Everything posted by Numbchux
EJ22 Turbo Upgrade
at 8-9 psi....yes at ~5 and somewhat conservative driving.....no
Check Your Lift Bolts!
I don't know if I have a pic of it, but I've got mine out, so if I have time this weekend I can take one. anyway, Allied Armament here in the states basically took those three blocks, and put a peice of metal along the outside edges to connect them all, that way the forces are applied more efficiently to the unibody. Scott....I'd really like to know how you did it. have any pic of your modified radius rod??
EJ22 Turbo Upgrade
a buddy of mine did this, with upgraded injectors, and piggyback ECU ('96 impreza L auto with PerfectPower 6 for management) and only 5psi of boost (EA82 wastegate on TD04) and had nothing but problems. he actually took it off about 6 months later for the sake of reliability. BUT, another local guy just did the same, except with stock injectors and ECU, and 3psi more boost, and it runs awesome! as long as it's an OBDII (which your car should be) it's smart enough to compensate for the extra air. and he said that when he ran the OBDII diagnostic tests, it said the injectors were only running at 93%, so there's some room for more boost!!! now, keep in mind, although it's running awesome now, he only did this because he just finished his EJ22T (closed deck) build up, and wants to kill the motor that's in it. he is not expecting it to last through the winter. long story short, I've got no definitive answer, just a couple personal situations to think about. if I were doing this (and I might....someday), I'd run less boost, and no management.
my puggys
then you must have had the wrong nuts or something.... either way, you only need the pug nuts if you're using alloy wheels. as they need the big centering washer. not necessary for the steelies.
not sure what you mean....all the kits run the higher risk of having the bolts coming loose. but if you're referring to the leading rod mounts getting horsed up with the new 'one-piece' blocks, I don't think so. they're a HUGE improvement!
my puggys
chef_tim found the longer studs IIRC. you don't need new studs, however. you just need the pug lug nuts. as they have large centering washers on them, or get the ball seats. find the post stickied in the wanted section, McBrat posted a link to the ball seats that allow you to use the subaru nuts with pug alloy wheels
Door ajar chime location
Just to the left of the radio, there's a little vent looking thing. it's immediately behind there. 2 wire pink plug. easiest way to access it is by removing the radio
strut rod....aka leading or radius rod? the one going back from the control arm? if so, I had mine pull out. not because of loose bolts, just because those three blocks (early AA design, I've since moved to the update one piece design), don't transfer the forces effectiently. a buddy of mine and I fixed it, we cut out the area around each nut, welded a new nut to a big ol fender washer, and then welded that into the hole. it's been real solid ever since!
EA to EJ conversion site needs your input
OK, I'm in the process of compiling all the information I can find on the EJ-swap onto one page. I'm using my Geocities account, but when it's done, I'll submit it to the USRM for publishing right here on the site. anyway, here's the link: http://www.geocities.com/numbchuxSOAD/EA2EJ I'm mostly using info from this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=48848 I'd like for you guys to check it out, and as I go, let me know if I should make any changes, whether it be in the formatting, or information. especially including spelling and grammer. I don't want it to look like I'm a total moron I'll bump this thread whenever I update the page.
The Swapzilla Story
yea, I spent many extra hours to hide/protect the wiring. how fast? it's hard to say, but it's definately the fastest N/A EJ22 powered car I've ever ridden in
The Swapzilla Story
OK, now that I've got things pretty much setup how I want it, I thought I'd post a few pics and a few mod list of my '92 loyale frankenwagon. now known as 'Swapzilla' ok, it started as a '92 loyale wagon, the SPFI EA82, and the FWD 3AT tranny. it was reliable as all getout, but slow, and crappy. mostly as a result of the tranny. as a result it inherited the nickname POSUV. well, after I got my '85 5mt d/r wagon, the loyale just sort of got pushed into the woods a forgotten. now, a few years later, we'd already parted out the '85, and it came time to do wheel bearings, ball joint, tie rod ends, shocks, etc. etc. on my mom's 240k mile '92 FWD 4EAT Legacy. so she replaced it with an '01 legacy. and, we began parting out the '92. this last spring I bought an RX tranny, and matching rear LSD. and a pair of adapter plates (one for the loyale and the other for the lifted wagon, a project for next summer). and this summer, I put it all together. using the rear trailing arm assembly, pedal box, and linkage from the '85, the RX tranny, LSD, adapter plate, and EJ22. Also, I got a set of 400/450lb/in adjustable coilovers that a buddy of mine had on his GC8 imp, as well as XT6 sway bars (only the front one is currently mounted), and a rear disc conversion (using 200SX calipers, for rear handbrake, though I haven't connected the cables yet.) I also used the front bumper and grill from my '85, instead of the fat lip look of the loyales. aswell as the white wagon wheels quick list: '92 loyale 4WD conversion MT conversion Rear disc conversion rear handbrake conversion XT6 front sway bar EJ22 RX FT4WD D/R tranny custom one piece driveshaft 400/450 lb/in adjustable coilovers White Wagon wheels and some pics, first with my H-alloys on it (these have real crappy tires, so I just did it to run to a local subaru meet one night): underhood: couple scenic shots here in Duluth:
Tein Flex for RX
bump. I want to know how this works!!
