94
Everything posted by Numbchux
1990 LOYALE Timing Belt Broke, low on oil
Numbchux replied to mmcclain's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a pile of timing belt covers in my shed (most of them are broken because they didn't come off like they should). The only time I've been left on the side of the road since, is when that idler pulley imploded, and I didn't have a spare. but I always carry a few basic tools (don't need much, a 22mm for the crank pulley, a 12mm and a short extension for the tensioners/rad fan, and a 10mm to turn the cam pulleys.), and a spare set, and if a timing belt breaks, I'm a little (not even alot) late for wherever I'm going....with the covers on...call AAA here's what an old idler pulley can do: -
not sure what you're asking. you want to do a 5-lug swap on your XT, and want to use this XT6 as the donor? the rear end stuff has to come off an XT6 (well...except the caliper..). newer stuff is completely different. the backing plate, and rotor should work. but at the very least you'll need a FWD XT6 hub. and the backing plate will need to be modified....and the rotor may not even work... pretty much the only piece that will 100% work, is the front end stuff. and the only thing from the front that has to be from an XT6 are the control arms
if you're in there to replace the timing belts. make sure you replace the tensioner AND IDLER pulleys. I bought an EA82 wagon last spring, the previous owner assured me that he had just replaced the belts and pulleys. on the way home, the idler seized, and took the drivers side timing belt with it.....slap on the towing charge to get it home, and suddenly it wasn't such a good deal I would also highly recommend replacing the seals in the oil pump. aswell as the ones behind the cam pulleys. maybe even the main seal, and water pump too. depending on how ambitious you are. -
pic request: EA82 underside
Numbchux replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I guess not....it'll look a little different, but it's the same idea....why? you got one? if you've got a high res version, you can just email it to me: numbchux (at) gmail.com -
I don't understand how it could matter. if you're not dropping the carrier bearing down that far anyway, you're going to toast those u-joints backing out of the driveway. I'd go one-peice or junkyard. wouldn't even consider a new bearing.
no, if you leave all the accessories on the engine with the swap, everything will work fine.. otherwise, you'll need to change the waterpump pulley (maybe the whole pump too...I'm not sure) and crank pulley
81 Subaru DL conversion to fuel injection...
Numbchux replied to Alexx's topic in Subaru Retrofitting
nice. then the SPFI conversion is for you! -
oh...sorry! if your car has a 1.8l, it would be an EA81 (although in '81 I beleive it could be an EA71, which was a 1.6l). they didn't start making EA82s until '85, and never in the hatchbacks or brats. the EJ22 is a MPFI 2.2l motor out of an early legacy. and is ideal for a swap. at least as reliable as an EA motor, but far more power. -
I'm going to photoshop together a pic of what I'm thinking of doing for an exhaust system. but need a pic of the underside of an EA82. could be on it's side, but prefferably on a hoist. and it would be really sweet if it was EJ22 swapped!! but I think that might be asking too much...
yes. mostly on EA82s. but you certainly won't be a pioneer on the EA81. the growing trend seems to be going to an EJ22....but if that's not your cup of tea....SPFI is awesome. -
wrong. the carbs are far more unpredictable/unreliable. my '85 carbed EA82 wagon got 25-28mpg when I bought it. and by the time I junked it, was lucky to see 20. and I did nothing but replace sensors, vacuum lines, etc. on that thing. and it never ran right. my buddy's '86 carbed 4WD EA82....get's almost 40 and he does nothing but beat the hell out of it all 3 of my SPFI wagons, lifted or otherwise, would get 25-30mpg depending on driving conditions (2 lifted, the other 3AT). and I continue to get that in the loyale with the EJ22 and FT4WD if I'm gentle on the happy pedal. SPFI WILL help your current motor run better and more efficiently. and if you continue to drive it the same as you are now, and everything from the swap works, you will see an improvement. Comparing one carbed car with one maintenence history, and one driver, to a FI car with a completely different history/driver, is completely inconclusive. the difference will mostly be in power, TORQUE, and driveability, but also mileage. -
probably. what years are they? are they both turbo?
