nncoolg last won the day on April 26 2020
nncoolg had the most liked content!
About nncoolg
- Birthday 05/19/1983
Location
Gold Coast, Australia
Interests
well Im surfing here so...
Occupation
unobtainium procurement
Biography
self confessed champion
Vehicles
sshhhh...its a secret!
Recent Profile Visitors
nncoolg's Achievements
USMB is life! (4/11)
24
I have a Megasquirt MS3X in mine, you can find all the info here :
...looking for one, thanks!
MPFI head revisions - Gen1 Gen2 Gen3? Try Gen8+
nncoolg replied to Ibreakstuff's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All XT6 Owners! (Feeler)Clear front markers
nncoolg replied to jdmleggy97's topic in Old Gen.: 80's GL/DL/XT/Loyales...
By the way, I reckon clear side indicators would be awesome if these go well! -
I'd be in if the quality was good! Can I spread this to the facebook page? -
FYI, new 4x140 wheels are available
nncoolg replied to Bratastick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ah, are they still available? -
Its mentioned above that WRX rear lines are LONGER than STI ones, you sure that isnt the other way around? Does anyone have some specs of the stoptech lines or a catalog with measurements? Id be keen to find out...
Because our Subies are blessed with such a wide stud pattern, the hubs are quite susceptible to getting bent ever so slightly. This causes lateral run-out in the rotors which in turn will cause disc thickness variation and cause pedal pulsation. Even the way the hubs fit on the car can make a difference - cv stub not straight, centering cone out of shape, etc. The only way to fix this problem completely is to have the rotors 'matched' to the suspension by getting them turned on the car with a ProCut On-car Lathe. If the machine is setup correctly you can guarantee less than .0005" (half a thou) lateral runout on your rotors. Do a google or youtube search and you will see what I mean...
Knock sensor. Bypass it with a resistor.
EA82 timing belt cover difference on # 1 & 3's side
nncoolg replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
series 2 is blacker? -
Removing Egr and Canister Purge Solenoids
nncoolg replied to grandam88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
...specifically when the ECU switches the Purge Vac. Solenoid on: Has anyone done any tests? -
I'm keen to learn from anyone that has experience about how the purge system works... -
turbo conversion considerations re vacuum tasks
The L series has that little white vacuum can behind the Strut tower (RH side on our RHD cars) for the HVAC, so all good if It's an L series, if it's an MY series, steal one from an L series
