Everything posted by Numbchux
Old Subaru like Lego's
Numbchux replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, GDs got 2 facelifts (and sedans got flared fenders, so sedans and wagons have different fenders and front bumpers). You can swap the entire front clip 02-07 with some modification to the core supports. You could also use a Saab 9-2x front clip, if you could find one. 04-05 headlights should all be interchangeable (there are likely a few different headlights that fit in that opening depending on trim. I know the STis had HIDs, etc.)
1991 Loyale Air in brake line
Master Cylinders should be bench bled before installation. so you've likely pushed a lot of air into the system. If your car has a hill holder (definitely on MT GLs, I never had a MT Loyale), there's a bleeder on that.
2020 Impreza Sport tire options?
Numbchux replied to Turbone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTaller sidewall with the same wheel diameter = taller overall tire. 225 and 205 are widths. Second number is sidewall height as a percentage of the width. That likely has a 225/40r18. Going to a 205/45r18 likely has the same sidewall height, because it's a percentage. Tire rack does not list a smaller wheel option on the website, but they're the same 296mm front rotors that they've used forever, so I would think you should be able to go down to a 16 easily.
Remedy for leather car seat stress
Numbchux replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
XT6 Transmission Crossmember Question
Nope, not without major modification (probably easier to fab from scratch) I've heard of people using the standard EA82 crossmembers, and modifying them to accept the EJ center piece.
16" 1998 Forester rims on a 2010 Outback?
Numbchux replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had numerous sets of Blizzaks that are approaching 10 years old still looking good because I store them out of the sun. My only hands-on experience with X-ices have been on a stage rally car, so I can't speak to treadwear 😜 The Nokian rep (grain of salt) will be quick to tell you that the Hakka is the only winter tire that is the softer compound through the entire depth of the tread, all the others get harder, and will essentially be an all season by about 7/32" (50% useable wear, most start with 10/32 and should be replaced by 4/32). I don't know if I buy that, but I do prefer Hakkas. The forester wheels will likely be higher offset and maybe even narrower, so they will be set back in the wheel wells a bit. Might complicate strut clearance, but you're running small tires.
Rear suspension - one tire rubs the mud guard in front of it, the other side doesn't.
Yep. I had the first AA lift, which didn't drop the rear crossmember like the BYB/PJD ones did (woa....I think that was 18 years ago...yuck). The rear suspension pivots around that front bushing, which is basically right at the front lower corner of the bodywork. So the tire swings forward from the centerline of the wheel well, but I don't think it gets any closer to the sheet metal. But maybe a not-rusty rocker (what's that?) would stick down a bit below that bushing and be a problem. I can't quite picture how it would all work
The 3 bolts between the outer and inner trailing arm can be loosened and adjusted to adjust toe and camber, so it is possible that it is adjusted differently. Might be worth a tape measure alignment. Or, a worn bushing could change the goemetry. I'd get under there with a tape measure and see where the discrepancy is.
2002 Forester timing pulley failed
Numbchux replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn't need an engine. It needs valves. I don't believe for a second that a $650 used EJ25 is "good". Especially from a quality source willing to stand behind the product. Unless the COMPLETE history on that used engine were known, I wouldn't just drop in a 20 year old engine. I would do MLS head gaskets and timing stuff. At which point, just fix your engine.
Numbchux replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEven just a compression test Definitely throw a belt on it and see. But I bet there's a dead hole or 2.
Numbchux replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen them skip without damage. But broken while running, I'd bet on bent valves. Head gasket job, plus take the heads to a machine shop for pressure testing and valve replacement as needed.
'93 Legacy 5MT into XT6?
Numbchux replied to linkthehero1234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope. If you had an XT6 FT4WD transmission, you could gut them both and make a FT4WD EJ transmission. But it's a big job, for worse gearing and differential. Any driveline shop can modify the driveshaft, though. Extra couple days in the process, but drop the engine and transmission in as soon as you can, measure the driveshaft, and it'll be done before you can get the wiring done. 4EAT shaft is likely a bit too short, and 4WD MT shaft is too long (you are correct that EA82 and XT6 use the same length shaft). Easier to cut down one that's too long, than lengthen one that's too short (it's metric tube, to they'll have to machine the factory flanges to fit standard tubing).
Numbchux replied to linkthehero1234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo. The AWD tailhousing is longer than the 4WD one. The splines are the same, but IIRC I had to have about 4" removed from mine. Also the bellhousing is different, so unless you're doing an engine swap, too, you'll need to swap all the internals into the XT6 case.
