Everything posted by Numbchux
Overheating, radiator fans question
Numbchux replied to jeffroid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, both fans should cycle in test mode. I would use a test light or multimeter to backpin the fan connector while in test mode and see if it's getting power. Might just be a failed fan. The fans really only make a difference under 15-20mph. So with those symptoms, I would question the gauge reading. Might be worth plugging a code reader in and seeing what temp the ECU sees (separate sensor), and/or using an infrared thermometer to test. Might be a grounding issue causing both problems....
Mystery Noise - EJ25 Engine Knocking, But Only at Temperature & Under Load
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXquick google search turned up this
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe saw many at the dealership. Causes a misfire. Wasn't uncommon to have cars towed in from other shops that had thrown a coil, injector and more at it trying to "diagnose"/repair a misfire, and it was a dropped guide. Never heard one make a noise.
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKnock knock, your new engine is calling. I bet you have very little oil pressure, as it's all blowing out past your rod bearings. Thicker oil and/or a high volume STi oil pump might buy some time. If the guide around the crank pulley is too tight, it will rub the text off the back of the belt. Was this clearance set correctly? Mitsuboshi makes belts for most Japanese OEMs. They do not sell them through the major parts stores, so many people don't realize they exist, but if you start watching, you'll see their name, or logo, on most belts (just did one on my Honda Odyssey yesterday, the original belt said Honda on it, but had the Mitsuboshi logo). Gates used to use quality Japanese bearings, but started phasing lower quality ones in probably 10 years ago, becoming increasingly more common. You don't have to search very hard to find wrecked engines due to Gates kits. With a little homework, it's not hard to find quality Japanese components from reputable sellers (NOT Amazon or eBay, lots of counterfeits) for a reasonable price.
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust looks like an old belt, to me. Certainly time to change it. But if it were really rubbing, it would be far more badly damaged. That just looks like the scuffing from the crank guide. Aisin tensioner, Mitsuboshi belt, and Koyo or NSK idlers only for me.
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe tensioners I've had fail were entirely unaffected by temperature. I supposed it's theoretically possible that it's only failed a little bit, and it might change as it warms up, but I would think as soon as it cycled through it's range (which is what the noise is, the piston bottoming out and the housing hitting the block), the fluid would be gone, and it would be spring only.
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRod knock comes from connecting rods, not pushrods. EJ251 is not a rotary engine, so they absolutely do have rods.
Numbchux replied to dirty_mech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like rod knock. Piston slap goes away as the engine warms up. Timing belt tensioners are unaffected by engine temperature. Rod knock gets worse as the engine gets hot. Put a real oil pressure gauge on it, and see if your oil pressure drops as the noise happens....
EA82 to EJ22 Couple Wiring questions
Speed and neutral signals both help with drivability, preventing the engine to stall when coasting and such. Not a major change, but super easy to hook them up, so just do it. Yes, both fan signals are ground signals to trigger relays.
Oil Consumption '14 Forester (I know the Usual Problems, Not Looking for an Explanation)
Numbchux replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe try a different dealership. Also, spend as much time on the freeway as possible during the consumption test. I know when I worked at the dealership, we would have claims denied (by Subaru), and then a few days later, SOA customer service would call us and have us Goodwill a repair. So a call to them would certainly be an option. Quick google search turns up 1 (800) 782-2783
mid mount brumby Very hard to start
Numbchux replied to docmidBratt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlinking CEL, Test mode? My first EJ swap cranked a lot before starting. I didn't have the start signal wired to the ECU (12v while cranking), this changes the enrichment (choke) while starting. I bought a dry cell battery and a block heater, as it would struggle to start so badly in the winter....then I hooked up one wire. But I think I had a code for it.
2.0 impreza oil light
Numbchux replied to rustfarmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, technically here in MN it's a "Prior Salvage". True "salvage" stamped titles cannot be issued plates. The inspection to convert the title from "Salvage" to "Prior Salvage" has nothing to do with safety. They just want to see the receipts for the major parts purchased (to verify that nothing is stolen). Whatever the verbiage. Once it's totalled, no warranty of any kind applies. Recalls, however, still do (had the Takata removed from our '04 VDC).
Numbchux replied to rustfarmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, the oil consumption suit happened about 6-7 years ago (right in the middle of my time at a Subaru dealership), extending those engine warrantees to 100k miles. And yes, the rings in the replacement short blocks are tighter, and fuel mileage will suffer. My mom's 2012 Impreza has a salvage title, and so is not covered. It's now over 200k miles, and I think burning a quart of oil every thousand miles, or so. And it's intermittently throwing a P0420 code (cat converter efficiency, likely due to all the oil gone through it over the years). And yes, I've heard from several sources I trust to switch to a synthetic 5w30.
