Everything posted by Twitch de la Brat
What to get on my License plate?
EVOEATR GRNYCAR FAST GL SUBROKT 1FASTGL But SUBRDAV I think is your best bet. Twitch
96 VW Jetta III
Well, he got his sights on a gti tranny, so hopefully he can buy it and get it installed soon. I'm getting kinda sick of playing chauffeur... Not to mention I was a clod and smoked the clutch in my BRAT But that's a whole 'nother topic. Twitch
1999 Sebring Coupe (Mitsubishi) - ignition failure
Heh heh heh... You had to know that was coming I'm glad you got figured out. And good to hear you got a loyal customer out of it too Lets hope you keep getting mitsu customers Twitch
Holy subaru god's
I love that color actually. Its a nice shade of Brown. Congratulations on getting it. $2700 is a pretty good price, esp considering you have practically every receipt since the car was bought. I highly recommend you keep exactly as it is. It may not be too valuable right now, but in 10 years or so its probably gonna be a valuable as an EA81 turbo coupe. Oh, and do the same thing as that little old lady, keep every receipt, do everything at the dealer, or reputable mechanic, and that baby will be worth a mint in the future. I wouldn't care if its an EA82T. If anything has been maintained like that, I would buy it. Even if its a Maserati Bi-Turbo And thank you Qman, I hate to see a good wagon thread get trashed with bad commentary. Twitch
That is awesome man. Good for you. I hope he's appreciative and you get to hear about his reaction. Twitch
Forester Wheels Bind in a Turn
Ok, if he's a certified Subaru mechanic I would trust this info. I wasn't sure if it was a viscous center diff or a clutch pack. If he says its a clutch pack, then it may be your clutch plates or the duty C solenoid causing the issue. Its not too uncommon to see the clutch plates fail after 150k-200k mi, nor is it uncommon to see the duty C solenoid bite the dust either. So if you're going to do it your self, pull the tailshaft housing and inspect the plates for excessive wear. If they appear to be fine, I would definitely check out the duty C solenoid. But if you're having a mechanic do it, I HIGHLY recommend taking it to a certified Subaru mechanic or at least a Subaru specific mechanic. Twitch
Are all of your tires the same size and tread wear? If you're running odd sized tires, your viscous coupler would be working while you driving normally. After a fair amount of driving with odd sized tires, the coupler will get hot and lock up the center diff. That's the reason the car will stall out on low speed turns. The center diff isn't allowing the tires to rotate at different speeds. Twitch
93 Impreza 5 Sp FWD Trans Interchange?
Twitch de la Brat replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBoth the stubs and the axles are 23 spline. When you switch to another transmission other than a 93 FWD Impreza, you will need to get AWD transmission axles or auto axles. The wheel hubs are just the EJ setup, so that won't change. Twitch
Now, does it only slow down at slow speeds, or at all speeds? If it seems to dog at all speeds, check your tire pressures all the way around first. If any are low, then air them up appropriately, I believe Subaru recommends 27-32 psi per tire. Then do donuts on gravel, as you can listen and see if you have any wheel not slipping enough. If you do have an issue with a tire not slipping enough, it could be torque bind. I'm not sure, but I believe those transmissions have a clutch pack that runs the AWD. I'll try to find a wiring diagram to confirm this. If it does have a clutch pack that runs the center diff, get ready to order a duty C solenoid or clutch packs. They should run somewhere between $100-$150 from the dealer, or you may get lucky and find it at an aftermarket dealer for less. But if its like the early EJ 5spd with the viscous center diff, I would be looking for a used center diff, as they rarely fail. Junkyards are the best option for this, either a U-pull-it or a They-pull-it, just have to make sure they have what you need. I'm not sure if you can swap a viscous center diff into a clutch pack style transmission. It would be a good time to investigate, as you have to pull the tail housing off the transmission anyway, if it is a bad center diff. Twitch
Twitch de la Brat replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNow are you replacing the engine or the transmission? If you're replacing the transmission, then you'll need new axles, as the FWD 93 Impreza axles are 23 spline rather than 25 like the majority of the EJ. As for the engine, I believe you can use everything that's already on your current engine and be just fine. Twitch
BRAT Meet **post your photos**
Well, unfortunately I'm unable to offload the pictures off my phone right now (piece of crap) anyway, I had a great time, made it back just fine Almost got zinged with a ticket on way home Thank goodness the cop was in a decent mood :-\ Those guys were out in FORCE this weekend. Saw one going after another guy going the opposite direction. I had a great time! But I probably won't be going over a day early again. It gets kinda lonely out there in the boonies... Overall I had a great time. Maybe next time I won't be so broke :-\ and neither will my BRAT Thanks again to everybody who helped! And I hope to be there next year! Maybe on a less policed weekend... Twitch
Last post before the trip, hope nobody needed to get a hold of me :-\ See Y'all there, rain or shine, I will be there. Twitch
suggestions
Wow, this is just after Brian joined... He got down to business quick As GD said, good job for searching, but check the dates of the posts before you reply... Mostly so you don't sound like an idiot Twitch PS: By the way, how did that go?
