blacklabel
About blacklabel
- Birthday 08/03/1986
Contact Methods
Website URL
http://
Location
Olympia, WA
Interests
Music, cars, video games
Occupation
Marine services/ dock worker
Biography
I am determined to get my GL driving
Vehicles
1991 Legacy L Wag 5sp 4x4
blacklabel's Achievements
Advanced Member (3/11)
10
Boiling radiator fluid?
blacklabel replied to blacklabel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The engine temp gauge isnt working, and the engine is getting a bit hotter than it should, but not to an extreme point. I wouldnt be suprised if the gaskets are shot. Before I had the subie she was sitting in a driveway for a while and there was a period of neglect since she's been in my possesion. Does anyone know where I can find decently priced gaskets and seals? -
My '87 GL Wag is currently facing clutch or tranny problems, so I have been making sure to be running it as often as possible for obvious reasons. The other day I was running her for a good hour or so and when I went to turn off the engine, there was a boiling noise coming from the coolant resivoir. The engine didnt seem too hot but it could have certainly been cooler. My thermostat hasnt been working even after replacing it(the gauge doesnt respond). Does anyone know what could be going on? I got into a fender bender which punched a hole in my radiator which got replaced with a rebuilt one, could it be a clogged line?
My '87 GL wagon does the whole de-acceleration exhaust crackle/popping. I thought it was backfiring but after taking a closer look I found that my exhaust is just shot to ************. Still working on replacing it...:-\
I'm pretty sure my clutch is shot in my 87 5sp GL wagon. I was wondering what mileage others may have had problems with their clutches or trannys. I know alot of problems can be pretty relevant to the mileage. I dont know the exact mileage since I havent been in my car for a couple years due to its lack of working. Its just chilling out at my moms place, waiting to be resurrected.
Contemplating a new weber carb...
i'm still a little confused about the different kinds of 32/36 carbs. theres the DVG, DGEV, DGAV, and DFEV. I thought that my '87 GL Wagon 5sp. was a manual choke but I'm not positive. -
I'm thinking about replacing the stock carb with a Weber 32/36 DGV but im not sure if it will be a clean swap. Does anyone have other carb reccomendations or know where to find decent deals? http://www.webercarbsdirect.com/32_36_DGV_p/22680.005.htm
My '87 GL has been having electrical problems. The most obvious problem is that the cd deck will randomly not work at all. I noticed that a power cable from the deck is connected directly to the posotive battery cable. My left headlight got a rock chip, thus allowing moisture into it and shorting it out. Could this be causing problems with my whole electrical system? I was thinking about going to pick-a-part and getting a new(old) headlight fixture. The car has spent some years in a driveway so I think that I may need to just replace some of the wiring due to moisutre and whatnot.
'87 GL 5-Speed Transmission/Clutch Problems
it does shift when the car is off. another thing that has been wierd about the car is that i dont have to push the clutch in to start it. I know that in most 5-speeds you need to have the clutch engaged to start the car. is replacing the clutch yourself very difficult? -
My '87 GL Wagon totally shat out on me and I dont really want to spend the money on taking it into the mechanic to find out that I could have just fixed or adjusted something myself. It all started when I was having troubles shifting into 1st-3rd gear. Unfortunately I kept driving with it like this until it just couldnt shift into 1st at all (lazy me). I finally got a little money and decided to start from the cheapest fix by replacing the clutch cable. This helped a bit but when I force it into 1st the car dies. Does anyone know if this is a common Suby problem and if I can get it fixed fairly easily?
Are these compatable with my car?
this says that these are compatable with my car. what do you guys think? http://www.streetbeatcustoms.com/streetbeatcustoms/nol1156405.html?engine=bizrate&amount=.21&keyword=NOL1156405-SY -
does anyone know where i can find a good rebuild kit for an 87 gl wagon 1.8L carb?
