Everything posted by Numbchux
going even more custom with my lift. need advice
who says you need more lift to get bigger tires? my black wagon has a 3" BYB lift with stock springs and non-adjustables with 29s. I say remove the accord springs, and do some fender trimming, then run big enough tires to get the ride height you want. otherwise, I'm thinking of removing those same blocks from said black wagon for the crawl 4 the cure next weekend. if I do, you can have them and the bolts for shipping (assuming they're not totally trashed....which they might be)
Chux's EJ22 swap thread for this week....
ugh....I'm getting very tired of this, I'll probably cough up the cash to have Shawn make me a harness when I do this swap in my lifted wagon.... mechanically, the swap is virtually done. engine's in, linkage is done, rear end is in, still waiting on rear brakes and front axles from tcat. haven't done the radiator yet, but I figure it won't need one until it runs anyway, in the meantime, it just leaves me more space to work. I'm not a total electrical idiot, but some of this stuff just leaves me stumped. anyway, I'm not getting spark. I've read Tex's thread about the same problem, but I think it's different. I'm not getting any spark, ever. neither of the ignition or fuel relays are getting power through the harness, and the ignition one isn't getting a ground. I ran a few wires just to get them to come on, and it still doens't work. so I have a feeling it's a deeper issue. This motor worked perfectly in the donor car, and was not dissasembled in any way. the entire engine harness etc. was left on the engine, and unplugged from the body during the swap. the only underhood wiring I've touched to the engine is the crank/cam angle, and knock sensor wires, to lengthen them. but I'm quite certain they all have good connections. everything on the harness seems to be grounded sufficiently, I tapped into the ground wire just to test it, and have been using it to test other circuits all day, with no problems, so I doubt that's the problem. what else could it be? I don't have easy access to a FSM, I've just been going off the chiltons/haynes diagrams, and some that my buddy printed off of the system at the garage that he works at. but I still can't figure it out... also, those that did it, how did you do the oil pressure gauge? the EJ motor just has the idiot light, but I'd kinda like the gauge to work, will an aftermarket sender fit under the alt? or should I just wire a little light to it, and if the light comes on....get worried.... there's probably more I'm forgetting, but that should do for now.
Need a little more info for 94 imp DR Swap
FWD imprezas don't have rear axles hatch monster's got it all right for the spline counts you can use your A/C compressor for on board air, for refilling your tires after airing them down, for air tools, etc. but nobody makes an air locker for a subaru.
ea81 cowl induction hood?
archemitis has one on his hatch. pretty sure it was a generic, plastic or fiberglass one out of a catalog, but he did cut the hood out from underneath it. and he had origionally thought about doing sort of a shaker idea with the H6 emblem on the intake manifold of the ER27 sticking up out of the hood
Support a great cause!!!
Sweet! thanks!!
The choices...
that would be cool.....but I still say hi comp EJ25
Hurley's axle thread
the High Clearance AA lift is fine on axles, as long as you don't try to get any more lift out of them. I had a few troubles when I had my struts adjusted up ~1"
Summer Lift Kit Group Buy
^Buddy of mine.... he just wanted me to make sure you guys know he's out of town for the week, but is still 100% in on the group buy.
First time wheeling was loads of fun until...
I hear the GCK EA81 axles are BEEFY, but I have EA82's so in my experience, by the time you spend enough money, to have enough extra lifetime warranty reman'd crap axles, you might as well have had some custom ones made! I wouldn't feel comfortable wheeling on reman'd axles unless I had at least 4 spares just to make sure I could limp it home. I've had horrible luck with remanufactured axles (had one last me about 18 hours once...), and great luck with junkyard axles, for a fraction of the price.
another EJ swap Q...
yep, we had a donor car sitting in the driveway...but we still did it all at once. you need to tear the dash down to the firewall, which means disconnecting the Lines to the heater core, and A/C lines. and both front fenders. The fuse box under the hood will need to be dissasembled, including removing all the relays (It's a tight fit through the hole in the inner fender), but save 'em. The fuse box under the dash won't fit out the hole, so the entire under-hood harness will need to be threaded into the interior. when we did it, we left only unplugged what we had to, left all relays on the harness (eve headlights ones, etc.). just to make things a bit easier. and it seems to have helped at this stage
outback fitted with ea82 D/R??
front axles are easy, FWD impreza's use a 23-spline inner DOJ cup, just like EA82 N/As. and the axles are the same as the legacy ones (or at least Gen 1 legacies....I can't say about later ones). the trick is driveshaft, as the EJ one won't go into the back of the tranny...and the EA one uses a different center carrier bracket. a custom shaft will probably need to be used. and then there's the crossmember....and linkage. I haven't looked at that yet....
AHA, I think you're right! that would explain the misunderstanding! thank you
ok, thanks. that's what I was thinking, but my dad kept saying that we're going to need to pulll the dash as we were pulling the wiring out of the legacy donor car....
just the motor, it'll be mated to an RX tranny.....but I don't know how it would make a difference
you guys that did it....did you pull the dash out of the EA car during the install? or can it be done reasonably just from the driver side with the gauges and stuff removed...
don't think there's going to be a DVD this year, but I'll plan on it for next, just not enough footage or time this year (mostly because the only good footage I have, is Austins, and I don't actually have it....). BUT, I just hit the $400 mark today, anyone here want to contribute?! if I win anything in the raffle, I'll offer it up to you people first (but it'll probably be for jeeps...)
Ej 5speed-welding center diff?
yes, the center diff can be welded. there's a local guy running hi L wagon with RWD right now. yes, it would bind horribly on the street....don't do it yes, FWD impreza axles fit right onto EA part-time 4WD Dual Range trannies and into your hubs (correct me if I"m wrong here, is there a difference between legacy and imp hubs?, otherwise you could probably swap the 23-spline inner cups onto your legacy axles)
New Pain relief available.
tried airing them down?? it doesn't sound like it would help, but it certainly does!! the rocks up here are very sharp (our ORV park is an old Iron Ore mine), and it's amazing what letting 15-20 psi of pressure out of your tires will do!
Roofline Snorkel, Why?
that's just one reason to remove the mechanical fan, and turn the electric one off before going into any water that deep!! case in point! he was not moving very fast either. in fact, if he had been going any slower, he might not have drifted to the other side.....
R&P steering pushing swampers ??
well, since this has turned into a PS vs. non-PS discussion.....I'll throw my experience in there: MorganM removed the PS from his wagon (when it was his anyway), but didn't swap the racks. it's quite hard to get it to turn, I can do it, but not unless I"m moving a little bit.
ok, one more EJ22 swap Q
sweet, thanks man
how much of the main harness/ECU is effected by the tranny setup? my donor car is a FWD 4EAT....will that make things drastically more difficult?
evans creek inspections!! info for wheelers, legal requirements
I haven't measured the black one, but my blue wagon's rear bumper is 24"+ off the ground sorry, yes, we are talking about washington. I just thought I'd throw out the rules in MN for camparison....but I think I just made it more confusing
EA82 rear sway bar mounts
yea, I figured I could just drill and tap the holes, but I don't remember how it went on there, so I'm not sure where to put them....but it doesn't look like there's a place there. ugh, I hope that '88 t-wagon is still at the yard!
Impreza Brat
no attempt at all, they finished it, and IMHO it looks awesome! http://www.htautos.co.uk/8.html
