97subaruGT
About 97subaruGT
- Birthday 04/03/1979
Contact Methods
AIM
EsunburnE
Website URL
http://
Yahoo
Ryundken
Location
Staten Island, NY
97subaruGT's Achievements
Advanced Member (3/11)
10
Change the ignition coil. I had a similar issue with Cylinder 2 on humid days. Spend 80 bucks, it takes 10 mins to bolt on. After the fact, i noticed that cylinder 2 plug wire had a lead that retracted into the rubber housing. Maybe I pulled on the wire too hard and the tip backed in so there was not clean contact between the coil and the wire. Check for that too.
Is it a factory alarm? On my 97, there's a black box about 10 inches above the left foot rest pad, under the dash. It's a black square box around 5 inches across mounted on the left side of the firewall, under the dash. THere should be 2 connectors going into the top of the unit, one with 1/2 dozen wires and one with about dozen or so. Disconnect the big jack and that should disable it. It's been a while since i disabled mine cuz it's was making the flashers blink after a dead battery.
Had a similar issue on my 97 Legacy. Turned out it needed new Ignition Coil / Wires. It would stumble only when cold for the first few mins when it was still partly humid in the engine bay. Once it warmed up, the water evaporated and everything was fine. The stumble also went away once the engine was revved. When I was replacing Ignition Coil ($100 at dealer), I noticed that Cylinder 2 wire had its lead retract into the the rubber sleeve. Looked like I pulled on it too hard and the lead retracted. Well, anyway, once that was replaced, back to normal. I would check those parts to make sure.