Turbo??
Must be your first car Or, maybe you got a reliable EA82. Thank every deity you can think of, and don't mess with it. It will be more expensive, more work, slower, and less reliable than a non turbo EJ Not a chance that it has the same compression ratio as a turbo.
JDM Engine replacement: Experience? Good/Bad?
Numbchux replied to Skizix67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAFAIK, the warranty for a DIYer is generally 30 days, and they just give you another engine. And they expect to get theirs back in exactly the condition it was sent. As such, I waited to order mine until I was 100% ready to put it in. I had all my gaskets, timing components, etc. on hand. The old motor was out with the intake manifold off and ready to use. So I swapped everything over (kept everything I removed from the JDM engine in a box) and was ready to start test driving about 3 days after it arrived.
Numbchux replied to Skizix67's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've bought one, and plan to buy a couple more. I just bought on eBay, paid with a Credit Card through PayPal. This gives me 3 separate avenues for accountability/charge dispute. Read the sellers feedback history, make sure they have a decent history, and have been selling engines for some time (I noticed at least one seller that had a decent rating, but almost exclusively on small parts...). Best practice is to swap the intake manifold and all wiring over from the old engine. The link that @idosubaruposted is for a bare, new shortblock. This will have a 1 year warranty. Call your local dealership and ask about remanufactured shorblocks. These are about the same price, but come with oil pan, pump, water pump, thermostat, etc, and come with a 3 year 36k mile warranty.
Cruise Control not working & check engine is one
Numbchux replied to Kris G's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCruise control is disabled whenever the check engine light is on, in those cars. Pretty long and well-documented diagnostic process to the P0420.
JDM vs USDM gaskets, is there a difference?
Numbchux replied to yoyo7015's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be largely the same. Use STi Head gaskets, just like the USDM 2.5s.
Timing belt/waterpump kit, which one??
Numbchux replied to punx2400's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAisin is the way to go if you want a "kit". I use Mitsuboshi belts, NSK or Koyo bearings, and an Aisin tensioner. Requires more homework to find all the right part numbers (I usually look up OEM # by VIN, and cross reference from there), and sometimes ordering from multiple sources (I've been using CarID for the last few sets, but I think I've gotten the tensioner from RockAuto). Don't think I've bought a water pump in 10 years or more...
Reverting 6 lug to 4x140 then adapter to 4x100?
I've heard of people machining/redrilling the stock hubs to 4x100. That's probably your best bet, if that's the size you want. It gets difficult as it begins to clash with the bosses for the rotor mounting bolts. You're currently running a 7" wide wheel with 4.5" of backspacing (meaning 1" of negative offset!), yea, that's not going to fit well. A stock Toyota or Nissan 6" wide wheel will fit much better. It is certainly possible to have new hubs made, but my understanding is cutting the splines is extremely expensive. Someone had a run of 5 lug rear hubs made not too long ago. They were manufactured overseas in large-ish quantities, and they were still spendy. I suspect having 2 pairs made (they are different front and rear) will be many many thousands of dollars.
Numbchux replied to rustfarmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not sure replacing the part would have a different effect. It's my understanding that they are very sensitive. My mom has said many times that she can only put in about a 1/2 quart when the light comes on before it's at the "Full" mark. She keeps a paper funnel tucked in next to the battery....
Swap 2002 31000AE800 transmission in place of 31000AE640? Trans swap differences 3.0 and GT+ Baja.
Numbchux replied to afewsubarus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOff the top of my head, 4-cyl AT Outback and (I think) GT are 4.444 axle ratios. H6 Outback is 4.111. So you might have to swap rear diffs, as well. www.car-part.com is a very useful tool for finding used parts.
Transmission-to-firewall strut
Numbchux replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen many broken, especially on crashed cars, but not always. Get a new one. I bought a Subaru one for our Outback, so it couldn't have been too expensive. And they are available aftermarket.
Numbchux replied to rustfarmer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, that car has an oil level light, and an oil pressure light. If the oil pressure light comes on on the freeway, the engine is done. If it flickers a little bit at hot idle, you might be able to save it, but at rpm and load....no. We discovered with my mom's 12 Impreza that the level light comes on pretty early, sometimes the level doesn't even read to the low mark on the dip stick, and only needs about a half a quart to read "full". Hers is a bit of an oil burner, so she's gotten used to carrying oil and a funnel.
Timing Belt, the right way.
Numbchux replied to jakebot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEM water pumps very rarely fail. Not a chance I would replace it at 120k miles. I buy a Mitsuboshi belt, NSK idlers and Aisin tensioner separately. Anything beyond that would be as-needed.
