Everything posted by Numbchux
N00b with Questions (swaps, rebuilds, problems, etc)
I agree with Scrap on the engine stuff. not many options as far as EA81 engines are concerned. there was a turbo, MPFI version, but that'll still require wiring, and engine crossmember, etc. if you're going to go to the trouble of an engine swap, go EJ22. awesome motor, 130-140 peak hp, but TONS more torque, and a way more usable torque curve. and if you keep your eyes open, a donor car (HIGHLY recommend the donor car route, instead of buying just the motor/harness etc.) can be had for almost as cheap as your car (though I'd recommend putting some money into a little rebuild...). the 4WD conversion was quite easy on my EA82. and as far as I can tell, the only difference is the EA81s don't have a center driveshaft carrier bearing (one piece driveshaft....finding a mount for the center bearing on a FWD EA82 is interesting), and the gas tanks are different. but if you drop the whole rear subframe/torsion bar assembly as one, then the gas tank, and install in the reverse, you should be able to do it pretty easy. then tranny, driveshaft, linkage, which is all pretty much plug 'n play.
EA-82, 88 vrs EA-82, 89
??? I've got a '92 SPFI engine, intake, and engine harness in my '88, with stock body harness. plug 'n play.
ej swap......
all of the above x 300
thinking of doing my first lift
anything beyond about 4" is going to have to be pretty custom. SJR makes a 6" kit, but it'll require some fabbing to get it to work. if/when I build another, it'll be an SJR 4" kit. He's got it figured out. and it'll be riding on 29" swampers.
IDing Allied Armaments lift parts
yep, that'd be it. mine doesn't look nearly that nice and shiny anymore, but still nice and strong. if you're even remotely skilled in fabricating, you could probably make one, but SJR makes a great one there, and it's not too spendy either.
FYI, don't go beyond 4" without doing something else to drop your diff. I ran with it at 5" for a month or so, and blew up (quite literally) 2 rear axles. I have since gotten a 2" diff shim, and cranked it back up to 5" without trouble for almost a year.
EJ22 power testimonials
I've been there....getting over that pass with an EA82 would be interesting. especially with a load.
excuse my ignorance... what cars came with the ea82 spfi pistons?
oh yea, forgot about the XT overlap..... but it appears those would work anyway, were there turbo XTs in '91?
your best bet, is to ask for 91-94 loyale pistons. the only motor in the loyale (with the exception of the rare 90 loyale RS turbo) was SPFI. if you want to get even more picky, in '91/'92, it was the only 1.8L subaru made...until they came out with the impreza in '93 it was available in all GL/DL N/A EA82s (not hatches or brats) in '88 and '89 (maybe '87 too, but I'm not sure on that one). I wonder if the XT MPFI N/A pistons would work....
Looking for Video's
here's a cool vid of my wagon. all pretty old clips, and I never did remove all the extra blank video at the end... http://media.putfile.com/Chuxwagon-2 everything else has been removed from inactivity, but hopefully I'll have my own domain here in a couple weeks, so I can re-host it all.
only the first few lifts got the adjustable rear extensions....they look like this: even if you got high-clearance, I beleive you get those drop plates for the top.
B. between Engine crossmember and framerails C. drops rear diff hanger (between carrier mounts and framerail, on either side of gas tank) D. drops radius rod bracket (rod that goes back from the front control arms) and transmission crossmember F. drops driveshaft center carrier bearing bracket I'll see if I can find some pics of it all installed on my car engine crossmember block, from the outside of the wheel well: radius rod bracket/tranny xmember on left. (the 2 blocks you see on the right are for the shift linkage gaurd....I have since removed that...it's really optional). they have since upgraded the blocks from 3 individual pieces like you see here, to the 'one piece' creation used now. but it's the same place.
Unique wheels found for 4x140 pattern?
just noticed that post. that's what I thought at first too, however, the enkei wirewheels didn't have centercaps. the lug nuts were visible.
you're dead on the money right there! 'Easy' detroit power IS the EJ22....it just didn't come from detroit, which makes it even better! dropping a V8 in it would require completely re-engineering the car. because even if you could adapt it to the subaru transmission, the whole thing would stick out in front of the front wheels. and just generally screw everything up.
