Everything posted by Numbchux
possible idea...
http://www.ultimatesubaru.org/forum/showthread.php?t=51382&
ej22 swap question (what radiator should I use) also help on the legacy parts list
or just go to http://www.alliedarmament.com they're just reselling 88hatchmonsters. or acting as a middle man of sorts.
Loyale Q's
as long as the drivetrain setup matches, it'll work. an AT single range 4WD GL gauge cluster will fit in an AT single range loyale. a FWD GL cluster will fit a FWD loyale. I'm not sure about the dual ranges, as they have a 'lo' indicator. so someone else would have to chime in for that, but if you happen to have one that matches, you'll be fine.
Loyale Headlights won't go off
huh....good to know
Lower gears, using stock drive & 31" tires ?
you add a traditional transfer case behind the stock tranny. much like it would work in a truck or jeep. this requires quite a bit of modification, as the tcase needs somewhere to mount, which means you have to essentially build an entire frame under it. Also, you have to lift the car enough that you can put a second diff under the tranny. which means at least 8" this 'could' be done on an imp, but I'm sure it would be very difficult. it's been done repeatedly on EA81's, but only 2 or 3 times on EA82. even the extra complexity of an EA82 makes it much more difficult. so I'm sure it would be very hard on an imp. not to mention that the stock tranny would have to be modified to send all of the power out the rear output. Mudrat did this when using an EJ AT in his EA81 hatch, but it required pretty extensive modification. or, swap in an EA D/R tranny, which would give you the second lo-range reduction, but also open a whole new can of worms as far as modification goes. I'm not saying it's not possible, but it'd be pretty darn tough.
yea, I can't think of a way that it would do this accidentally. it sounds like someone did it on purpose. but the loyale's did not come with DRL's from the factory.
Anyone seen the new SubieSport?
For all of you that didn't see it:
May 20 in MN
It's the open house at the Iron Range Offroad Park in Gilbert, MN to raise awareness for responsible and legal offroading. You can get into the park for free. Let's try to get some more subarus up there. There will be lots of jeep guys, and the local S10 ZR2 club is probably coming, aswell as my uncle in his Landrover. If we get enough people to come, it'll really get things moving on the new Virginia expansion to the park. My place is only an hour away, so lodging will be free. Who wants to come? Mick? Austin? Archemitis? Tim? also, this is a great place, with lots of terrain, a stock subaru would be more than fine up there.
No Spark....
good point! I didn't think of that....if there wasn't a blown fuse before....there probably is now I'll see if I can find a better test lead. Thanks!
I got an almost full page spread in the Readers Rides section on my car. I'm going to take a picture of it to save it. I'll post it up later. And I just sent them an email, with a huge list of everything I've done to my car, and attached 5 or 6 hi-res pics to it. I just got my copy on Friday, so those of you who are subscribed, it's probably on it's way
No Spark....
well, I still couldn't find my multimeter.....but I dug out an old electric Radiator Fan, cut the plug off, extended both the wires, propped it up in a safe place where the blades couldn't hit anything, and went around testing things. I figure even if there isn't all of 12v getting through there, it'll still spin the fan a little. touched it to the battery (just to make sure my system worked..) and it spun (and reminded me why I replaced that fan.....bad bearing, yikes what a horrible sound) Anyway, I turned the ignition on, and started touching my wires to stuff. and got nothing. nothing at the + and - sides of the coil. tried + and ground too. then I stuck the wires in both of the connecters going to the coil. nothing, even in the one that plugs into the amplifier. at this point, I'm thinking it's going to be something stupid. but I just don't know what
wow, and you're in it! "Can anyone tell me why the interior smells like something died in it?"
Anyone? or notice that one of the testers for the Honda CRV vs forester vs impreza was TEX?! or see the huge article about WJM's RX and a how-to on Megasquirt? or catch the '86 XT Turbo the magazine picked up as a project rally car? but I'm telling ya, the best part was page 23
RWD Only Soob
Why Thank you...that was a fun day that's exactly right! I noticed that very early on in my FWD loyale, when going through snow, if I went in forward, I could almost always back out! weight distribution? like most of it in the front, not much in the back :-p
No Spark....
everything's plugged in.... from the weather we've been having the last few days, I doubt anything got melted
No Spark....
lol, it's actually MorganM's old wagon. there is an ecu code for the sensor (the Crank Angle Sensor), That happened on my other wagon when I swamped, got gilbert mud in the sensor...but it threw a code. I'm not getting the code now. I can't find my multimiter, so I haven't been able to test it, that and it's snowed about 8 inches today, and I don't have a garage.....brrrrrr Will there be voltage to the + side of the coil all the time with the ignition on? even without the engine turning over? or do I need to have someone crank the engine over while I test it?
April 2006....check out page 23
so why don't it work??? Update page 4
did you check the fuse? it could be that it's getting power from the switched power source, or even just the backlight line, and not the always on power. I hope that made sense... also, could be the fuse on the back of the deck or it's just broken
No Spark....
fuse is fine..... how would I diagnose/repair the amplifier?
Finally built my snorkel **UP-DATE 3/8/06 NEW CARB ADAPTOR! NO TOILET FLANGE**
looks very good, a little goofy coming out of the hood, but I bet it'll work awesome!
RWD Only Soob
Subarus do not have torque steer. Don't confuse them with other FWD cars, they're much different. What causes torque steer, is the tranverse mounted engine, and therefore the tranny/diff has to be mounted off to one side. This forces the front axles to be different lengths. Under accelleration, the axles actually twist a little, and because of the unequal lengths, unequal amounts of power go to either front wheel. This causes one wheel to want to accel more than the other, cause the car to turn (This is why Brian's eclipse turns at the start of the race in the Fast and Furious, btw, everyone mocks that, but it's actually quite real). Subarus, on the other hand, have a longitudanal (I didn't spell that right...sorry) engine/tranny configuration. allowing for exactly equal length front axles (they're even interchangeable). Torque steer is a non-issue.
No Spark....
OK, didn't have much time today, but I did check for ECU codes.....34 = EGR....I suspect that was the one that caused the previous owner to put electrical tape over the CEL. So I doubt that's new....any other ideas?
RWD Only Soob
the drivetrain is plenty strong!!! it handles alot of abuse offroad with 28" tires, and only fails if you have extreme CV angles
RWD Only Soob
it is If it's got a FWD mode, it does not have a center diff. That's why you can't use 4WD on the road
RWD Only Soob
You're most definately not the first one to do this... there have been a few that have damaged the rear output while abusing it substantially... BUT, lo range RWD and front ebrake are a wonderful combination:
