Everything posted by Numbchux
Went offroading today.. my oilpan isn't happy...
my buddy had a return line welded onto his oil pan for when he added a turbo....so it can be done I'm soooo protective of my oil pan, it can really keep my abilities limited, cause I'm worried about doing that to my oil pan, or worse
What Do I Do With My New Sube?!?!?!
don't forget soobme/TWB! http://www.ultimatesubaru.org/forum/showthread.php?t=47904 and do a little research before you send Mudrat any money.....he's been banned because of his business practices... lifts: http://www.ozified.com http://www.sjrlift.com http://www.alliedarmament.com
possible area for me to offroad...maybe
that's a great story and all......but in Minnesota anyway, it's a felony, and you could loose the vehicle used.
I reiterate: the FAQ is no longer stickied....I don't know why, so I even did a little searching for you: http://www.ultimatesubaru.org/forum/showthread.php?t=24980 there's a search button near the top of the page
Minnesota Subaru BBQ
yea, I'm not sure when I'll be able to get those from you next, but I'll be in touch... that's a great idea!! we should do that!
lifts for old subarus are blocks, it's a body lift. you can't get more than an inch or so with just springs, and that's through tougher springs, which will cause substantially worse performance offroad 4-lug subarus virtually never came with 14" wheels in the US (I only know of 1 set for sure, but there's probably a couple more) camber is not adjustable on them. unless you go building yourself custom longer control arms, which would need longer axles, and probably longer tie rods I have one wagon with 3" of lift (not including tires), and another with 4". both running ~28" tires. if you're getting serious at all, 3" is not enough! good advice on the motor.....but for an EA82, that's WAY too much money, if you're going to spend that kind of money/effort.....do an EJ swap. if you don't want to put that much work into the motor, start removing stuff that doesn't work/you don't need. A/C, mechanical fan (as long as you have an electric one, and the rest of the cooling system works fine), DONT remove power steering, the previous owner of one of my wagons removed the power steering on it, and I hate it. for a car that's built to be maneuverable at slow speed, it's crucial. also, make sure it has a good ignition system, do the whole thing, coil, disty cap and rotor, wires, and plugs. it'll help alot.
Video THread
I'm in Minnesota. We only have 1 public place....the rest is private land.
Well, Morgan doesn't own a subaru anymore. Archemetis is arund, and theoretically still owns 87 subarus (sure seems like it anyway), but is not a regular online poster... your best bet is to join the MNSubaru club ( www.MNSubaru.com ), There's usually stuff happening on there, if nothing else, the weekly firestone meet in downtown St. Paul, I'm usually there if I'm in town. woa!! holy simultaneous posts!!! yea, I know morgan would come, and so woud austin. Just as long as it doesn't conflict with the open house in Gilbert on the 20th. and I'm planning to have lots of 'garage' days in May (though they probalby won't actually be in the garage hehe). I've got a few big projects in the works for when school gets out.
Sweet82's on the right track, but I don't think you need to get a different car. If your loyale is pretty solid structurally, and if you're ready to be doing a lift, and other modifications to your subaru, a transmission swap is pretty easy. Find one out of a '85-'89 Wagon, Sedan, or Coupe. Non-turbo. Should be part-time 4WD, but not the pushbutton, it'll have a third lever (regular shifter, ebrake, 4WD), Just like a truck or Jeep. It has a 2WD (FWD in this case) setting, a 4WD Hi setting, and a 4WD Lo setting. this lo range is key in getting those 4 little hampsters under the hood to turn big tires when on the rocks (or whatever it is that you're wheeling on). THere is a FAQ (Frequently Asked Questions) section here in the Offroad forum, it lookes like it got un-stickied, so you'll probably have to search for it. but it has a TON of information, compiled from many of our members posts over the last few years. Beyond that, just hang out, read virtually everything you can. There is a ton of information here, and no definate answer to your questions, so you'll have to look around, and decide what you want to do. The three options for pre-built lifts are all very comparable, it's not like jeep lifts, where some give better flex, while others just look good, Subaru lifts are all virtually the same, price and availability are probably the deciding factors in any of them.
just tell them you're willing to accept that. or, find one that's based more on an internet forum, like the MN Jeep club. They're real informal, but a great way to meet people, and find what there is available in your area.
Rear diff swap?
based on what?!? so you've seen them in action, but ever followed one down a trail? neither solid, nor independant is superior in everything. they both have their advantages, and disadvantages. but back on topic. yes, roundeye, it's been discussed. but usually with toyota IFS stuff, not chevy. AdamNDJ was in the process of making an adapter to mate the toyota front knuckles to the trailing arm in the rear of the subaru, so the diff, and axles could be used. until he got called to duty....search for it.
This is a great way to find places to go, and people to go with. Typically, the local offroad groups are more than happy to get anybody and everybody who's even a little serious about wheeling to come out with them. I'm a member of the Minnesota Jeep Club, and the North Shore Wheelers (which is primarily Jeeps) here where I live, and frequently go on trail rides with them.
Be VERY careful about wheeling somewhere you don't know about. Here in MN, if it's public, it's illegal (except the iron range park up in gilbert). and the rules for ATVs and ORVs are very different. There are a ton of places that ATVs are allowed, but ORVs are not. please don't help the general public reenforce those stereotypes that keep us off the land in the first place. Be better than that. Make sure it's 100% legal, or don't go.
Any interest in a lift kit group buy???
how about ej-ea adapter plates??
Official Lift Kit Group Buy
I don't think the front of an EA82 is the same as an XT6....
Ea82-t Crank Bolt Gone South!
that happened to my blue wagon last fall. just as I was pulling into my alley, all the lights came on, it looked like it does when the ignition is on, but the engine was off.....so when I pulled onto my slab, I popped the hood, and the crank pulley was hanging by the alternator belt. the bolt was still there, thank goodness.....but very much no longer attached. yikes!
Outback lift kit $550
I assume it's the same one that's on their site: http://alliedarmament.homestead.com/LiftKit.html
Serious axel problems
yea, what car are we talking about? lifted? what kind of axles?
pieces of subaru youve left on the trail?
I've left lots of CV balls, and a few pieces of that rear DOJ....but everything else I picked up ripped off the rear bumper cover once, didn't realize it until I got home, but I went back for it the next day. I peeled my roof rack off a couple times, until I trimmed a foot+ off the crossbars....good times
Please Help 5-lug Conversion!
I've already got the xt6 control arms, but was thinking that the legacy stuff wouldn't be quite right. the axles are the right length and everything? I thought the legacies had a wider track....
wait....so the front axles, knuckles, etc. will work from a '94 legacy?!? I just picked up one for an EJ donor....I wasn't expecting to be able to use this stuff!! sweet!
91 loyale skid plate/brush bar? help!
you could, but the stock one is pretty beefy. I'd say just leave it. IMHO, the only reason to get a different one, is once you've got a lift, the stock one won't reach anymore...
you have an EA82 your loyale should have a skidplate (assuming it's 4WD) from the factory a brushgaurd will probably have to be completely custom. Allied Armament, or TWB fabs is probably your best bet. look for their posts in the vender section here.
Car Multi-sensor digital guage *added models & price ranges*
or easily bypassed, but it would be nice to have a way to do that, but disable it at the touch of a button (or flip of a switch). So us offroaders could reach down, and turn off the fan for 30 seconds while playing in the water.
Video THread
OK..... http://www.ultimatesubaru.org/photos/showphoto.php?photo=8529&cat=500&ppuser=3242 http://media.putfile.com/Tribute-to-the-Chuxwagon http://media.putfile.com/Chuxwagon-2