Wheel balancing powder??
that's the conclusion that I came to....but that's definately not how it works. I've ridden in a couple rigs with tires balanced by freeweights in the tires, and you can feel it initially...but once it settles out, it's actually quite smooth many of these guys even have home-welded beadlocks, that surely throw off the balance of the wheels....
they're listed, and even pictured on the wheels page: I've never heard of them, though, and certainly never seen them. wheels page: http://www.ultimatesubaru.org/80s/wheels2/wheels.html
Front diff interchangeability: The true answer
not reffering to the later stubless ones....just EJ vs EA. turbo axles are pretty hard to come by around here, is it possible to use the EA82 23-spline stubs in the LSD? or do you have to use the EJ stubs?
I've heard of the local guys using anything from bbs, to golf balls.....frankly, I have no idea how it works, seems to me that they would all get thrown to the opposite side of the tire from where they should be, and make it worse. but I must be wrong, otherwise people wouldn't do it. anyway, I've never heard of anyone using anything that you wouldn't require the removal of the tire. something I saw on Mn-Jeep http://www.innovativebalancing.com/ oh yea....and I've heard of problems with golf balls:
yes, but the newer cars use a different style stub axle, will that work in the EA box? or do you need to use the EA stubs....will that even work? that's something I hadn't thought about. I wanted to use this in my lifted rig, and just assumed you'd use the same stub shafts. but it sounds like that may not be the case.
Fog Lights
yep, power mirrors was a factory option, so it's integrated into the harness. but fog lights was dealer installed. if you already had them, the wiring will be there, but if you didn't, it won't.
Denver mad scientists - transmission lab: Lab ingredients/forumula FOUND!
I'd bet on it. but if the pinion works with the RX diff....it might work the other way around.... you guys should take about 350 trillion pics of this
Subaru 1.5R impreza
Numbchux replied to bgd73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd daily drive it. I daily drove my lifted EA82 wagon for a year, 91 hp going through 28" tires. it could keep up with traffic, and get ~28mpg doing it. and no, the engine is not more fuel effecient @ WOT. quite the opposite, actually. 5th gear + WOT + ~3k rpms = 80mph @ 22mpg OR 4th gear + ~40% deflection + ~4k rpms = 80mph @ 27mpg..... Lukas, you're exactly right. it's not a race car, and as long as you don't drive it as one, it's awesome. I bet it's perfect in an impreza (wagon for me...thanks) and EJ dual range and yes, EA82s are capable of impressive mileage. like I said, my lifted wagon could hit 27-28mpg, even once got 30 with a little tailwind. my buddy in his '86 carbed GL wagon (what...like 83hp?), has hit as high as 37.....frequently about 35. I can't imagine the kind of mileage possible with the aerodynamic body of the XT no need for more than about 30hp for safety, as long as you're paying attention, and making smart decisions. I've limped my EA82s running on only 2-3cyl. a number of times....it's not any more dangerous. a little hard on the motor, yes, but you just compensate with your driving style, and everything's ok.
Fog Lights
not on anything I've ever owned... definately wire it through a relay, unless you like fire in your car I like putting my switches over near the radio, make for very convenient access. the stock trim panel leaves room for one or 2 right next to the radio. or, if you have an aftermarket deck with dash adapter, there's a panel underneath it that can easily fit 5 or 6....
you really are off your rocker aren't you? Subaru has built millions of EJ-series engines for the better part of 20 years, most of which see well over 200k miles, or put out 300+ hp, sometimes both. 24mpg is pretty impressive while driving that hard. I bet he gets almost 30 on the highway. also keep in mind the oversized tires he's running. back on topic, however. my loyale is so freeekin fun to drive! not lifted, so I haven't had the chance to try an EJ22 EA car offroad. but this thing suprises ALL the local civic and neon guys. even from a roll. the last tank of gas was 100% in the city, meaning virtually never hitting 40 mph, and WOT from every stoplight, and I still got 22mpg. and about a month ago, I took my String Quartet 2hours away to a wedding gig, 4 of us, 4 string instruments, 4 music stands, full-size spare tire, bunch of spare fluids, and my big tool bag. and got all of 27mpg I can't wait til I can get some decent tires and start autocrossing this thing. heck, I can't wait until the ice races this winter!!!!
legacy's didn't have front LSD. they had center, which is a whole different can of worms the only factory 5-speeds with front LSD were JDM STis. but, there are more than a few aftermarket options for WRX etc. cheapest I've been able to find was about $300 for an OBX helical-type LSD. this has nothing to do with the final drive. while the carrier is the same, and therefore the ring gears are the same (or similar enough to work), the pinion is different for the 4WD. I'm quite certain that the only way to change your final drive, is to use a legacy viscous center diff. but then you wouldn't have true 4WD. as for the rear, only STis use an r180 rear end, so r160s in various gear ratios and LSD configs are out there. but if you go r200....you might as well get a locker!
