Numbchux
    94
Everything posted by Numbchux
  1. Really?? I guess I've just been lucky then I stand corrected!! thanks!
  2. the 4-cyl XT's have the same alt the 6-cyl ones have a better one, but it requires some modification to make it work...doa search for info on that
  3. I'm not sure if it makes a difference, but you multiply the miles to compensate for the tires, than divide by the gallons...mine's about 20% (same as speedo, so if you barrow a GPS, or match speed with another car at 50, you can figure it out that way), and that get's me about 20 mpg @ 75 mph, 24 @ 60, and 22 city...
  4. I have done the clutch on mine...but did you do it on a lifted subaru?? I couldn't beleive how much easier it was to do!! I actually got most of it done with the tranny up in the air, just pulled back out of the way...then I got the idea to swap in the lower mileage tranny sitting just inside the garage...anyway, I only needed help getting the tranny back up in the air, the rest, I did by myself....first time! oh yea, and I had my dad spin the wheel while I tightened the pressure plate bolts through the starter hole, but my mother could've done that! anyway....glad you're making progress, I expect to see some off-road pics soon!!
  5. pulling the engine to do a clutch?? wow, I can understand doing it on an unlifted rig...but on a lifted one, you don't even need to jack up the car....maybe I did it the hard way
  6. Yea, my camber looked pretty crazy when I first put the lift on, but after a couple trips up to duluth (~300 miles one way), it settled out some...it still looks kind of crazy, but not too bad, and handles just fine (well, as good as can be expected with no sway bar...)
  7. Most of my friends love it! some of them have an old D/R Subaru next on their wishlist!! but when I take it out on the trails, and do better than the jeeps with way more money into 'em...they're usually threatened, and have some pretty negative things to say .....whatever, I know it's because they're insecure about their heeps
  8. oh....it's been done alright....the search function at the top of the page will yeild more info than you know what to do with, and if it doesn't, check out the USRM (repair manual), which is stickied in the old gen forum
  9. oh....like the caliper's seized and won't clamp on the disc? I'm not sure what you mean by locked....
  10. I've been pushing my luck....as I've only been carrying a stock wheel as my spare, I have an extra wheel, but just haven't gone and had a full-size tire put on it... anyway, it's the opposite for me, if I get a flat, I need to put the spare on the front, because I have an LSD in the back, those two need to be the same size, it's a bit harder on the front diff, but it'll bet me home in a pinch... one of these days, I'll go and get a tire put on it
  11. I hate to burst your bubble, but the D/R's only came on non-turbo cars....RX's have a similar dual-range, but not as much reduction in lo... The push button is just single range....it's in FWD, push the button, it's in 4WD....OR, it might be full-time 4WD with center diff lock...either way, it's not a dual range if you do find one, you'll need to be creative about axles/driveshafts, I've heard FWD axles fit on the D/R stubs, but I'm not sure, and I haven't a clue at how the driveshaft would fit, and yes, you'll need an adapter plate, and some creative work on the linkage, it's not as simple as you think
  12. You scared me there!! I thought you'd gone and hit a minivan or something... I was looking at some of the pics from there, and man, it looked scary, my car just isn't up to it yet. how'd the rubicon do? it's ok, you needed to redo the paint on that side anyway
  13. If it were me, these would be the only options above and beyond it being unsafe, it's really hard on the car, specifically the tranny, even if it's a 4-speed, I'd be nervous about doing damage
  14. Yes...They might be different height, I'm not sure, it probably depends more on whether it's 4WD or not, but they will bolt up.
  15. wow!! on road?! that would really hurt your mileage, not to mention your tires, and handline I've got mine at 35, but those are just all-seasons, I'd run swampers a bit less...I like tim's suggestion of 32
  16. well, if you're gonna be offroading, 6-lug is your best bet, if you're gonna be going for road performance, 5-lug is probably your best option...
  17. I too had to do this to my '85 carbed wagon, the nest was in the blower. I moved the resistor block, took out the three bolts that hold the blower in, and dropped the entire contents of a mice nest out of the system, it was mostly chewed up insulation from the rest of the car. I then put it back in, but not tight, turned on the blower, and sprayed lysol right onto the fan, which effectively forced it all through the system. then followed it with the febreze and didn't notice the smell until just before I junked the car a year later. Same treatment again probably would've done it...
  18. Well, you ARE the Dr. of Krazy.... really though, my mom's legacy does that, only when it's cold though...but it's real bad, it does it just a tiny bit otherwise, but it also jumps around all crazy when it's cold...we've decided it must be the cable, but haven't done anything yet. another vote for the cable
  19. yep, blocks between the engine crossmember and body, and more between the radius rod bracket/tranny crossmember and body shady, you know I'll be getting front bumper from you....just depends on the style maybe a swing gate too...if you're still doing those.
  20. hmmm...this is a good point....I just talked to my dad, who's a mere 10 miles or so from where austin lives now...he said it's 8*F!!!
  21. oh yea...forgot about the Auto....get the RX
