5
Everything posted by Twitch de la Brat
EA82 Wagon featured in a video game?
Twitch de la Brat replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nose looks kinda like a Camry, but the tail definitely is a 3rd Gen. If you penciled in the grille, I think you could get away with calling that a 3rd gen wagon. Twitch -
They're selling you a job you don't need and could figure out on your own. Check the fuel pump. Does it buzz or whine when you turn the key on? And better yet, does it spray fuel? Pull a plug after cranking and smell it/test it for fuel/oil/antifreeze (touch it to a paper towel and see what color the residue is). All this could be done in a matter of minutes and possibly save you a ton of money. Twitch PS: To be on topic, I blew a rear speaker in my XT, go me! Who knew 20 watts could pop a speaker?
EA71 Pistons
Twitch de la Brat replied to Twitch de la Brat's topic in Historic Subaru Forum: 50's thru 70's
Any news yet? I still need pistons... Twitch -
Idasho, my BRAT ran on about a 50/50 mix of diesel and gas once before Apparently my dad forgot that gas cans are red and his diesel can is green. He borrowed the BRAT, made it 3 miles down the road and the poor thing started to choke and die on him. He couldn't figure it out until diesel vapors eeked from the fuel filler hose Ran like a champ after he countered the diesel with an even mix of gas... Subynut, that scares me that K&N would include that with one of their kits. If you wanted to go on the cheap, a chunk of plumbing pipe would be a suitable replacement... Twitch
Where does this wire go?
Twitch de la Brat replied to bluebonnet81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check for vacuum leaks. And yes, I was going to say it sounded like the oil pressure sending wire. Twitch -
Return of the Pedal Box monster
Twitch de la Brat replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
I did a home made repair on mine. Bought some angle iron from the hardware store and welded it into every corner on the box. Then shot it with leftover "chrome" paint we somehow acquired over the years. Couple bucks for some angle iron was a lot cheaper than $15 a piece for clutch cables, plus eaten synchros. Twitch PS: I'll see if I can find any of my pics of it -
My cars are usually two tone after a good rain/rally session So I'm working at NAPA now, making better money than I was, and when I was driving the XT in the rain, I noticed how easy it is to light off the front tires Got an offroad show going on at work Saturday and I'm going to try my hand at the teeter-totter in the XT. I'll get pix Twitch
Ah, I didn't realize how locked down the platform really is. And the HDMI out for visual isn't that big of a deal, thankfully, as smaller and smaller displays are supporting the HDMI standard. As for the "niche" thing, the manufacturer wasn't aiming for that, it just grew around the product, so they went with it. Gotta follow the money trail. Anyway, they were aiming for a small, ARM based SOC which was easily accessible for most anyone to make a computer out of. I'm pretty sure the creators were part of the open computing initiative. Anyway, you're right, Pi is meant more for media and entertainment than menial controller tasks. Arduinos are looking better and better... Twitch
Actually AMD as Intel is a modified x86 processor, but anyway, I was thinking with the main CPU being an x64 and then the subsidaries being the low level processors you speak of, you could remap the driving computer on-the-fly between changing songs And frustrations are a thing of the past for me with Subarus, I've gone straight to threatening the car with a multimeter and a handgun And the flash based memory storage system would handle being drawn on no problem as you mentioned Twitch
That's what I meant. It could be sourced for initial bootup maps (tables) and possibly for trouble codes, but there would be a RAM bank that the processor would load everything onto for operations And if your flash drive started getting corrupted, you could just load another one with your mapping/programming and go from there. Twitch
Memory is cheap. You can buy a 1GB flash drive for a couple bucks, even cheaper if you buy in bulk. And those original ECU's were making do with a few MB, if that. So memory constraints are nothing. Hell, RAM can be had for dirt cheap as well, so there is little to no memory constraints to be had, whether its active or storage. Twitch
I've read your entire thread, and I'm a total programming n00b at best. I'm just curious if a centralized processing unit with good power would be better, as in a Raspberry Pi. They can be had for $25 and are pretty stout little SOC's. I'd be worried about stability, but their direct interface with USB would make updating the code cake, as well as being able to create and load your own fuel/ignition maps easily. And I'm sure that processor has enough oomph to run most any low level code you throw at it, even making on-the-fly adjustments. Just a thought. Twitch
EA71 Pistons
Haha, ok Ivan. Let's see how it all goes together. I'm wondering how the skirts effect everything as well... Twitch -
Hey SmashedGlass, lets hope your engine doesn't leak worse now that you cleaned it I readjusted my headlights last night when I got home because I was sick of not being able to see. Now my high beams actually broadcast a decent distance and my headlights aren't cross-eyed. But I realized my driver's side bulb is in way worse shape than my passenger side. So I'll be getting silverstar's when I get a chance. Ordered NGK wires from the factory for $22 after freight (through my work) and hopefully it'll help kill this (insert long string of expletives) misfire! I'll be taking a brass brush to the contacts in my cap if necessary. But this is getting frustrating. On idle I'm getting about 600-650RPM and it should be up around 800. And the total lack of bottom end is pissing me off as well. Spark plugs look ok, a little lighter than desired, but not bad. V power's, so it should be fine. I'll upping to a platinum if this keeps happening though. That's all for now folks.... Twitch PS: HOLY HELL WE HAD A HELLACIOUS RAINSTORM THIS MORNING.
EA71 Pistons
Thank you Crazyeights. That will help immensely. Twitch -
Rally of course, the Wedge doesn't have the tires available for proper AutoX. And if the EA82T doesn't have the oomph, I think my wagon may be able to take you with all that torque its gonna have But I think your experience will overtake any advantage I may have. Twitch