Whos wagon is this??
I didn't mean to say you didn't know what you were talking about. just that it also looks alot like the northern MN dirt too: it looks almost radioactive in that pic, might be the time of year. btw, that's Morgan's real wagon on the right
MUST READ alternator conversion 90A maxima --> ea82 bolton
now that you mention it. my dad has a 90 amp alt for his Z31 that he got out of a maxima. IIRC, the easiest way to make that work was get a crank pulley off the maxima aswell so you can just run the serpentine belt, instead of the v- BUT, apparently if you get a v-belt pulley off a GM car with an internal fan (all of those things are crucial, and somewhat hard to find), it'll complete the puzzle. he already tried using any of the pulleys off of the number of subaru alts that I have laying around, and none of them worked.
speedo cable and lift
technically you can do it from underneath/behind. but probably only if you've had it all apart, and know where/how it goes together. but it may be worth a try.
yea, my speedo cable pulled out, I just rerouted it under the pitch stopper. and yea, my shifter hit the trim around it, I had lots of trouble getting it into any gears. there's a nut on the back of the linkage, that attaches the whole thing to the body, this allows for some adjustment. loosen that nut a bit, and allow it to shift, then retighten. you could also put a bunch of washers on that stud to drop the linkage down a bit, but then you're 4WD lever would probably hit the trim before it get's into the FWD position. this may help some, although I still had to grind on the trim with a dremel to fix it all.
High Amp Alternator ??
oh yea, the stock unit is a 60amp unit, IIRC. the 90amp XT6 alt can be fit in there, but it's not the easiest conversion. however, the 100amp GM alt from the late 80s is a pretty common conversion. I beleive there's a big thread on it here in the old gen forum.
adding GL accessories to a loyale
there's an idea! my carpet's sliding all over the place....
Anyone Try LED Bulbs?
hate to burst your bubble....but all GLs have them, with or without the sunroof
so, I had my door panel off today to try to fix my power window problem (which, btw, I fixed ), and I noticed that the loyales front doors have different handles than GLs, and I also noticed that the hole for the third screw is there behind the panel. a hole in the panel, and the little plastic insert that the screw goes into, and it could easily be switched. anyway, it made me think. anyone ever tried to put GL maplights, or the little light in the rear, into a loyale?? I can't think of any other major differences...
Question...
yep, I've only had one axle permanantly fail that still had a good boot (btw....don't buy/use NAPA reman'd ones!!) I've found a generic CV boot from JCWhitney that's quite big for this application, so it's travel is never strained, they seem to be more durable than the stock ones.
cam angle sensor wiring....sheilded?
sorry man, I'm talking about a legacy motor, hence the CAM angle sensor, not crank.....I guess I just assumed people would know what car I was talking about since I've been having so much trouble with my EJ swap this summer, my bad :-\ but, like I said, it appears to be working again. without the sheilding. I can't think of a reason why I should string new wires if it's working fine. I doubt it'll do anything but make it run like crap if it needs to be sheilded, and even if it does more, I've got extra sensors and an ECU....so I'm just not going to worry about it for the record, the 2 signal wires I used have pretty thick insulation. so that probably helps
Question...
if you've done a body lift, it makes no difference. I started running into problems when I was running almost 5" of pure suspension lift in the rear. but now that I'm down to about 3, I haven't had a problem yet. I've never had a clicking EA-series axle last very long, maybe it's just the mud up here, but as soon as the boot tears, and some mud gets up in there, it breaks (even before the lift). my mom's legacy, however.....went about 10k miles with clicking CVs... long story short: no
you happen to be right, but it also looks almost identical to the iron ore rich dirt we have in Northern MN... and no, I had Morgan's old wagon for the last 6 months or so....and it doesn't look nearly that nice
In a previous life I must have been a used car salesman
no, theoretically (from the side of the can) you can run it for as long as you'd like, but I've heard from many sources that it should only be run in there temporarily. also, when you're done with the oil change, add some Marvel Mystery Oil....it seems to do wonders on the valvetrain of these cars (HLA's and such)