'01 H6: Inadequate cooling
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe just throwing a new radiator at it would have done it. But I feel much better having flushed the engine and heater core, too. Circulation through the heater core is crucial for thermostat operation. I don't think anything is bad, per se. I used Gunk, and we use Wynn's at the dealership where I work.
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy '04 VDC started doing that a couple years ago (~250k miles), and eventually got bad enough to require significant change in driving style to keep it from getting dangerously hot. I used a Spectra aftermarket radiator when I repaired the crash damage it had when I bought it (at 133k miles). A serious cooling system flush solved it. Put a flush chemical in it and drove it for a few days, drained, filled with coolant and flush, drove for a few days, then drained, removed the radiator so that it could be intensely flushed inside and out, and the condenser could be sprayed out from the engine bay side. Then disconnected and flushed the heater core, and then engine. Temperatures stay perfect, now (I put the 100+k mile aftermarket thermostat right back in with a new gasket).
How do you tell if a CVT trans or valve body has failed?
Numbchux replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIIRC, there are 6-8 solenoids in the valve body assembly, so generally you'll throw a code and have a circuit to test. I do remember seeing a few that had other solenoids fail. But the lockup one was the most common. Converter and transmission itself will generally lead to physical symptoms (sound, lurching, slipping, etc.).
Numbchux replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe most common "valve body" failure that I've seen is the torque converter lockup solenoid, but the solenoids are not sold separately. On my mom's 2012 Impreza, it threw a code for the lockup solenoid, ohm'ed it out and it was either open or shorted (I don't remember which). I bought a chinese solenoid on Amazon, which worked for a few months. Then I got my hands on a used Valve body, the torque converter solenoid is identical to 2 of the shift solenoids, but the torque converter one is used almost constant 100% duty while driving, so I pulled the shift solenoids and used one in place of the failed converter solenoid, which worked great. Of course, about a year later, the transmission started slipping, bucking and lurching, and being a salvaged oil burner, it now sits in my yard awaiting partout.
Tribeca wiring harness question
Numbchux replied to linkthehero1234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat might be possible, but you'd have to reverse engineer all the information on the CAN data stream, and then begin to experiment to see what the ECU needs to run without throwing codes. Frankly, the fact that you're asking these questions means you probably aren't up to the task, it requires several orders of magnitude more knowledge of the car and it's systems than knowing which harness goes where. AFAIK, there is no "prebuilt" emulator to do this. There are prebuilt universal emulators/loggers, but they'd likely have to be custom programmed.
Numbchux replied to linkthehero1234's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, being a CANBUS car, you would have to get Every. Single. Module. in the whole car. And you have to make every single one happy. Or none of it will function. The most current information you'll find will be on the "Six Swapped Subarus" Facebook group. If someone's figured out how to crack one of the ECUs, it'll be there. But if the software's been modified, it likely still won't pass smog.
Timing belt broke, perplexed
Numbchux replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen many aftermarket belts tear apart like that. Mitusboshi belt, NSK pullies, AISIN tensioner, make sure there aren't any seals leaking oil on it. Have the heads checked. And you'll be back on the road.
Recommendations for 2002 Outback Wagon LL Bean EZ30D
Numbchux replied to jeffroid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou used to be able to get a JDM engine with ~65k miles on it for about $800. Now it's closer to twice that. So the climate has changed a bit. Labor to do head gaskets on an EZ is considerable. The timing chain cover bolts alone can be a huge nightmare. And then you have all the time into an engine with completely unknown history. Sure, it runs fine now, but how long will that last?
AC stretch belts on an older subaru EJ
Numbchux replied to nvu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sure it would be possible, just a matter of removing the tensioner and finding the right size belt. Not sure why you'd want to. They're more expensive, and can't be reused. IIRC Subaru only used them for like 2 years.
'02 Outback heads
Numbchux replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you asking about replacing heads because the belt broke? If so, just have a machine shop replace the bent valves. The heads are fine.
2011 outback transmission valve body
Numbchux replied to Toadspit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat was how my mom's 12 Impreza started. I think it made it about 8k more miles before it was terrifyingly bad. And now it's parked in my yard awaiting partout. I hope your experience goes better.
Numbchux replied to Toadspit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPretty common to have issues with the solenoids (usually torque converter) in the early CVTs. Subaru does not sell the solenoids separately, and the chinese solenoids you can find on Amazon and such only last a few months. I got my hands on a used valve body and used the good solenoids (there are 3 that are identical), which worked great for a year or so until the rest of the CVT gave up the ghost. That was with about 220k on a 2012 Impreza. I really should start parting out that car.... good news is the valve body is on the top, accessible right below the airbox. Really not too bad of a job. But consider that the best case scenario, and assume the worst. Good CVTs are expensive.
