97subaruGT
Everything posted by 97subaruGT
Change the ignition coil. I had a similar issue with Cylinder 2 on humid days. Spend 80 bucks, it takes 10 mins to bolt on. After the fact, i noticed that cylinder 2 plug wire had a lead that retracted into the rubber housing. Maybe I pulled on the wire too hard and the tip backed in so there was not clean contact between the coil and the wire. Check for that too.
Is it a factory alarm? On my 97, there's a black box about 10 inches above the left foot rest pad, under the dash. It's a black square box around 5 inches across mounted on the left side of the firewall, under the dash. THere should be 2 connectors going into the top of the unit, one with 1/2 dozen wires and one with about dozen or so. Disconnect the big jack and that should disable it. It's been a while since i disabled mine cuz it's was making the flashers blink after a dead battery.
Had a similar issue on my 97 Legacy. Turned out it needed new Ignition Coil / Wires. It would stumble only when cold for the first few mins when it was still partly humid in the engine bay. Once it warmed up, the water evaporated and everything was fine. The stumble also went away once the engine was revved. When I was replacing Ignition Coil ($100 at dealer), I noticed that Cylinder 2 wire had its lead retract into the the rubber sleeve. Looked like I pulled on it too hard and the lead retracted. Well, anyway, once that was replaced, back to normal. I would check those parts to make sure.
It's your factory remote door lock system. Under the dashboard, middle of the driver's side, there should a be a bunch of wires with one kinda separate with a small black button on it. Insert the key in to ignition, turn it to ON position and press the button. That will reset the factory system. If you can't find the button, on the left of the footwell, toward top left there is a small (5x5) black box should be mounted on the "wall". There are two thick wires with wide jacks running to it. If you don't use your factory door lock system, pull those two wires and the clicking will stop.
Hey guys and gals. 97 Legacy, 160k miles. I'm getting a vibration in the steering column and pedals when I hit the brakes. I replaced my pads about 16K miles ago and at the time, got new front rotors. The shop said my rear rotors were still ok. Does this mean now I need rear rotors? Anyone have a part number so at least on ebay I can find something that fits? At the dealer, they're around $90 each..a bit pricey but not bad since the shop wanted to sell me the front rotors for $150 each...ouch!! I went to the dealer and got 2 for a total of $150. Any ideas on diagnosis would be appreciated. So far, I have no squeal and no other brake problems...braking power does not seem to be less than before. Front rotors are very smooth. Rear are not as smooth but no glaring defects either. Any way to tell if the rotor is warped? THanks.
1. Engine shake - i get the same thing in my 97 Legacy. It's most noticeable between 60-75 mph. I think there is a TSB out from Subaru to fix this - install a dampener on a front transaxle. 2. Removing the headlamp unit - Unclip the front grill - the little clips on top and slide it out. There is a screw behind the grill you'll need to unscrew and 2 screws on top of the headlamp that mount to the frame. Unplug the headlight and corner/turning signals. You can slide the headlight unit out but watch out on the left side, there is a stud that is inserted into the fender/frame so you may need to wiggle the headlight out with a little force to get it to come out. Good luck.
