94
Everything posted by Numbchux
Hey from Minnesota
Numbchux replied to Optimus8304's topic in Meet n' Greet. Your USMB Welcome Center
I'm sure I'll be in town in August for Ojibwe Forests Rally. -
Plug an OBD reader in and read the coolant temperature, and compare it to an infrared temp scanner pointed at the coolant bridge (if you don't have these tools, combined investment of $20-30 on amazon and invaluable diagnostic tools). If they agree, that's not your problem. Then connect the test mode connectors to make sure the circuit operates as it should. A/C will warrant fan operation, and defrost engages A/C. Depending on the conditions, it's not improbable that the engine really is warm enough to warrant low speed fan operation.
I ASSume 2.5, CVT? Does it go into Park (engage parking prawl)? What fluid did you use, and did you put it in the right place (fill plug on the side)? I know these can be a bear to get all the air out (best done level, warm and running, which is hard to do without a hoist), but I wouldn't think an air pocket would default to drive.
You've got a bad connection somewhere. I've seen it a few times. My XT6 was a loose bolt between battery cable and terminal, Loyale was a melted connector at the ignition switch, old Legacy someone didn't put the main ground wire back on when replacing the starter. Check the main battery cables (positive to the starter, ground to the starter bolt). Make sure they're in good condition. Wiggle them around and see if they feel too soft or too hard (I've seen moisture get inside the insulation and corrode the copper from the inside). If those look good, you can buy a high-amp relay, and install it between the battery and starter solenoid to isolate any issue with the ignition switch/wiring/connectors inside the car.
Subaru automatics (there are some premium models with VTD AWD that are different, but definitely not yours) are VERY front wheel biased. Drive to the rear has a noticeable delay, and as the clutches that drive them get worn it gets worse (my XT6 requires considerable front wheel spin to get the rear to engage at all.....not ideal). Manual transmissions use a much simpler AWD that sends the power to both ends equally and has a viscous LSD to prevent slip. The Forester might have a rear LSD, whereas the Legacy definitely didn't, but that'll be a pretty small difference. So it's not a Legacy v Forester thing, it's the transmission type.
It's possible the worn brushes on the motor were knocked clean as you replaced it (for the first month or so of driving my winter beater Outback this year, I had to smack the blower with my snow brush to get it to start working in the morning), just like smacking a bad starter. Or, your problem is actually a bad contact somewhere that you jostled when replacing, and it'll return...
I haven't been doing harnesses for many years....not worth the time. SJR still lists it on his site: https://www.sjrlift.com/collections/engine-swap/products/wiring-harness-thinout-ej-swap
Grain of salt: my expertise is with EA82s, but off the top of my head I think EA81 is the same or similar....but I could be wrong. You can hook the EJ temp sensor to the Brat gauge and it will read low, but still usable (you sort of have to mentally re calibrate what normal is...). You can use a resistor to fix that reading (details in the writeup). EA sensor uses larger threads than the EJ, so can't use that, and I don't think there's enough material to drill/tap to the larger size. Also there are universal sensor housings out there that fit inline with a radiator hose. If you go aftermarket (digital or analog), you can reuse that wire in the EJ harness for a clean installation. Tach is just a matter of hooking up the correct wire from the EJ ECU to the Brat gauge. Speedometer is mechanical. I know that an EA82 cable will work with an EJ transmission. People have swapped EA82 and EJ transmissions into EA81s many times, and I don't recall any discussion of any difficulty with cables there....
Very little will be identical. Phase 1 vs 2 engine/transmission. Different body style. Brakes are the same. Front struts, knuckles, control arms, axles will be similar (I think there's a difference in ABS sensor). Driveshaft will be the same if it's the same style transmission. Exhaust will be similar. Fuel pump is different. The BE/BHs don't seem to be plagued with filler neck issues. But the '00-'01 ones are susceptible to rear subframe rust. I just replaced that on my '00 330k mile OBK, and the filler neck looked great.
It only takes a few drops of oil to leave a residue in the reservoir, so don't panic yet. I would remove and clean out the reservoir, and keep an eye on it. Check it when the system is cold so the level is at it's lowest. The time to worry is when you have coolant in the oil, temperature creeping, or running issues. Even coolant consumption on these engines is usually just intake manifold gaskets.
Hey from Minnesota
Outskirts of Duluth -
Put a stereo and a poorly-installed subwoofer box in it like the other kids and call it a day. If you're only sort-of broke, get some tires better suited to your needs/wants (all-terrain, or high performance). There are some simple brake swaps from slightly newer Subarus that can usually be procured for cheapish (although usually require larger wheels and therefore new tires).
- 12 replies
- 1
Hey from Minnesota
Hello, fellow Minnesotan! -
Here's the factory service manual: http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/2004/2004 USDM/. Go into the Transmission section. On page 37 of the Control systems file is a picture of the roll pin (this section is about removing the entire shift linkage, so most of the rest is not terribly helpful). Then in the Manual transmission file, page 43 is for the Transfer case and extension case removal. You only need to remove the extension case, so there's a lot more there than you need, but it's kind of useful. It talks about correctly shimming those bearings, but I wouldn't worry about that, I'd just transfer the shims from the old case into the new. The next section about the transfer drive gear is useful, as you'll have to transfer that from your old housing to new (just 4 bolts...). Here's the parts breakdown for the shift linkage: You'll have to remove the springpin marked 35083, and then slide that ujoint (35046) off the shaft on the transmission. You'll also have to separate the support rod from the transmission, probably easiest by removing the 3 bolts that hold 35033 bracket to the housing.
If you use that good used transmission. I bet you can get a core for $50-100. So more like $200-250.... I wouldn't describe a ujoint symptom as a rumble, more of a vibration, and usually only while under load. It's not generally play in the joint, but they seize. It can be felt by hand, but only after removing the shaft from the car.
I see 2 listed on car-part in NH for $150ea, about 150 miles from you. I bet those yards would be happy to ship one to you if the local ones don't want to bother. Jim's Used Cars in Ellsworth shows one from an '01 that needs joints for $100 (they also have a good transmission for $350, but I'd call around and see if anyone has a core that may not be listed online). 00-04 Outback and any year Baja with a Manual transmission is the best fit, but any Legacy/Outback manual 2004 or older would be acceptable. I used a shaft from an '07 in my '04, and it was a touch longer and felt like it was bottomed out in the transmission. I used it for a couple weeks and didn't have a problem, but I wouldn't recommend it as a long term fix. Lining up the parts are relatively easy. The hardest part will probably be the shift linkage. There's a double roll pin that has to be pounded out and then the 2 halves separated, here they have a tendency to rust together and require heat and/or pounding to get apart and back together.
