94
Everything posted by Numbchux
I did some looking. That allen bolt is likely one of the upper oil pan bolts to the block. Probably could remove it without an issue, but shouldn't need to. Yea, make sure you're not using an impact socket. Only downside to removing the oil cooler, is in order to really get any more room, you'll probably have to drain the coolant system and disconnect those 2 hoses (easily flexible enough to replace the cooler oring itself...). And this is new enough to call for the Subaru blue coolant.
There was a TSB about the TPS on H6 models causing mild transmission issues without throwing a code. There is an updated part number from Subaru for it. It's not exactly cheap, so get your hands on the FSM testing page to test the resistance values, but that might be your answer. That's the only thing I can think of. The Transmission unit uses speed and throttle position to determine the appropriate gear. If it was getting bad speed info, you'd have other symptoms....so it almost has to be TPS. The TCU is a learning unit, so it might be worth doing a capacitive discharge (disconnect the battery for a few minutes, and step on the brake to use up any electricity in the capacitors) to reset things to a factory default. It may be learning some bad habits.
6 lug hub and break issues, 87 gl wagon
Numbchux replied to adot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
SOP for the 6-lug conversion is just to redrill the hub. So the brake parts are not changed. Should be standard EA82 parts. -
It's well above the level in the pan. Barely a dribble, as I recall. Much easier to access with the oil filter off, though. I had a hell of a time getting the new one started with the filter in place. Also I had an aftermarket one on it which used a different sized socket.
It's completely possible to piece together without a donor car. And if you know your way around the cars, it can be an excellent way to do it. I have several times. BUT, I will still say that generally-speaking the best way (cheapest, lowest risk of failure, most complete) is a donor car. I'm in the middle of a Lexus 1UZ 4.0l DOHC V8 swap for my 4Runner. I bought the engine out of a car, and could not hear it run. So I bench ran it before I bought almost any other parts for it. Those ECUs are notorious for having failing capacitors, so I replaced those, and bench ran it again to make sure it still worked. Then I coated an exhaust manifold and ran it again. All together, it's probably run about an hour on the stand. Skip the first 10 minutes to hear it run.
- 17 replies
- 2
Subaru GL-10 Classic Car Licensing
Numbchux replied to Nowah9's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This will depend very much on the local laws. Typically the state has a vaguely-worded statement about when and where you can drive it, which pretty much completely leaves it to the local law enforcement's discretion. When I got collector plates for my Brat and 4Runner (probably 8-10 years ago), I definitely had to sign something stating limited use (similar to the WA list posted above), when my dad did it for his 300ZX (more like 15 years ago), there was mention of mileage (although no inspection or anything to enforce it), when I did it for my Celica last year, there wasn't even any mention of it. The only requirement now, is to have another car registered with standard plates in my name. I kept standard plates on my Celica for years even though it was seasonal use, as I do daily drive it in the summer. I got pulled over one spring for expired tabs. When I told the officer that I bought them over the winter, but forgot to put them on when I got it out of storage, he suggested that I register it as a collector. My old neighbor, before I moved a few years ago, daily drove 2 cars both with collector plates year round. He did have a car in his name with regular plates, but his wife drove it. Never had a problem. I did get grief at the DMV/DNR office when I got an ORV sticker for my 4Runner. The lady at the counter, "You're going to take your collector bajaing through the woods? Your going to get caught!". I told her not to worry about it, and I've never had a problem. Of course, it's not a large savings. My insurance didn't change (I already take coverage off them when I'm not driving them). Tabs on older vehicles are only like $35 a year, and I don't have to run a front plate....neat. -
Engine swap for Brat.Doable?
Numbchux replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yea, it'll fit. Adapter plate to an EA82 transmission (better for offroad use), or use an EJ one (better for street use). Custom transmission crossmember. Some creativity/research on front axles. Wiring. Fuel Pump. Some Plumbing. It's been done many times, documented fairly well. I'd call it about a 2 or 3 out of 10 as far as engine swaps. But I'm pretty well-versed in swaps (currently putting a Lexus quad cam V8 in my 4Runner, and did a lot of work helping a friend put a 6.0 LS in his '98 Legacy). -
?'s about using XT6 knuckle with EJ axles (impreza)
Numbchux replied to FerGloyale's topic in Subaru Retrofitting
This would be my recommendation. But, here's my stream-of-consciousness post about inner wheel seals: Short version, I ended up test-fitting a Timken/National 225678, and it looked like it would work (I don't like the XT6 knuckle/brake setup for my applications, so I never put it to use). -
I knew I'd seen a similar discussion on this topic awhile ago, so I looked up the thread. Sounds like it might be the same car. Either way, no follow-up https://www.subaruoutback.org/forums/110-gen-2-2000-2004/494839-2003-subaru-outback-3l-h6-electrical-onstar-issue.html I haven't had any issue by unplugging modules. My '04 had Onstar, I unplugged it all and tossed it, and everything works. My '00 had a Subaru accessory shock sensor mounted next to the radio, tossed it, security system works as it should (no shock sensing, of course, but whatever). Ideally, you'd still have the stuff you cut out, but even without it, get the wiring diagrams (linked in the above thread), and repair what was cut, and that will probably fix your problem.
