentra or sunny) rear calipers would work as well.... Anyway, up to you. but it sure seems like mounting L calipers to EJ knuckles is not the ideal solution. EDIT: just looked on wikipedia. looks like the S12 is badged as the gazelle there in Australia. maybe more common then S14/15 parts? -
^huh? were you responding to my question? mounting nissan rear calipers isn't any harder than the RX ones you're planning on using. in fact, it'd be exactly the same except with different calipers. you'd still be using RX pads, and whatever rotors you want. AND, by not trying to use the L front calipers, you can use EJ-series front brakes. which are WAAAAYYYYYYY more common. especially performance options. I've been running a 5-lug setup with 200SX rear calipers, rear ebrake, and RS front brakes for about 8 months now, and more than 10k miles. replace the XT6 backing plates and rotors with custom plates and liberty rotors, and you wouldn't need any more rare and/or custom parts than you already have. -
I'm curious why you want so badly to have the front ebrake. I'm sure you can get your hands on some nissan 200/240SX rear calipers, which are almost a direct swap onto EA82t caliper brackets. and then you can run the much better new-gen subaru front brakes. I absolutely love my RS front brakes with 200SX rear calipers and XT6 rotors in the rear. lots of power, very well balanced, using stock EA82 FWD wagon proportioning valve. -
EA81, hands down. tougher, simpler motor. the torsion bar allows substantially more travel in the back (and simpler to lift!). the downfall is the axles. BUT, all EA81s use dual DOJ rear axles. Swap some EA82 inner rear DOJs on both ends of the EA81 shafts, and you've got some pretty good travel (although, the torsion bar + longer shocks means you'll still have more travel than the axles can take.....limiting straps would probably still be a good idea). also, the 3 bolts on the leading rod/tranny xmember bracket are further apart. this was the main downfall on both my EA82s, was those captive nuts pulling out, and the EA81s have more leverage on the frame rail. And the body styles are superior. The wagons, sedans and coupes are pretty comparable.....no preference here. but the Brat is just awesome, and the short wheelbase and non-existent rear overhang of the hatch are unbeatable! -
been discussed. been tried. They're made of much thinner/weaker metal than a normal wheel and will bend muuuuch easier.
the "cherry bomb" glasspacks usually sound like crap. but a nice Thrush glasspack. sounds pretty decent in place of the stock muffler.
hmmm.....looks like someone gave up http://portland.craigslist.org/clk/car/649763065.html
There are many different ways to assemble a 5-lug swap. so you'll have to do some research, and see which works best for you (which parts are most easily accessible). here's the original list: http://www.ultimatesubaru.org/forum/showthread.php?t=50400 there are some updated lists with pictures and stuff around as well, but that'll give you a pretty good start. The problem with the EA81 swap is the front suspension. the rear end works exactly the same as the EA82 as far as the hubs and brakes are concerned. But the EA81 front track is narrower. and the difference is in the engine crossmember. So, all 5-lug axles will be too long......so you'll need to have some custom axles made. Someone else will have to chime in with the details, but I'm fairly sure that you can't use XT6 control arms on an EA81 either, so you'll need to ream out the ball joint hole on the EA81 arms, or make a sleeve to put the EA ball joint in your ER/EJ knuckles like discopotato did. S'ko did it (as I'm sure you'll see in the post he linked) by putting an EA82 engine crossmember under his brat. but the lift blocks were a crucial part of that.....pretty hard to do it at stock height. also, look for posts by rguyver, he did it in his Brat. But then again......he's an amazingly skilled fabricator :slobber:
What axles for a Dual Range into a Legacy
Numbchux replied to Scott in Bellingham's topic in Subaru Retrofitting
SOA part number: 28021AA501 FWD 5MT Imprezas (all 1.8l) with manufacture date between 11/92 and 7/94. -
^ negative. both are adjustable. I just uploaded this page from an '88 XT FSM for my buddy who's brat has some crazy rear camber issues.
Debate: mpfi vs carbi in ej'ed older vehicles
Numbchux replied to Yo'J's topic in Old Gen.: 80's GL/DL/XT/Loyales...
huh, never seen that page.....never looked. So I just looked at the same page in the '92 legacy FSM. the EJ22e pump puts out 36.3psi and 80l/h, and the EJ22t gets 43.4 at 150l/hr. so yea, SPFI pump is plenty pressure for either. but might not be enough volume for the turbo (although I know a guy who's running a mildly modded tleg on an N/A pump). In fact, I wonder if the MPFI pump is substantially too much, pushing 60+ psi might be hard on the pressure regulator. -
you can't, which is what's limiting the travel. you need to unbolt the shock from the trailing arm.
EJ Engine and Transmission into a RX
Numbchux replied to [HTi]Johnson's topic in Subaru Retrofitting
the RX axles will work fine with the EJ trans. linkage needs to be modified. tranny mounts are different. either custom crossmember, or XT6 front and rear crossmembers with EJ center section. driveshaft needs to be adjusted 55mm (pretty sure it needs to be longer....but I could be wrong). rear diff......depends what trans you're using. if it's a 3.90 trans, just get a 3.90 EA rear diff. otherwise you'll need to use the EJ rear diff. physically mounting it is easy, as all r160 mounts are the same. but you'll run into some axle challenges, as there are a few different kinds of axles. first gen legacies (maybe others) use 23-spline stubs that are compatible with EA DOJ cups. otherwise, you maybe be looking at hybrid axles.....possibly custom races. -
well, search anyway. an EJ swap is no small undertaking. and will require a lot of research. 105 was the half price special.....again, search. there are a few people that offer them. I have 2 mrose ones (no longer available), and I've got 2 buddies that just bought SJR ones. which are very well made.
nope. SPFI and MPFI pumps are the same. it's the carbed EA82 ones that don't put out enough pressure. which wasn't the point being made, he was talking about using the EA82 SPFI system to control the EJ22. -
not unless you've done a 5-lug swap and are using EJ-series knuckles.
assuming you're talking about an EA82 in your profile. stock replacement......GR2s are nice. when I was looking locally, the Monroe's were cheapest. it's only the EA81s that can use longer rear shocks because they use a torsion bar instead of a spring.
you'll probably have to unbolt the shock from the trailing arm, and pull the suspension arm down to give yourself some more room.
if pug alloys don't offer the performance gains (minimal, at best). anything better is pointless because you still have crappy suspension and crappy brakes. a 5-lug swap with some subaru steelies is going to yield much more significant performance gains than any wheel you can throw on 4-lug hubs. $600 a wheel is stupid when you're still running 242mm single piston front brakes with 226mm single piston rears. and the best shock/strut combo you can use are GR2s. if you're really looking for performance gains, the only reason to stay 4-lug is for AutoX class reasons, in which case, you can't upgrade wheel size anyway. Look at WJM's RX (well.....when he was racing the RX or Wagon). he was racing on subaru 13" alloys. and yes, MOST 6-lug wheels are much heavier than a pug. I don't know about the cadillac, but vipers weigh as much as a small truck (if not more)......those are going to be some extremely hefty wheels. not to mention the fact that they're 10"+ wide.
