Only 3 voting days to go!
http://autos.winnipegfreepress.com/index.php?action=rankmyride&step=details&id=151
Last bump before it's over. I'm counting on you to help put me over the top.
Remember to vote once a day per IP address (eg. once from work and once from home)
You can vote once per day per IP address. If you have a way to change your IP then you can vote multiple times per day.
I'd be voting non-stop but I fear the people running the contest will be watching out for patterns like that.
Also, I've seen instances where the page fails to load in IE. Loads fine in Firefox.
Apparently they called my car a rust bucket!
Sure there's a bit of rust but, all things considered (mileage, yearly driver), it's better than most cars of that vintage.
I think I will need a lot more votes coming in daily to win this thing now.
I'll share...come to Winnipeg and boose it up on the boat ride with us as part of the winning prize.
BTW, if you have a dynamic IP (like mine) you can renew and vote multiple times a day.
You may want to look up the term "Heat Soak".
Using a voltmeter to check your ignition circuit will help you "probe" the issue.
In the case of the SVX the ignition switch itself wears out and you can lose a lot of voltage there. Sometimes the neutral safety switch as well (in the case of autos)
I entered my SVX in a local public voting contest but I need as many votes as I can get if I stand any chance of winning.
The site is http://rankmyride.ca and the direct link to my car is:
Simply click the link and, when it loads, click "5" (or whatever you feel like voting)
It won't help me to vote "1" for other cars.
You can vote once every day per IP address.
I was ranked as high as 4th but currently am in 5th place. Every vote helps and is greatly appreciated. Thanks for your time.