Got my BRAT running and ready to go!!! I'm ready for a road trip So, you guys better be ready for the BRAT meet, cuz I'm coming Twitch
Type of tap to repair threads
To answer your first question, you can clean up threads with a slightly different tap, as long as they are just starting threads and not the whole thing. Such as you can use a 12x1.5 tap to clean up some 12x1.25 threads. And if you wish to get just a straight 12x1.25 tap, good luck. I've tried to find one for myself, and they are next to impossible to get. As for your second question, if you are going to drill it to 1/2 in and re-tap, use a fine threaded tap. 12x1.25 is considered extra fine, so a fine thread standard should be ok. Twitch
Build Thread for my 1978 Wagon...
I like the electrical channel across the engine bay Are you gonna take care of that rust? Looks pretty nasty... Twitch
rear axle removal
Never mind, I got it with 15 minutes of heat and alternating bashing with a BFH and a steel rod. I coated it in bearing grease before reinstalling it, to reduce the chance of sticking and rust formation. Thanks for the info in the thread though Twitch PS: Its just about ready to go, I've just got to finish bolting it together
So? Who's going to be up on Friday? I'll be heading up early Friday morning, as in, I'll be going through Spokane at 8 or 9 in the morning. Anybody wanna convoy? (And yes, I will play that song ) Twitch
Picked up a 1991 Legacy SS yesterday...
- Alt not charging
Ok. Have you tried tracing the charging wire or getting a wiring diagram and seeing where exactly it runs to? If you can somehow look at the entire running of the main charging wire, you may find some broken wires, or maybe a short. Another thing, have you checked the voltage straight off the alt, grounding to the body? Twitch- Alt not charging
True, but the alt needs the signal wires to know when to charge. I found this out on my BRAT. I'm sure its the same on an EA82 as they share alternators. I believe the volt meter just reads off a circuit. Twitch- Alt not charging
Have you checked to make sure both of the signal wires are connected and have continuity? I've had that issue when the wires come loose (GM alt swap), or I forget to plug them in As for the dash lights not lighting up, I would check the back of the instrument cluster for any loose/corroded wires. Also, have you completely gone through your fuseboxes? Have you checked all the relays, fuses, fusible links, all that stuff? Twitch- rear axle removal
So what? :-p Its only 2010 Ok, I've been attempting removing the axle from the outside shaft, and I can't get it. I'm NOT going to disassemble the axle, but I've tried everything to break loose the axle (minus heat, but that's soon to be used) and I can't get it. Any other suggestions? And obviously I searched, how else would I have come up with this thread? Twitch- How many Soobs have you owned twice or more?
I bought an 87 GL wagon, sold it to a friend, he drove it for a couple months, then gave it back. Its still sitting in my parents front yard That's it so far, unless Bill wants to give Rusty back Twitch- B.R.A.T. Meet 2010
Heh, yeah, Brain Rocks I'm getting that installed today Thanks for the map Andy, looks like the end of the trail will make some awesome *ahem* "drifting" area Zap, that sounds great. If we could condense all the needed info into one first post, it'd make getting updates easier. Twitch - Alt not charging