Good point, '00-'01 had a recall to spray a coating on it for that, but now 15 years later (I think the "recall" spray on my '00 was performed in '03), they're getting pretty nasty. They changed the coating in '02, so they're much less susceptible, but still worth looking at. It's possible to replace, but not a small job, and worth considering when buying.
Yea, very few "common" issues on the '00-'04 cars (by far my favorite Subaru). 4-cylinder cars are notorious for Head Gasket leaks, but unlike the stereotypical head gasket failure, these almost always manifest as an oil leak. Annoying, but as long as you check the oil regularly and don't let it run out, they'll run a long time (I had an '03 that was leaking when I bought it, and I fixed it right before selling it about 40k miles later). 6-cylinder cars have an issue with the serpentine belt pullies that can fail with little warning. Replace them preventatively. Depending on trim, Subaru started phasing in immobilizers into the '05-'09 cars. If that's the case, keep in mind a duplicate key is $150-200, and if you loose the last one, it's a HUGE project (make sure you always have a spare). Turbos were an option in this vintage, these are much more finicky about maintenance, I don't recommend them for daily use. Wiring into the tailgate is fairly common to fatigue were it bends between the gate/body. If it has any issues with the rear wiper, lock, or lights in the tailgate, there's a decent chance it needs repair there. Individual breaks can be traced and repaired, but it's about $80 for a new harness to reset the clock. But far more important is general maintenance. Fluids, matching tires, stuff like that. I normally look for low-mileage, neglected cars for cheap. Last year I bought a '00 with about 320k miles on it from an acquaintance who I know takes good care of his cars. It has been eye-opening how much fewer problems it has...
It's an interesting theory. But to me, it seems that if the surfaces in the joint really are that worn, it's going to be a problem either way. That said, I've brought some really troublesome joints back to life with new boots and grease. I've never bothered to swap side to side. I just re-boot originals.
Wow, thanks for the update. I never knew him, and don't remember the last time I saw him post, but he certainly was a regular in my early USMB days. Sorry to hear that.
Yes. Foresters are still 5x100 bolt pattern, so the wheels will fit. Offset is probably 5-7 mm different, depending on the year, but that's a pretty small difference. As has been mentioned, the tires from that forester will almost certainly hit the strut, and possibly bodywork as well, again depending on the year (tire size). With the correct tires, the wheels would fit. And you could probably go a bit oversized if you wanted, but Legacy front struts do not leave much room.
And people who want an answer. I probably know the answer to your question. But I still don't know your question. Good luck!
Cool. Is the 5-bolt version any stronger?
Yep, my first thought is turbo, but it could be a lot of things. Also, if the turbo is bad enough, it can introduce debris into the oil, which in-turn kills the engine (which is why it's hard to find good used engines). It would be possible to put a non-turbo engine in. Would require many modifications. And you'd want to have the ECU retuned (the advantage of the turbo ECU is it is tuneable). But being that the non-turbo cars are so much more common, it would make so much more sense to just start with one.
directional tyres running wrong direction
Numbchux replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When unlocked, that center diff is open, so it's not as bad as a LSD center like the EJ boxes. But yea, really should run 4 identical tires. -
Turbo is DOHC. Best to pull the engine to remove the heads (probably possible without, but it's best to tilt the engine on it's side, as the cams have to come off to get to the head bolts). Smoking out the exhaust could be just about anything. Without a pretty in-depth diagnosis, assume it needs a complete new engine w/turbo.
Still worth getting hyped up for. I'll be buying one FOR SURE. There was mention in the Facebook post about 1-bolt and 5-bolt versions. Looks like these will drop into the factory carrier to replace the spider gears, so maybe there are 2 different versions. And I'm assuming it wouldn't work in place of a factory LSD. But these are all details.
This! If you've got a You Pull it style junkyard nearby, find one with a late '90s/early '00s Subaru. Any 4-cylinder would work. Tensioner bracket bolts to the Compressor/alternator bracket, and there's another little bracket over the head. Just grab the whole assembly, compressor, lines, etc. It'll be more efficient with the r134a than the compressor that matches your engine. Then take a picture of the VIN if you need parts in the future.
Love the pop top! good work!
Numbchux replied to pontoontodd's topic in Off Road
Excellent highlight video. About a minute in, the slow rock trail is what I like. I don't think I've done anything quite that gnarly in our Outback, but close. A clean swap will remove the un-used parts of the harness, merging 2 into 1. Although the older cars have very little there to remove, so it's not as big of a deal to just leave it. -
Oh yea, it's a nightmare. Even with the A-pillar bars tight up against the firewall it makes it tough. I worked on a car where they had built the cage with the dash in place, and threaded the bars through the side defrost openings. We had to swap it to a non-turbo for a season, and it ended up with most of 2 harnesses in it so we wouldn't have to take it out twice in about 10 months.
