112
Everything posted by Numbchux
No way to know how long it will last. Might be 50k, might be 50. New fluid will help, but obviously it won't solve the problem. And it will still be a gamble every time you drive it. Make sure your never outside the towing range of your AAA membership.... Whatever you think it's worth (I won't get into that, the market is crazy right now), it will be worth a LOT less with a known major problem like that. Look at Impreza transmissions. 3.9 is a very common ratio for the Impreza/OBS in that vintage. They will likely have a slightly taller 5th gear than the heavier Legacy, but it's a pretty small change. Facebook marketplace and brand-specific groups are a great place to buy a transmission. I bought 2 Turbo (FXT and OBXT) 4.444 manual transmissions for $150 through a local group. One has completely unknown history, but still! I bet with a little digging, you could find a nice local transmission for 300 or less. Sure, it's a pain of a job, but if the car is in otherwise good condition, you will add thousands of dollars to its resale value. That's easy math if you ask me. You could probably find a shadetree mechanic doing side work in his garage and pay him to do it, and still come out way ahead.
No small project to split the cases and replace the bearings, and there's a lot of "while your in there" things to consider on a 235k mile trans. I've had many manuals apart, and put a couple back together and used them. I would definitely not bother, not with how easily a good used transmission can be sourced.
Could be throwout, but also absolutely could be internal to the transmission. I would get the car up in the air, running in neutral and poke around with a stethoscope. See if the noise is coming from in the bellhousing (listen right on the clutch fork), or from the case itself. Change the fluid and see what the drain plug looks like.
Well, small update. She had the fluid changed at a local-to-her independent shop that she frequents, she brought in Subaru CVTF A few days later, she was driving, and noticed a loss of power on the highway, and when she pulled over, the engine had stalled. She had to navigate across a lane of traffic and an entrance ramp, so she's not sure if it stalled on the move, or when she stopped (like a stuck torque converter). But, after cycling the key, it started back up, and drove normally. My dad read the codes later that day, and found P0700 (AT abnormal) and P0841 again. She's visiting me again this week. First thing I found out, none of my scan tools will read the live data for that sensor. I have a Carista ELM327 bluetooth adapter that I use with my phone, I have a couple basic apps, but ActiveOBD is a Subaru specific one, with which I can read torque converter lockup, AWD transfer, transmission temp and more. I also have an Innova 3170RS, and FreeSSM. So, then I was left with the options to buy a better tool to test it. Pay the dealership to test it. Or, just throw the $150 sensor in. The local dealership had it on the shelf, and said they use them in the shop about once a month. If it were my car, and only driven locally, I'd drive it and wait for symptoms to worsen. But it's my mom's, and she drives all over the state, a breakdown in the middle of nowhere would be far more costly. So, I did what I hate to do, and loaded up the parts cannon. Yesterday I put 5 more quarts of Subaru CVT fluid in (what came out was still pretty brown) and the secondary pressure sensor. With such intermittent symptoms, only time will tell if that was the chicken or the egg. I drove it to work today, and it's showing it's age. Not sure what the future is for this car, it seems like a pretty nice car, but with a salvage title, considerable oil consumption, and a failing CVT, it's probably not worth much, and not worth fixing.
