94
Everything posted by Numbchux
I've been thinking about putting a remote start system on my wagon. but am not exactly sure what all would be involved, and how easy it would be to wire into an EA82/EJ22 harness. I suppose the engine stuff would be pretty easy, just 2 wires, one for main relay, one for starter....but I'm not sure.... It's just too cold up here, and the darn thing cools itself far too well (more proof, that a stock EA82 radiator is more than enough to cool the EJ22), the temp gauge doesn't even come alive by the time I get to school. and I hate putting all those miles on it with it so drastically under operating temp.
my loyale just hates starting when it's cold. plenty of power from the starter/battery. but it jst doesn't want to fire for a good 10 seconds or so. sometimes I have to floor it to get it to run. but once it does finally start, it hesitates for a second, and then comes up to idle, perfectly smooth.... while it's warm, it runs awesome, and starts immediately, but every morning I go out, and it just doesn't want to start. it's always started eventually *knock on wood* but I hate cranking it that long.... it's not throwing any engine-related ECU codes (just the starter relay, and Vehicle Speed Sensor ones....) any ideas?
I've never heard of anyone using a steering dampner on a subaru. but I suppose it could be done... I do know this, however. rule #1 when offroading....thumbs out of the steering wheel!
as long as you're not using wheel spacers or wheels with crazy offset, there's no reason why you'd burn through bearings. and it appears that scott's got a way around the hub-to-strut clearance problem
then it just might work. it'll sit a bit low in the back, and you might have to be a little creative. but I bet you'll have plenty of room in the front.
I think it'll be a touch tight (might need a little trimming) on stock springs. but if you're running OB springs too, they'll fit fine.
yep, great stuff. that's "scott in bellingham"'s site. if/when I build another lifted soob. it'll be with SJR stuff
D/R EA82 swap into AWD Auto EA82T ??
Numbchux replied to 4RnrRick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
one of those 2 was the harness for my EJ22 donor. and it was a FWD 4EAT.....holy crap. the other was my EA82 3AT, which had it's fair share of wires, but nothing by comparison. I certainly think it's possible. but I'd rather build a hybrid high-comp, N/A, MPFI motor, and not have to touch the wiring. than the other way around. I've never really worked with an MPFI EA82 harness though, just messed with/around a couple at the junkyard...so that's mostly just speculation -
no the engine part of the wiring is pretty different. because the turbo block is MPFI.... BUT, you could take both engines out, swap the MPFI heads from the bad motor, to the good one, and drop it in without the turbo (use the exhaust, and intake plenum pieces that are on the SPFI car). only parts you'll need are a few gaskets. AND, the wiring will be completely plug and play with this method. just have to mix and match engine parts a bit. I promise, it'll be an easier job than messing with the wiring harnesses! having messed a bit with a couple different AT harnesses (neither AWD...), the last thing on this planet that I'd like to do is deal with that, and try to have it work! I'm having enough trouble just keeping the engine working on my swap, and it's got a 5-speed.... -
just get an Eaton M62 Supercharger from a mercedes. it's a proven setup. and, assuming the crank pullies are the same size as an EJ22, should produce 5-6psi of boost. and cost less than that thing (if you're patient, they can be had on ebay for less than $300.) AND, the eaton has an electronic clutch on the pully, so you can disengage it, and have the engine run just like stock! it's an interesting idea, but highly doubt it'll work like you'd hoped. I bet the drag on the crank to turn something that big will far outweigh the little bit of boost that the poor motor could handle.
This is what I would do. more power (specifically...torque!) than the SPFI motor, and no wiring hassle. and it'd be a perfect opportunity to put a few new gaskets in there, and new t-belts. -
it looks to be electric?? Just go to sears and buy a leaf blower....
yes, but when they did the summer group buy this past summer, they said that they wouldn't be available after that....
Specs Needed: WRX Flywheel vs EA82
Numbchux replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
bolt pattern can be modified. EJ clutch discs work with EA trannies. the challenge will be the pressure plate, and, as mentioned, the diameter. getting a pressure plate that cooperates with the throwout bearing, and getting the teeth on the outside edge to cooperate with the starter.... -
I did almost 70miles last fall, in my lifted wagon, behind an F150, in the dark. NOT fun. I would NEVER do it again. but, it did save me a fortune on the rescue cost (turned out to be a wet crank angle sensor.... ).
tcase stays up high with the engine and tranny. diffs get dropped down along with crossmembers and subframes. no CV axle problems. and normal driveshafts meant for a solid axle vehicle can handle the angles to compensate, and getting higher angle U-joints is pretty easy too. there's a little more torque and strain, sure. but as long as you're not dumping the clutch, and are easy on the happy pedal, there shouldn't be any problems.
these cars can tow alot more than they can stop. disks or no. don't even think about a highway, if you have to make an emergency stop at highway speeds, you'll be dead. also, how are you going to attach it? I have no idea how much a shadow weighs, and I realize with a dolly that tongue weight isn't really a factor, but that kind of pushing and pulling on the rear of the car might be alot. even if you have one of those tie-down mounted 'receiver' hitches. in fact, what is a shadow? the Honda motorcycle? if it's just a bike, even a larger one, you could do it. but if you need a tow dolly, probably not.
you say it's got OB struts...springs too?
Quick question about EA fuel pump for EJ swap
Numbchux replied to Phizinza's topic in Subaru Retrofitting
I don't know, I've heard that it is (well, turbo vs. non-turbo, most GL-10s are turbo). but the one in my loyale would be the same as a regular GL, and it's working fine for my N/A EJ22. more fuel pressure might not be a bad idea for a turbo EJ motor, however... -
Loyale Front Little Lifting!
Numbchux replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
:confused:- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
aftermarket shifters for 5 speed?
Numbchux replied to hatchsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well, I can tell you this much. the threads on an EA82 shifter are the same dimensions as a '94 legacy. -
IIRC, the springs will give you another inch or so. I'd heard that PK was working on a legacy lift. but I haven't heard anything about it. you might be able to contact AA (call them). they might have something. problem with body lifting a legacy, is you still can't put any bigger tires on it. the spring perches on the struts are the big limitation for tire size. you can fit tires that rub on the perches into the stock wheelwells with pretty minimal trimming. and I don't see the point in body lifting something, if you still can't put bigger tires on it (kinda reminds me of some of the fullsize pickups running around town on stock street tires, and 6" of gap between the rear bumper at tailgate) also, My dad has purchased an outback suspension setup. and it appears to be identical to the system on his '94. but we haven't installed it yet...
as Brucey mentioned, talller gears aren't necessarily the answer. but I thought I'd elaborate... lifted EA82 wagon, if I try to use 5th gear, I have to use so much more throttle, that the gas mileage goes down by almost 10 mpg! cruising at ~4k rpm in 4th gear is WAY more effecient. also, keep in mind that in order to change your final gear ratio, you have to change the rear diff AND the transmission (or have it regeared ) it's a bigger job than most cars
yea, I just meant that comparing what my buddy's doing on his EJ22 is not necessarily a great example. since the EJ22 is bullet-proof, and the 25 is....well....not. he's getting away with 7-9psi quite well. I wouldn't put the EJ25 through more than 5. the DOHC ones have a big problem with head gaskets (I wouldn't think of boosting one of those), and the SOHC ones are better, but the problem isn't gone.
holy old thread! when I first installed my AA lift (1" taller strut extensions than crossmember blocks), I also cranked the adjustable struts up another inch or so. and ate through 3 axles in a month. I lowered them again, and haven't had a problem since.- 22 replies
- Suspension
- Front
(and 1 more)
Tagged with:
