Everything posted by Numbchux
Is there any way to start an EJ25 without an ECU?
Numbchux replied to trainergames's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis means you have bigger issues than the ECU. Even without the ECU it should crank over. First thing I would do is put a socket (22mm, IIRC) on the crank and see if you can rotate the engine by hand. Rule out seized or hydrolocked. Then check for power getting to the starter (the heavy wire to the stud on the starter should always be hot, small wire on the spade should be hot with the key in "start"). If it's getting power, it's probably the starter, if it doesn't it's electrical (security system, ignition switch, neutral switch, wiring etc.) And I would definitely agree that it needs all fluids, rear diff, transmission/front diff (separate fluids if it's an auto), and oil at the very least. My dad and I resurrected a flood car many years ago. '94 Legacy, had water partway up the doors, well over the hubs. We had a parts car, so we swapped the carpet, door cards, and seats. We stripped that stuff out, pulled the ECU and ABS unit out and apart and let them dry in the sun for a few days, changed all the fluids, repacked the wheel bearings, and drove it for another 100k miles (had about 260k on it when we parted it out, then I put the engine in a '96 Outback which got at least another 20k before it was sold). We never had mystery electrical gremlins or anything. Of course a '94 has a lot less electronics than an '05, but I'd think it'd be worth a shot.
Loud Power Steering Pump
Numbchux replied to Naked Buell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just did that O ring on our Outback, old one was as hard as plastic. MSRP on it from the dealer was less than $2. That and a couple worm clamps on the suction hose seem to have solved my fluid aeration problem.
97 Impreza OBS temperature
Numbchux replied to HASx11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that car should be a 2.2, not common for head gasket failure. And head gasket symptoms usually get worse with speed, and involve coolant loss. I think the easiest thing to check (although it seems fairly unlikely), is whether the fans are coming on. When it's good and hot, stop and pop the hood and see if they're both running. It doesn't take much driving at all to push enough air through the radiator, though. I had a failed fan in our Outback 3.0 for over a year and the only time it ran warm was offroading in June, slow trails with lots of trees and the A/C on.... Thermostats very rarely stick shut (I've honestly never seen it, and I've tested several), but it's cheap enough, and some fresh coolant can't hurt. I would also recommend pulling the radiator when you have the system drained, and make sure the fins are clean. The fins are spaced out more in the A/C condenser, and debris can accumulate between them blocking the airflow.
Failing AC compressor pulley?
Numbchux replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA/C tensioner/idler (aftermarket usually lists as an idler) is relatively common. If the bearing seizes it'll frequently damage some of the hardware around it. Pull the belt and check the pulley. If that bearing feels rough, replace it. If you catch it before it wrecks other stuff, you can replace just the bearing.
WHEEL BOLT PATTERNS
Numbchux replied to tonyarmstrong's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIncorrect. wtdash is correct that the Forester stuck with 5x100, where the Legacy/Outback line switched to 5x114.3 in 2015 They will not bolt up. Also, FYI. All Legacies have at least 17s these days, some with 18s.
AGM Battery Upgrade
Numbchux replied to suprunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's certainly possible that it's not charging and you don't have a warning light. Get a Multi-Meter (if you don't have one, get one. If you have a Harbor Freight near you, it's about $5), and test the voltage across the battery while running. Should be ~14.5v. Or, go to almost any auto parts store, they usually have a hand-held battery/alternator tester that they can bring out to the parking lot and test it quick. Does the battery light come on when you first turn the key on? If the warning bulb burns out the alternator will not charge.
Rear Rotted brake lines 98 Outback
Numbchux replied to mickytrus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI second this post completely. They are double/inverted flares, with M10x1.0 fittings. I took this picture of the repair I made on my '97 about a year and a half ago, this is under the back seat. I replaced all the steel hard line that is exposed under the back of the car. There's a factory junction block just under here, but it's usually badly rusted, I just bypass it entirely. 2017-08-09_08-16-18 by Numbchux, on Flickr Use an inline flaring tool, like this. Makes flaring the line a breeze, especially in the car. https://www.amazon.com/dp/B01DO9142G?tag=amz-mkt-chr-us-20&ascsubtag=1ba00-01000-a0032-win10-other-nomod-us000-pcomp-feature-scomp-wm-4-wl-ddt0_sce0_prc0_aapi0&ref=bit_scomp_sav0 You'll need a small tubing cutter, as well. Nothing special there. Cheapest source for the NiCopp Line https://www.amazon.com/gp/product/B0788JTB45/ref=oh_aui_detailpage_o05_s00?ie=UTF8&th=1 On my latest project, I used stainless fittings, too..... https--,,--//www.amazon.com/Stainless-Steel-Metric-Invert-Fitting/dp/B01KNGVPCC/ Then you'll just need a pair of unions. These are the exact ones that I used, but they're cheaper at your local auto parts store: https://www.amazon.com/Brass-Brake-Union-M10x1-0-Inverted/dp/B001O09HVI/ref=sr_1_6?s=automotive&ie=UTF8&qid=1515186248&sr=1-6&keywords=brake+line+union+metric
AGM Battery Upgrade
Numbchux replied to suprunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLights dim with electrical load while running? Car wouldn't start after a long drive? Sounds to me like you have a charging problem, not a battery problem.
