94
Everything posted by Numbchux
Here's the how to I did on it. https://www.subaruoutback.org/threads/driveshaft-u-joint-replacement.465866/post-5685977 And AutoZone part number
EJ22 flywheel rubbing in 91 loyale
Numbchux replied to Zip Tie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Must be an EJ transmission, too? Custom transmission crossmember, I assume? It's possible that the transmission mounts are too low, but I would think it would need to be considerable for this to happen. Are they the same motor mounts? Flywheel? Every EJ swap I've done personally used the EA82 transmission, and therefore flywheel, which is a smaller diameter than the EJ one. But plenty of people have used EJ flywheel and transmission, and I have not heard of anyone having this issue. -
Doors do transfer. On the 1st and 2nd gens, the rear door glass was different between a sedan and wagon, I assume the same is true of the 3rd. I think the sunroof stuff is different. The only sunrooof-related part that I would consider a common failure part would be the cable that runs from the motor to the front glass, but I don't think that applies to the sedan, might even be Outback specific.
You're sort of on the right track. The male stubs on the '05 axles will pop right into the '01 transmission, after the stubs are removed from the '01. Unfortunately, that involves splitting the transmission as the stubs on a manual are held in with snap rings from the inside. You're sure the '01 axle won't work in the '05? Those chassis are VERY similar Here's the surtrack axle for an '01: And for an '05: 4" difference, but that's also counting the stub that protrudes into the transmission, which sounds like it would be really close.
Fuel pump assembly, especially if the cap isn't broken. That's about the only thing that's "prone" to failure. If it's a Limited, it'll have leather, which is very nice IMHO. OE Fog lights suck. They look neat, but not very functional. I sell any good ones off my cars, even if I'm keeping the car. I don't know how the GT ones mount, the Outback ones just bolt to the bottom of the bumper beam. So all I can say there is to watch for any extra bracketry behind the bumper cover. Yep, bumper will swap right over. The '02 may have smaller front brakes than your '03 (mid-year '02 change). Beyond that, normal partout stuff. Switches and lights are usually worth saving. If it's got a trailer hitch. I see a lot of deer crossing, so I would be saving any front bodywork.
A lot of leaks can end up there. Front main, oil pump. Even oil pressure switch can drip down the front of the motor and get blown back to the filter. The oil from a head gasket leak seems to frequently blow backwards as you drive and then drip off the engine crossmember/steering rack/sway bar more than straight down onto the oil filter. But that's a pretty blanket statement.
I just bought these for the low beams in my '00 Outback, and I'm pretty pleased with them. Fit in the stock housing, good optics with a sharp cutoff (made me realize that my LH housing is aimed at the ground since my deer hit last year). https://www.amazon.com/gp/product/B07CNZPPC2/ I don't know about the Forester. But on my Outbacks, the H1 is the low beam and DRL, but when in DRL mode, it gets lower voltage. LEDs will flicker in this mode, so disabling the DRL is a must.
It would. It took quite a bit of time to do then, and I was single, and working part time, and "going" to school....well, enrolled anyway. Got a wife, 2 kids, career, old house, and a couple dozen other projects, now. I like to stay active and see what people are doing, and offer help when I can, but I can't see me sitting down and re-doing the manual.
Bright Idea?? Dumb Question??