I'm going to miss my wagon
I don't look at it as an investment at all! That's why I'm so shocked that I 'made' money on this deal. keep in mind, that figure was calculated without the many hundreds of hours of blood, sweat, and tears that went into building it. but I think you're right. I've had alot of fun with it, but it really is time to move on. part of it is the fact that I've never sold a car. I've had 4 EA82 wagons, parted one out, and gave another away (which I knew from day one wouldn't be around for more than 6 months or so anyway...). a year ago I was saying that I'd keep this thing forever.... -
now that my lifted wagon has 'sold' (I meet the guy next saturday morning to finalize the deal...), I've been doing some thinking. first, it started with the though of how much I spent on the rig. well, origionally....$150. lift, pugs, and tires: $500 maintenence stuff (couple sets of timing belts, oil pump reseal, new aftermarket electric fan, etc. etc.): ~$300 tube bumpers, skidplate: $350 (came with the black wagon when I bought it for $350, and I kept them before giving the wagon to my buddy for his birthday last summer) a few junkyard axles, and a couple reman'd ones: $100 then we get into major mechanical stuff... much better cared-for, lower mileage EA82 SPFI engine, came out of the loyale, which served for years before I got my hands on it, and am still driving it....so that motor didn't really cost much. and the motor that replaced it came out of my mom's old legacy, which was replaced with a much better legacy for $350 from ebay. almost all of which was made back in parting out the old one. not to mention the 5-lug stuff I saved. lower mileage D/R tranny out of my old '85. the car cost $700, but served as an awesome daily driver for a year and a half, AND all the 5-speed, 4WD conversion stuff that I used on my loyale came off of it. so that cost is pretty much zero. approximate total build cost (equipped as I'm selling it): $1400 sold for: $1600 worth it? still not sure. but I just keep telling myself that I'd pretty much reached the maximum performance capacity for my budget and patience on that car. and it's replacement will be much better suited to my needs.... and no, I'm still not going to reveal the replacement
axles for dual/range in legacy
Numbchux replied to Scott in Bellingham's topic in Subaru Retrofitting
FWD impreza axles will work. I pulled a pair from our local junkyard for Austin while he was out here, and tested them on my collection of trannies. worked find on a PT4WD D/R tranny, not on the FT4WD D/R tranny, or on the EJ AWD tranny, or on the legacy FWD tranny. it has to be out of a FWD impreza. or...yea...I'm pretty sure you could put the EA inner DOJ cups on the legacy shafts... -
haha, a BFG A/T is a good tread? what are you doing? there isn't anything that you can do with those tires, that you can't do with your average el-cheapo all-season (and the all-seasons will get better traction in the winter!). truth is, you've got almost zero options, beyond a nice snow or all-season tire. tirerack.com (huge selection in my experience), only shows 9 different tires available in that size. there's one type of blizzak studless snow tire...and the rest are all-seasons. in fact, it's hard to find stuff with decent tread that fits on an old subaru WITH a lift!
like my uncle says, "if you need to put a naked woman on your mudflaps....you obviously have never seen one in person"
truthfully...not here....most of the stuff on this board is geared towards the older cars. http://www.rs25.com is a good source and so is http://www.nasioc.com I would also find a local club, and see if they have any meets, go and talk to some local people. I've learned more in 20 minutes hanging with the local guys here, than I have in much of my time here on the boards.... Cobb makes good stuff, and almost anything you can imagine...but they want $$$
I like the wing....not so much on the 04 ones...but I do still like it....but I'm wierd that way. anyway, yea, anything can be done. the glory of subarus, is all of them have virtually the exact same design for virtually everything. it'll have an EJ253, the same as a 2.5 RS of the same years, suspension is similar, if not identical to imprezas, ditto tranny.... it just has a different body on it, and longer struts.
Loyale Front Little Lifting!
Numbchux replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yep, and until you find a way to run dual DOJs on the front....that's completely irrelevant :-p- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
ECU doesn't control the fans anymore....
I think an inch and a half would be about as far as you could safely go. just make sure they maintain the stock camber- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
02 wrx complete drivetrain in 98 outback
Numbchux replied to STRANGELUCK65's topic in Subaru Retrofitting
yep. just don't have anything for ya. try your local subaru dealership. they might let you photocopy a few pages out of the FSM. -
I don't know. it never did it before, but I just checked the codes a couple days ago, and one of them was #12....starter relay/circuit. I don't think I have the throttle cable adjusted quite right...so floor it on the pedal might not be quite WOT....and therefore might not be flood mode... noah. good call on the temp sensor. IIRC, when I was hooking everything up, I hooked up the wrong temp sensor to my gauge cluster. I wonder if I ever got it hooked back up to the ECU...I'll check that
yea, it is a manual. and I do have the habit of leaving it in gear.... it'll be awhile before I can afford it, though...so maybe I'll start practicing leaving it in neutral with the handbrake on.