2015 Outback Battery Issues (keyless entry
Numbchux replied to backout's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wonder which one of my coworkers you spoke to.... Yep, factory battery was 356cca, they're finally puttying 490cca ones in them for 2018. Subaru replacement batteries come from Interstate, and are 550cca (That SOA part number you listed).
Timing belt install: What's the secret?
Numbchux replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFactory recommendation is to leave the RH lower idler off, install the belt, and then install that idler. I do that, line up the marks on the top side of the belt then slip the belt between the cogged idler and water pump, then install the last idler. I've had a couple fight me, and it seemed to help not to torque down the other pullies loose until the belt is on.
There's a reason TTB is so popular with the Baja guys. The Dana 44 version has very long "arms", and is pretty beefy. I've been doing a lot of research on 4WD vans (I just bought a ford conversion van), and there's a company down in California that's getting like 15" of travel from a Dana 50 TTB (much shorter arms than the 44), under a full-size van. I'm leaning towards something like that under mine. It's pretty crucial to get the mounts set up correctly at ride height, as that's what effects all the alignment angles.
If you hate the wipers starting when you hit the 'wash' button like I do...
Numbchux replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, what's this on? I've often thought about it on my cars, but never followed through.
88 GL 10 T- 2.2 L swap, hoping to run Microsquirt
Megasquirt is powerful, but very much open-source. That brings along a lot of challenges. There are a few different injection and ignition methods, and they have different requirements for sensors. With batch fire/wasted spark, it can be done with just a fairly low-resolution crank trigger. For full sequential, you'll need much better signals. There's a guy here in MN setting up an EG33 on MS, and while the stock trigger wheels give enough resolution, the stock sensors themselves are not reliable enough, and he was getting nasty sync loss. So he made custom adapter brackets to mount aftermarket hall effect sensors in the stock positions to improve the reliability so he can run reliable sequential injection/ignition. Then come the turbos.... Run something commercially developed, and you'll have much more support, and more consistent information (Open source means you're searching the whole of the internet for build threads and write-ups, and some of it is current and most of it isn't...). You'll pay 2-6x as much, but it'll be much easier to work with.
Anyone install a Transgo SK RE4R01A shift kit
Numbchux replied to bratman2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, a shift kit would firm things up and prevent slippage. Power mode changes shift points, line pressure, and AWD function.
Width of PS rack?
When using EJ axles, the inner joints are more compressed than on an EJ car. Some people have reported that they bottom out. Technically using EJ knuckles shortens the tie rod assembly slightly, it's a negligible change when driving straight, but that small change relative to the ball joint really improves the ackermann angle (while turning, the inside wheel turns sharper than the outside).
Bet you never had this happen
Numbchux replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't take anything apart, just get it in the air and get under there and see if that axle is seated in the transmission. If it's not, my preferred method is to pop the ball joint out of the control arm, and swing the whole knuckle assembly in until the joint bottoms out and you can sort of use it like a slide hammer to pop it back in.
Numbchux replied to john in KY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have seen axles not fully engaged into the transmission/rear diff. Never seen an EJ hub stripped.
Subaru EJ251 in a Miata
Very interesting, and I'm sure it'll be a fun car. Yea, those transfer gears typically don't hold up well to being the sole output, but the light weight and relatively low power levels here will help. Might want to start budgeting to upgrade those. Custom driveshaft, I assume? Seems like a pretty niche market. Someone with the time and skill to assemble an engine, and notch the crossmember and framerail, but wants some bolt-on brackets? Probably a great candidate for a BRZ transmission, or Bill's bellhousing to a Toyota RWD transmission.
CVT
Numbchux replied to QZORX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, well, that is kind of strange. Regardless, though, your car doesn't have the CVT, it's a 4EAT. So a CVT will behave very differently. Go test-drive it, you might like it. The infinitely-variable ratios might suit your driving style better.
CVT
Numbchux replied to QZORX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, I'm a bit unclear on the complaint. Especially since the Imprezas didn't get the CVT until 2012, your 2011 has a conventional automatic. A new Outback is only available with a CVT, no manual or conventional auto since 2014. It is a second revision of the CVT that gets fewer complaints than the older ones. That said, I drive my mom's 2012 Impreza Premium (CVT with paddle shifters) all the time and I like it, it's different, but does exactly what it was designed to do, and I've never experienced anything that I would call bucking or shifting as long as I was being consistent with the throttle.
99 outback power steering
Numbchux replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere did the replacement parts come from? Remanufactured? We've had terrible luck with remanufactured power steering components lately. We've had several Subarus in for pumps, reman one non-functional out of the box, warrantied once or twice before we give up and put a new OE one in, which works perfectly. Get a decent used pump and try that.
Width of PS rack?
I used an XT rack in my Loyale. It was a direct swap, it was a quicker ratio, but only barely. IMHO not worth the work unless you have to replace the rack anyway.
Width of PS rack?
On flat ground, yes. But as the suspension travels, the control arm and steering link both move in an arc. If they're not the same length, they will not move in the same arc. I did a quick google search and found this picture. It's a little oversimplified as it shows those arcs above horizontal, but a cars travel is completely below horizontal. And I would illustrate it with the 2 arcs overlapping at ride height....but the basic property is the same
Width of PS rack?
Shortening the steering linkage will effect how the toe changes through the suspension travel. That's what we're talking about, shortened rods has been done but you end up with bump steer.
Is there a svx only forum
Numbchux replied to Gabessvx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.subaru-svx.net/forum/