1990 BRAT EJ swap and Other stuff.... (Chilean Way)
Numbchux replied to Rafavidmess's topic in Subaru Retrofitting
small clarification In the late '90s, they transitioned to a single 3-wire sensor, which still performed like 2 separate sensors (2 wires for the ECU, single wire resistance-to-ground for the gauge). And then around 2008, they transitioned to a single 2-wire sensor only feeding the ECU, which then outputted a signal via CAN to the gauge cluster. Yep, you can use your EA81 sending unit with a little modification. Or you can wire a resistor in to modify the EJ signal for the EA dash (I know this works on the EA82s, I think the EA81s as well). That's in my write-up. Or, just wire the EJ sensor to the EA gauge, and it will read about 1/2 what it used to, but will still give you some information. -
If anyone has any insight, or, I'll just document what I find in case someone is looking in the future. My mom's 2012 Impreza 2.0i Premium. 216k miles, original engine and CVT. Had the torque converter solenoid fail last summer, and the fluid was a bit brown, so I did a drain and fill then (probably 190k miles), and we did another at about 80k, when I was working at a dealership. The AT Oil Temp light was flashing one day, I scanned it about 2 days later (no lights on) and it had a stored P0841, as well as a U0100 (CAN signal error), C1431 (AT abnormal), and C1422 (VDC Interrupted). From the Subaru FSM: First 2 steps in the diagnostic procedure is to check the condition and level of the CVT fluid. I think she's going to have another drain and fill done (she does not live locally to me, so I probably won't see the car for another couple weeks). And then there are a few tests using the SSM to check the pressure readings from the sensor under a few conditions (Idle in park, 3k rpm in park, torque convert stall at WOT). Beyond a fluid related issue, the procedure basically ends with the sensor, wiring, or transmission causing the fault. The secondary pressure sensor is externally mounted, threaded in towards the rear of the left side of the transmission. By her VIN, part #31878AA020, with an MSRP of $148.17
I don't quite follow what you're doing. But, the low range gearset is on the input shaft of the transmission. The EJ cases are cast with the cavity for the gears, but they are not machined out for the bearings and such. It would take quite a bit of precision machining to convert a single range case to dual. The 4WD versions have a very different output shaft/front pinion arrangement. You could use a FT4WD front pinion gear in an EJ output shaft, and then have the locking center. But if you don't care about unlocking, it would be far easier to just weld the EJ center.
The fact that it's felt in the steering wheel has me thinking it's not the transmission. I just replaced a CV axle with a completely failed inner joint, and it could not be felt in the steering wheel any more than anything else (it shook the whole car....). I've been chasing this vibration for years, and because it wasn't felt in the steering wheel, didn't even occur to check the front axles. Boot was fine, and it only happened once driven at least a few miles. Does it change at all when on or off throttle? Brakes? Pull to one side more than the other?
I've put a hot shot relay in a couple subarus with no trouble. As long as it's triggered by the factory switch, it should all be fine. The system doesn't know if it's directly triggering the starter solenoid, or a relay. It's possible that the original problem was a failing neutral/range switch or wiring to it, and you are now getting a second symptom.
Ea82 to Ej22 Swap Questions
Numbchux replied to ontherun987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A lot of variables. Be more specific with your questions, and you will get more specific answers. All EJ engines share essentially the same basic dimensions. So they will all physically fit almost identically (with the exception of the last few years of the EJ253, 2010-2012 or so, where the motor mount configuration changed a bit). 2.2s were made 1990-2001. So the difference comes in the electronics, which can be changed. But ASSuming you want to use the ECU and wiring from your donor car (cheapest option), the rule of thumb, is the older ones are simpler, and the newer ones are more complex. 1995 (for the 2.2) added OBDII, which makes them far more easy to diagnose, as any off the shelf code reader can connect to it. But much newer than that adds fuel tank sensors and stuff that will be hard to replicate/bypass in the new chassis, so you will likely always have trouble codes. -
Yes, both fans should cycle in test mode. I would use a test light or multimeter to backpin the fan connector while in test mode and see if it's getting power. Might just be a failed fan. The fans really only make a difference under 15-20mph. So with those symptoms, I would question the gauge reading. Might be worth plugging a code reader in and seeing what temp the ECU sees (separate sensor), and/or using an infrared thermometer to test. Might be a grounding issue causing both problems....
Knock knock, your new engine is calling. I bet you have very little oil pressure, as it's all blowing out past your rod bearings. Thicker oil and/or a high volume STi oil pump might buy some time. If the guide around the crank pulley is too tight, it will rub the text off the back of the belt. Was this clearance set correctly? Mitsuboshi makes belts for most Japanese OEMs. They do not sell them through the major parts stores, so many people don't realize they exist, but if you start watching, you'll see their name, or logo, on most belts (just did one on my Honda Odyssey yesterday, the original belt said Honda on it, but had the Mitsuboshi logo). Gates used to use quality Japanese bearings, but started phasing lower quality ones in probably 10 years ago, becoming increasingly more common. You don't have to search very hard to find wrecked engines due to Gates kits. With a little homework, it's not hard to find quality Japanese components from reputable sellers (NOT Amazon or eBay, lots of counterfeits) for a reasonable price.
The tensioners I've had fail were entirely unaffected by temperature. I supposed it's theoretically possible that it's only failed a little bit, and it might change as it warms up, but I would think as soon as it cycled through it's range (which is what the noise is, the piston bottoming out and the housing hitting the block), the fluid would be gone, and it would be spring only.