Numbchux replied to Al Zhiemer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Liberty has a button on the dash, it's a single momentary button, when 12v is provided on that wire to the control module, it turns the system on, and then again on the same wire, it turns off. Easy enough. This button also has an indicator light in it to tell you when the system is on, you may want to replicate that somewhere. The stalk on the steering wheel has 3 functions. Accel/resume, Decel/set, and Cancel. This is done using a 12v momentary pulse on 2 wires. There are a couple diodes in the switch so it provides 12v to both wires simultaneously for the cancel function (see attached). You could make that your 4th function by replicating those diodes, or leave it off (easy enough to touch the brake pedal to cancel or turn the system off). I assume the switches are from an EA81 sedan or wagon. I don't have any good diagrams on the function of those, but again, shouldn't be hard with a multimeter to figure out how they function and apply a power source to one wire and get it out on another wire when the switch is pressed. -
Building a outback pickup for off road
Numbchux replied to Fish-N-Fool's topic in Subaru Retrofitting
The AWD is crap? Because a functioning VLSD center does surprisingly well offroad. Or you just mean you don't like the gearing in your AWD transmission. I'm just saying you are trading off the gearing for AWD. I drove an EJ-swapped EA82 with stock size tires and a PT4WD transmission for awhile, and HATED it in FWD. It would roast a front tire when you even looked at the throttle, so I was constantly putting it in and out of 4WD when accelerating or turning. Big tires helps, but the stock EA82 geometry is not condusive to traction. I'm pretty apathetic towards the Subaru dual-ranges. It's just not enough. I started building an AWD, 4.444, 1.59 transmission, but got stuck when the Carbonetic front LSD wouldn't clear the low range gears. Since then I've spent more time in vehicles with real gearing (my 4runner with 2.28 low and a torque converter, or a built Toyota manual with 5.29 axles, and double transfer cases with 2.28 and 4.7), and it just doesn't seem worth it. -
Yes, that is just a check valve, it can clog and cause the gas pump to shut off immediately. On the cars with that, we always sold the nuts, too, as the studs usually twist off with them in the old one. Did you ever actually run your VIN on a parts lookup site (parts.subaru.com or partsouq.com both have VIN-specific lookups)? I'd highly reccomend doing that to make sure you've got the right one.
Missing some vital details. What car is this? What cruise system are you using? Here's a generic answer. The EA82 cruise system uses a latching on/off switch, so the switch stays where you leave it, whereas a window switch is momentary. Many EJ systems use a single momentary button to control on and off function. There are ways to use a momentary switch to control a relay, simplest is to just use a latching relay (which would use a separate "on" and "off" function). Window switches can function a couple different ways, where they reverse the power themselves, or just operate a relay. But either way, a few minutes with the correct cruise diagram, and a multimeter on your switch and you should be able to replicate the appropriate signals for the accel/decel buttons (usually just a switch to ground). -
Depends on which transmission you'll use. But almost all the EA82 DR transmissions are from non-turbo cars, and are 23 spline front axle stubs. The only 23 spline front EJ axles are '93-'94 FWD 5MT Imprezas. You can put 25 spline stubs in there, but you have to split the transmission. RX Turbos had 25 spline stubs, but they only have 1.19 (vs 1.59) low range. Yes, transmission is a different length. Wheelbase is different. AFAIK, a custom length driveshaft will be needed. EA82 DR transmissions will require swapping to a 3.9 or 3.7 rear diff, depending which trans you use. IMO, you're hacking up what little creature comforts give the BG platform an edge over the EA82. The EA82 platform is lighter, and simpler. Front axles will be simple, driveshaft is simple. FWD sucks more with the EA82 geometry than EJ, so if you want any sort of pavement performance, go EJ (and AWD). Unless you're launching an inflatable boat, you'll be abusing your clutch with any Subaru manual transmission. Part of me has always liked the Ute versions of the wagons, seeing the new Smyth kits makes me actually want a GG Impreza! I have to say, if one of those ended up in my possession, the exhaust stacks would be in the scrap heap SO fast....but each to their own. -
Production brat lift kit
Numbchux replied to SgtSparkles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
As was said, you're looking for EA81, so there are a few options. FYI, it's not "they", just "him" -
00-04 Legacy and Outback hoods. Hood with a scoop is unique to the Baja turbo. IIRC the washer nozzle spacing is slightly different on the early ones, so you'll want to carry over the hoses. Legacy uses a smaller grill, so it won't meet up with your bumper, but an Outback/Baja grill can be swapped onto it.
"Production"..Nothing mainstream like Rancho, Skyjacker, Rough Country, etc. But there's a couple small companies making stuff. My go-to these days is www.SJRlift.com -
Go to your local dealership and have the parts guys put together a quote for you (even if you don't buy from them, although the kind thing to do would be to buy something there for their time). They'll likely have a good idea of what's typically done. When I worked there, we saw them often, and kept the tube in stock. My concern with the aftermarket, is of all the times I looked them up, I never noticed a pattern. There were like 4 different part numbers, and didn't seem to be any consistency on what fit what. At the very least, you'll want the gasket and 3 screws up at the top. IIRC, the other hoses and stuff were on a case-by-case basis. I know I didn't replace anything else on my '97 when I did it.
