Everything posted by Numbchux
RWD Only Soob
You're most definately not the first one to do this... there have been a few that have damaged the rear output while abusing it substantially... BUT, lo range RWD and front ebrake are a wonderful combination:
Jumpin' the '79...
no, you don't, when minnesotans condemn something to the junkyard.....you just don't
SVX to EA82 5 lug conversion?
I suppose it's possible with the front, I'm not sure, but the rear is a whole different animal. the entire rear suspension was changed with the EJ cars. Take 'er apart and have a look, but I think you'll find that some extreme modification will be in order to make them work right.
No Spark....
yep, all dash lights are working just fine. I did my best to look at the wires going to the coil, but it's hard in the dark, I'll look again in the morning.
No Spark....
nope, it's got brand new belts, and no covers....that was one of the first things I checked
Jumpin' the '79...
+1.....I've never even seen an EA81 on the road that wasn't a board member! even EA82's are rare in this part of the country! and junkyards?! you're lucky to find a legacy older than '95!
No Spark....
so I've been driving my car ('88 Gl Wagon, 3" BYB lift, etc.) quite a bit these days, but just because of scheduling, etc. haven't driven it in a few days. I know the gas tank was real low, so I went out real early so I could go straight to a gas station. Got out there, and it wouldn't start. Great, so I throw my gas can in my Girlfriends Escort, hook up the battery charger (in case it took alot of cranking), and the magnetic block heater, and head off to class, after class, I pick up a couple gallons of gas and come home. I put in the gas, and tried it again. Still nothing, turns over fine, but won't even fire. great, so I pull off the coil wire and test for spark....nothing Any ideas? it's dark and snowing now, and I don't want to try to diagnose it now....but anyone have a similar problem? it's been extremely cold this weekend, well below 0 for a few days there....anyone had a car just not start? it's cranking strong, and it really isn't that cold now. but it just won't fire.
Broken Axle
if it were me, and I had a parts car...I'd swap trannies...
Big Buncha Pics from My Saturday Fun ***Action photo added post # 23***)
having wheeled a bit with Austin in his Imp, I think the biggest disadvantage is the lack of lo range. but the extra lo rpm torque helps a bunch
Broken Axle
let me put in my vote on 'new' verses used axles, as someone who's replaced more axles than I can, or would care to, count, both used, and remanufactured. You're average 'new' remanufactured axle is total crap. and won't last very long at all, even under normal use. but an OEM subaru axle, no matter how old, as long as the boot is kept in good condition, will last hundreds and hundreds of thousands of miles. it sounds like you're diff stub has come out of the tranny. is this on your driver? or your parts car? if it's the car you're driving, the axle's probably fine, and the diff bearings went out, causing the stub to work itself loose. if it's on the parts car, and you want to get the stub out of the axle. a vice and a MAPP torch can be invaluable tools! oh yea, and the axles are reversable from one side to the other
Can someone explain this on my Loyale
I don't have the solution to the problem, but I can tell you that there is a very simple throttle cable. one end attached to the pedal, the other to the throttle body. no electronics
DEEP water crossing (video)
ah, the video from the pic we've all seen.....cool
auto tranny alternative
and GL-10's
Prepping for deep water
^^overkill.... this does remind me, however, that when you're in the water, don't, if you can possibly avoid it, push in the clutch. if you're in deep enough water, and you push in the clutch, water can get between the plate and flywheel.....even if the engine's running, you're not coming out!
is that a new hood/grill/headlights? I thought you had the scoop and vents?
loyale turbo
sure, it could be done, but why? the EA82 (loyale) turbo is not well matched to it's own 1.8l engine, it would not go well with your 2.2l. Find someone upgrading their WRX turbo and use the td04 from that. then you won't have to rig much at all, just use WRX parts
I've never had any trouble with either, but I always look after muddin, and the top of the dipstick is dry. and I've got my dif breather extended up into the spare tire well
lol, that's just funny....it was 20 below in the sun here on friday....not to mention the wind off lake superior....mmmmm nonetheless, it looks sweet!! looks like the trip up to two harbors I took a couple months ago with the North Shore Wheelers....my car was the only one to leave this hole unassisted before the fullsize chevy broke it up a bit more
Anyone ever replaced their key's battery??
well...nevermind....I decided to try it with it off the keyring....and what do you know? it worked? one half slides off of the other, with a CR1620 watch battery in it.....for future reference
That's right, my latest GL came with it's origional master key with the little LED light in it to light up the ignition or door lock in the dark. but I'm sure it's origional, so it's very very faint. still functional, but useless nonetheless....anyone replaced the battery in it?
Amber Door Lock Light?????
I tried very extensively to disable this....to no avail. I found that everything relatively accessable will also disable the power locks. the only way is to either pull the cluster, and pull the bulb. or put some electrical tape over it (just a large piece in the general vicinity on the plastic cover will do, my latest wagon came like that) though if you find a way...I'd love to know it!!
oh yea, all the carpet is torn out of both of my wagons.... I like your concept of the container over the disty, but it would have to have a pretty small and low opening to combat the water effectivly. I've had problems (with a brand new OEM subaru disty gasket) in water not nearly deep enough to actually submerge the disty, but just splash up on to it. however you decide to do it, bring some paper towels/kleenex in a plastic bag so you cna dry things out. and if you're not getting any spark from the coil, it could be the crank angle sensor in the bottom of the disty, if you get really mucky water in there it'll gum up the sensor and you won't get any spark at all. That turned out to be my problem up at iron range offroad...
85 Automatic 4x4 question
it's more like a torque converter. 100% of the torque goes to the front. and the rear goes through this clutch pack. it doesn't have to be a stay on the pavement, but it's not going to be doing anything real serious. Right now you've got essentially the same setup as an EJ 4EAT AWD tranny with the Duty C locked. it's pretty strong, but the rear output will still slip under full load. the lack of gearing (single range, IIRC 1st gear in a 3AT is higher than a 5-speed) is a larger detriment to the 4WD system...
that's right....thanks for the correction
